faucet needs new gaskets and springs located below the handle. remove handle, loosen collar nut and remove, pull cartridge out straight up, remove gaskets and springs, take to local Home Depot and buy new and replace. install cartridge, install collar nut, install handle. All finished.
Sounds like the collar that locks down the stem is in need of tighting to get some resistance to hold handle in place.
Remove handle to acces this collar and to tighten.
Sounds like the retaining ring under the handle may need to tighten a little to stiffen lever a little. To remove handle take plastic red/blue cap at base of lever covering the screw. Remove allen screw that holds handle to base with a allen wrench.
Try to tighten collar that holds the stem for the lever and that should help with the lever. if not the gasket that's under the collar maybe wore to the point that tightening want effect it.
If you need a parts diagram go to this link for an exploded view of the internal parts. I hope this will be helpful to you.
Sorry to read about your problem, I hope this helps you out.
their is a little cap at the top, remove it..then their is a set screw..loosen and pull the handle.. this can be hard.. then unscrew the large round collar that's holds the cartridge in place.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
1-Remove aerator from end of faucet spout to check to make sure it is not obstructed by anything. Grit builds up there and causes flow to decrease , but it can be taken appart and cleaned out.
2-If you have a sprayer attachment to it sometimes the diverter goes bad. This sends water to spray head.
Cut water off remove handle with allen wrench and loosen collar on top to gain access to remove spout. after removing handle and collar you can pull up on spout or work it side to side easily to remove it.
In the middle at the bottom it has a removeable diverter that can be removed and replaced.
If it comes appart it will restrict water flow.
3- If you have to remove faucet to make sure no obstructions any where esle.
I hope this may be some help for you to have a starting point.
it should be under the pivot nut /collar,(where you remove handle from.un screw it and look closely.it is shaped like a horse shoe and may have small hole in it,and is brass in color
there should be a removable "button" on the faucet base below the handle. under there, there should be a set screw. loosen the screw, remove the handle. now u can adjust the base, collar, etc. to ur liking...don't forget to reassemble everything the same way u removed them.
Handle or spout collar!
