Question about HP Computers & Internet
Looking for network security key or phrase word for Eircom 6317 7500
    President:
  • 2,961 Answers
You cannot get keys or phrases, you make them up yourself to form a secure wireless connection within the router security
Posted on Aug 17, 2008
How i chning computer password
LOST WIFI SECURITY KEY WORD
If you have lost your WEP/WAP wifi key phrase there is no way to recover it except go into the router administration settings and see if it is in plain text there. If not then you will have to make up a new key phase and apply it to ALL your connected devices.
In future, write the key phrase down on a piece of tape and apply it to the bottom of your router. You can use a hint instead of the actual phrase.
I use the memo function of my cell phone to keep all my passwords and keys.
Apr 21, 2014 | Linksys Wireless-G WAP54G 802.11g/b...
Tip
What is a WEP Key?
Wireless networks broadcast messages using a radio and are thus more susceptible to eavesdropping than wired networks. Wired Equivalent Privacy (WEP) is the first in a line of increasingly secure algorithms that include WPA and WPA2 used to secure IEEE 802.11 wireless networks.
Setting WEP up is usually done from the wireless security tab of your router configuration, this is most often accessed from your computer using the web address http: 92.168.1.1 by default. It consists of a pass-phrase and a key. the pass-phrase is used to generate an encryption key, this is then necessary to use any packets (Bits of data) transferred over the air.
Newer routers allow this configuration to be done through a visual application as well.
on Apr 08, 2010 | Computers & Internet
Netgear network security
Apr 06, 2014 | NetGear WG111V2 Wireless Adapter
How do I prevent my neighbor from using my wireless router?
If you do not have any wireless network security enabled on the router, your neighbor can see this SSID and connect to the network without authorization. While this is generally frowned upon as being unethical, it is technically not illegal as you have "made the network available" by failing to secure it. The easiest way to secure the network is through the use of a WEP key or a WPA pass-phrase. WEP keys are generally 5, 10, 13 or 26 randomly generated characters long. WPA pass-phrases are just that - a phrase such as "The sun is yellow". Either method will prevent unauthorized users from accessing your network. Only those individuals who possess the key or pass-phrase are granted access.
These options is located under the Wireless > Wireless Security tabs from within the router administration.After login you can change the password.
If you need any kind of technical assistance you can contact support cell at here
Jan 22, 2013 | Belkin Computers & Internet
I dont know what my network key is.
open new Internet Explorer and type in address Bar " http://192.168.1.1" and hit enter.
Leave user name field blank and type "admin" for the password.If you changed the router password, then log in using your password to login to the router.
Once you are in the router setup page, click on the Wireless Tab at the very top of the page. Once you are in the Wireless Tab, just right under the word Wireless you click the sub tab that Wireless Security. On this page you will see the Security Mode. If your security mode is set to WEP you will have four sets of keys available. To known which key to use look for the Default Transmit (Tx) Key, If your default transmit key is set to 1, then you will use the key in Network key 1 to connect to the wireless network. Now if your Security mode is set to WPA (Personal/Pres-Shared Key/PSK) what's inside the WPA-shared key or Pass phrase / Personal Key box is the network key for your wireless network.
May 15, 2011 | Linksys Wireless-G WRT54G Router
I'm looking for my security key on the back of my router.
Connect an Ethernet cable from the network-port on your computer to one of the LAN ports on the router.
Then, you can access the web-server "inside" the router, and run the "Wireless Networking Setup Wizard", to let you choose an SSID (your "network-name") and choose an encryption-level (choose 'WPA') and choose a password/pass-phrase, which will become the "security-key" for your network.
Sep 09, 2010 | Linksys WRT160N Wireless Router
What is wpa pass phrase while setting wireless printer
WPA with a Pre-Shared Key (PSK), also known as personal. PSK is entered as a pass phrase between 8 to 63 alphanumeric characters in the ASCII format at both ends of the wireless connection. Although PSK accepts a minimum of eight characters, for proper security, it is a good idea to use ample length and should not use a commonly known phrase. This phrase is used to generate session keys that are unique for each wireless client.
WPA pass phrase is a password for the wireless network to make it secured. You can obtain the WPA pass phrase when you access your router. Check the manual of your router for the address, username and password of your router. Go to wireless settings, you will see ther the SSID or Network Name, Network Key or the Pass Phrase and Authentication (WPA/WPA2/WEP). You can personalize the SSID,Network Key and Authentication. Remeber that for you to connect wirelessly the Authentication and Network Key on the router should match the Network Key and Authentication of the Printer or Computer.
Thanks for using Fixya,
Aug 06, 2010 | Computers & Internet
Trying to use old netopia router for new laptop
Well ther should be a wirless icon on the botom right corner of your scren right click and say serch for avalibe wirless networks. find the one that is yours. it might ask for a WEP pssword which is on the botom of router. You might have to change some of the wirless adapter setings. just send me a mesage and i would be happy to help.
Jan 02, 2009 | Netopia (3347NWG-ENT) Router (3347NWGENT)
2wire058, mod 2701 HG-B
To akd56 - tks for yr earlier advise, I got as far as "connect to a network" which asked for my security key / pass phrase when setting up which I now forgot.
Nov 18, 2008 | 2wire 2700HG-B Router (2700HGB)
How can i unlock netopia 2247NWG
Firstly... avoid showing your SSID (eircom-123456789) here, as the WEP key can be reverse engineered from the SSID.
To change your SSID, connect your router to your PC with an ethernet cable, go to your web browser (Intenet Explorer, Forefox, etc) and type 192.168.1.254, and press return.
This will open the control panel for the router.
Select 'EXPERT MODE' from the menu on the right, and accept the warning prompt. Then click on 'CONNECTION' and the 'WIRELESS' on the menu on the right.
In the main window you can then change the SSID for your network.
You can also change some of the other options in this window such as enabling closed mode, change security protocol, password, etc.
Feb 10, 2008 | Netopia 2247NWG-VGx Wireless Router...
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
