Question about Video Game Consoles & Games
Wii not reading wii fit disc - Video Game Consoles & Games
  • 3 more comments
  • Anonymous Mar 09, 2009
    Wii Fit "can not read disk". All other games work just fine, this is the only one.
  • Anonymous Mar 17, 2009
    I have the same problem. Wii fit disk not working. Nintendo wants $30 + shipping to get a replacement disk. Unbelievable....it costs them probably 20 cents to replace it.
  • Anonymous Mar 22, 2009
    wii fit disc not loading.
  • atulkhanna Apr 02, 2009
    Wii Fit DVD not working.All other Games working fine.Got it replaced from BestBuy as well. Still the same. Please help
  • san619diego Apr 13, 2009
    wii not read wii fit game, this seems to be a VERY common problem. Every place I've been to will not sell the game only, you must buy board and game OR trade in board and game. I smell a scam...
    New Friend:
I don't have a solution...I thought the solution would already be found here.
(grrrr!) its 2011 and my wii fit disc cannot be read.
O_0
Posted on Jan 16, 2011
SOURCE:
My wii fit plus disc reads cant be read when inserted in to the wii help please can it be fixed
Hi lyned1,
If the Wii is having trouble with a disk, it means there's either a problem with the disk or the Wii. If your Wii can't read any disks then you'll want to contact Nintendo. Otherwise you need to investigate your disk.
If you hold the bottom side of the disk to the light you should be able to see if there's a smudge or scratch. If it's a smudge, cleaning the disk will often fix the problem. Use the microfiber cloths used to clean eyeglasses or, short of that, a tissue. Just rub the smudged spot. (When using a tissue I generally steam up the spot with my breath first.) If the disk looks good, put it back into the Wii and see what happens.
A scratch is more problematic. If it's a game you just bought, try exchanging it where you bought it. Otherwise you can try polishing out the scratch.
Some older Wii units also have trouble with dual layer discs, If your Wii is having trouble reading a dual layer disc you can try Nintendo's Wii lens cleaning kit. And also you can try to use a different disk to check if your system will be able to read it. then try the Wii Fit Plus If after all that, your Wii still can't read the disc, it's probably just a bad disc.
Thanks for using Fixya.
Jan 28, 2011 | Video Game Consoles & Games
It doesn't recognize the wii fit plus disc it tells me to insert disc
Are you inserting the disc properly? And when is the last time you ran a laser lens cleaner through your Wii system. Dust and contaminants can cause disc read errors.
Oct 28, 2010 | Nintendo Wii Fit for Wii
Wii wont read discs
put in a cleaning disk.
Jul 16, 2010 | Nintendo Wii Console
Unable to read disc
If (1) this error only occurs with the Wii Fit game and (2) you have no scratches or marks on the game disc and (3) you have cleaned your Wii with a lens cleaner product recently; then, most likely the Wii Fit game disc is bad.It's not your Wii.
here's the problem: the wii fit game is 4.7gb. Most wii games are 4.4gb. Burning a Wii game at 2x speed is fine if its 4.4gb.
For Wii games that are 4.7gb (full size of a DVD disc) the games must be burned at 1x speed or errors will occur.
It is likely that Nintendo burned these at 2x speed and therefore your wii is getting an error due to them incorrectly burning the disc.
Aug 18, 2009 | Nintendo Wii Console
Wii console won't read disc
wash disc with 1 drop dawn rince pat dry
Feb 17, 2009 | Nintendo Wii Console
My wii fit disk wont work
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Dec 27, 2008 | Nintendo Wii Console
I got wii fit the disk wont work !!!!!!
Wii can"t read disc
If Wii gives can't read disc, so first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide,that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Dec 14, 2008 | Nintendo Wii Console
Video Game Consoles & Games Logo
147 people viewed this question
Top Video Game Consoles & Games Experts
Ekse
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
