Question about Sony PlayStation Portable (PSP) Console
Frustrated with PSP and Laptop
I have HP Pavilion dv6000. I tried to trasfer a game from my laptop that I saw on SonyPlaystation store to PSP. Followed instructions: The PlayStation Network Downloader application. But, can't seem to download game to PSP. What am I doing wrong?
  • cherryana Aug 23, 2008
    Not working. I went to file. Clicked on it. And nothing is downloading in to my PSP. Any other suggestions.
    By the way what is version 4.05 FW? Desperately needing clarification! I appreciate all the help. Thank you.
Ok.OFW = sony official psp firmware.It is like an Operating system just like windows XP.It runs your PSP.
ok may b this will help.
start over again uninstall older version of sony network download manger.go to store.playstation.com then download latest version of sony download manager and install it.if your using any fire walls then make sure it is allowed by firewall to connect to the internet.then connect your psp and click on the file and it will download th efile.if still having probelms then add me [email protected] ll be able to help better there
Posted on Aug 30, 2008
  • 4 Answers
All you have to do after installation is to go to playstation network and download the demo or file you want to.After saving it goto the place where the file is downloaded and double click it.Connect your psp via usb and turn on usb connection.Your game will start downloading.Also make sure that you have 4.05 FW.
Posted on Aug 18, 2008
SOURCE:
Tip
Something about Replacement For HP Pavilion dv6000 Laptop Battery
Replacement For HP Pavilion dv6000 Laptop Battery - Extended capacity laptop battery for hp pavilion dv6000 series.The
lithium-ion replacement pavilion dv6000 series battery sold on http://www.discount-battery.eu.com/laptop-batteries/hp-
pavilion-dv6000.htm works with your notebook to reduce power consumption, letting you work longer than with other types of hp
pavilion dv6000 series batteries.This replacement battery pack is rechargeable, removable, Lithium Ion battery.The Hi-Quality
battery meets or exceeds original manufacturer specifications for your battery in quality, durability, and performance. Li-
ion batteries do not suffer from the memory effect. They generally last between 300-500 charge/discharge cycles. All
batteries are tested for 100% quality control assurance. This battery includes a one year warranty. We offer a 30 day money
back guarantee and fast shipping on all of our products.
on Apr 01, 2010 | Computers & Internet
Tip
How to Disassemble an HP Pavilion DV6000
The HP Pavilion DV6000 is one in a popular line of consumer-oriented laptops produced by HP. Relatively inexpensive, the Pavilion DV6000 is a good all-around value for most users. Taking apart an HP Pavilion DV6000 is not an easy chore and if you plan to use the laptop again, it is important you know what you are doing or you have a large appetite for risk. If the above doesn’t describe you, consider taking the HP in for professional repair or upgrade. Otherwise, follow the steps below to disassemble the HP Pavilion DV6000.
18385245_1.jpg?w=200 1、Prepare a clear workstation. Turn off the laptop and remove all power components including the cord and the battery. (Turn the laptop over and you will find the tab to push and pop out the dv6000 battery.) Also remove any peripheral attachments like card readers and USB devices.
90-04208-003_original-hp-pavilion-dv8000z.jpg?w=250 2、Turn the HP Pavilion dv6000 upside down and unscrew all the screws you find. Try to keep them separate by size so you can put them back in the same spot when and if you decide to reassemble the laptop.
3、Remove the hard drive and memory modules by pulling up on the rectangular compartments. The memory is located in the central compartment (remove by spreading latches and pulling up), and in most HP models the hard drive is located to one side.
4、Remove the optical CD/DVD drive by pulling on the drive face to the left and out of the laptop. Remove the WiFi card by disconnecting the gold connectors on the antenna and pulling the card from its slot.
5、Turn the hp dv6000 back over and remove the keyboard and power panel/media touch pad. Carefully pry the power panel up with a piece of hard plastic near the power button on the left side. Be careful when pulling not to yank the power connection as you might accidentally rip out a wire. Pull back the keyboard to reveal the connections. Disconnect the connections by carefully pulling on the tabs with your thumb and forefinger. If they are tight, wiggle them back and forth while pulling on them to loosen them.
6、Remove the screws that were underneath the power pack/media touch pad. Carefully pry up the top casing and set it aside.
7、Detach all visible connections to the motherboard by pulling gently on them, wiggling them if they are stuck. Gently pull up from the right side of the motherboard and remove. The HP laptop is now fully disassembled.
on Jan 21, 2010 | Computers & Internet
I have an HP dv6000 laptop computer, and, starting last week, the laptop acts like it's turning on (all the lights illuminate, fan starts for a second) but nothing on the screen, and then the laptop turns...
Common issue on HP dv6000. You will need to get to the GUP and reflow it with a heatgun. Try this hp pavilion repair guide. It contains step by step instructions on how to take apart the system and fix the issue with the video. www.msbin.com/hp
Dec 18, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
I have a HP dv6000 laptop that needs a motherboard replaced. can you tell me how to do that?
hp has step by step directions on there website for full rebuild of the dv6000.. let me get you the link here now...
http://www.insidemylaptop.com/take-apart-hp-pavilion-dv6000-laptop/
Sep 30, 2009 | HP Pavilion dv6000z Notebook
Laptop DVD
Try cleaning the DVD drive with compressed air, if it still does not work try cleaning the drive with a DVD disk cleaner. if it still does not work and the software for the DVD drive has been confirmed as operational then the drive is dead and needs replacement.
Jul 07, 2009 | HP Laptop Keyboard for HP Pavilion DV6000...
Laptop hp dv6000 will not recognize cd burner/dvd player
HP Pavilion dv6000 laptop PC
Did you 'turn off' the AUTOPLAY feature of the CD\DVD ? When the player "runs two times at startup", it is trying to find the program on the disc.2nd- Look in internet for HP dv6000 cd\dvd drive replacement.(If that is the ""exact match for the product"" you wrote about)
3rd.goto CONTROL PANEL>SYSTEM>HARDWARE>DEVICE MANAGER and look up cd\dvd and uninstall it. REBOOT, when your system comes back it will try to find the cd\dvd. If it does not, it is damaged (kaput!), must be replaced. If Windows finds the cd\dvd drive and reinstalls the drivers, but it does not work, then the heads are dirty or damaged.That Windows found the dvd\cd means that the circuit on the device works.
Mar 16, 2009 | HP Pavilion dv6000z Notebook
Is HP Pavilion dv6000 Laptop support Linux Enterprise Version 5
try out a live cd first for copatability...I use backtrack 3 with xp pro sp3 installed on hd..
Jan 22, 2009 | HP Pavilion dv6000z Notebook
Unlock code for hp dv6000 laptop games
i don't have the unlock code for hp dv6000 laptop games. help me, please!
Jul 28, 2008 | HP Pavilion dv9000z Notebook
Sony PlayStation Portable (PSP) Console Logo
77 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
