Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
0 volts on pin 9 of the flyback
I got 0 volts on pin 9 of the flyback. IC561 is bad agreed?
In circuit testing of R541 and D531 isn't a reliable test. I would need to unsolder for a good test. I can unsolder and test when I replace IC561.
  • 2,337 Answers
Base on the service manual information, yes IC561 could be defective.
You did not get the +15 volts because the TV failed to power up and the majority of voltages are coming from the flyback transformer.
Posted on Aug 18, 2008
SOURCE:
2000 Ford mustang 3.8 cranks won't start diagnostic gives code b1353
B1353 Ignition Key-In Circuit Open GEM Go to Pinpoint Test B .
PINPOINT TEST B: THE KEY-IN-IGNITION CHIME DOES NOT OPERATE CORRECTLY
Do you know what the GEM - genaric electronic control is ?
You need a scan tool to check ignition switch position .Don't know if this would cause a no start . Have you check for ignition spark and fuel pressure ? Are there anyother problems with power door locks or windows or lighting ? Thing's the GEM controls ?
CONDITIONS DETAILS/RESULTS/ACTIONS B1 CHECK IGNITION STATES
NGS
Monitor the GEM PIDS IGN_KEY, IGN_A, IGN_S, and IGN_R while cycling the ignition switch through the OFF, ACC, RUN, START and key out positions.
  • Do the PID values agree with the ignition switch states?
Yes GO to B2 .
No GO to B4 . B2 CHECK GEM INTERNAL TONE OPERATION Trigger the GEM Active Command CHIME ON and OFF.
  • Does the chime operate correctly?
Yes GO to B3 .
No INSTALL a new GEM. For additional information, REFER to Section 419-10 . REPEAT the self test. CLEAR the DTCs. B3 CHECK GEM INPUT FROM DOOR AJAR CIRCUIT Monitor the GEM PID D_DR_SW, while opening and closing the driver door.
  • Do the GEM PID D_DR_SW values indicate CLOSED and AJAR correctly?
Yes INSTALL a new GEM. For additional information, REFER to Section 419-10 . REPEAT the self test. CLEAR the DTCs.
No GO to Pinpoint Test D . B4 CHECK GEM INPUT VOLTAGE FROM IGNITION SWITCH AT CJB FUSE 28 (15A)
CJB Fuse 28 (15A)
Measure the voltage between CJB Fuse 28 (15A), Pin 1, harness side and ground while cycling the ignition switch through all positions.
  • Is the voltage greater than 10 volts in the RUN and START positions only?
Yes GO to B5 .
No REPAIR the CJB. REPEAT the self test. CLEAR the DTCs. B5 CHECK GEM INPUT VOLTAGE FROM IGNITION SWITCH AT CJB FUSE 32 (15A)
CJB Fuse 32 (15A)
Measure the voltage between CJB Fuse 32 (15A), Pin 1, harness side and ground while cycling the ignition switch through all positions.
  • Is the voltage greater than 10 volts in the RUN and ACC positions only?
Yes GO to B6 .
No REPAIR the CJB. REPEAT the self test. CLEAR the DTCs. B6 CHECK GEM VOLTAGE INPUT CIRCUITS FOR OPEN - IGNITION SWITCH CIRCUIT 911 (WH/LG)
CJB Fuse 28 (15A)
GEM C352
Insert ignition key. Measure the resistance between GEM C352 Pin 8, Circuit 911 (WH/LG), harness side and CJB Fuse 28 (15A) Pin 2, Circuit 911 (WH/LG), harness side.
  • Is the resistance less than 5 ohms?
Yes GO to B7 .
No REPAIR Circuit 911 (WH/LG). REPEAT the self test. CLEAR the DTCs. B7 CHECK GEM VOLTAGE INPUT CIRCUITS FOR OPEN - IGNITION SWITCH CIRCUIT 1002 (BK/PK) Measure the resistance between GEM C352 Pin 22, Circuit 1002 (BK/PK), harness side and CJB Fuse 32 (15A), Pin 2, Circuit 1002 (BK/PK), harness side.
Yes GO to B8 .
No REPAIR Circuit 1002 (BK/PK). REPEAT the self test. CLEAR the DTCs. B8 CHECK GEM INPUT CIRCUIT FOR OPEN - KEY-IN-IGNITION SWITCH CIRCUIT 158 (BK/PK) Measure the resistance between GEM C352 Pin 9, Circuit 158 (BK/PK), harness side and ground.
Yes GO to B9 .
No REPAIR Circuit 158 (BK/PK) and key-in-ignition switch for failure. For additional information, REFER to Switch-Key-In-Ignition Warning . REPEAT the self test. CLEAR the DTCs. B9 CHECK GEM VOLTAGE INPUT CIRCUITS FOR SHORT TO POWER - IGNITION SWITCH CIRCUITS 911 (WH/LG), AND 1002 (BK/PK)
CJB Fuse 28 (15A)
CJB Fuse 32 (15A)
GEM C352
Remove ignition key. Measure the voltage between GEM C352 Pin 8, Circuit 911 (WH/LG), harness side and ground, and between GEM C352 Pin 22, Circuit 1002 (BK/PK), harness side and ground.
  • Are voltages greater than 10 volts?
Yes REPAIR the circuit in question. REPEAT the self test. CLEAR the DTCs.
No GO to B10 . B10 CHECK GEM INPUT CIRCUIT FOR SHORT TO GROUND -- KEY-IN-IGNITION SWITCH CIRCUIT 158 (BK/PK)
GEM C352
Remove ignition key. Measure the resistance between GEM C352 Pin 9, Circuit 158 (BK/PK), harness side and ground.
  • Is the resistance greater than 10,000 ohms?
No REPAIR Circuit 158 (BK/PK). REPEAT the self test. CLEAR the
Jan 03, 2017 | Ford Cars & Trucks
2002 f150 cruise inop shows code 3?
  • 3 flashes - deactivator switch is open or circuit defective.
    • Flash code 3 - deactivator switch circuit failure
    • Central junction box (CJB) fuse 13 (20A).
    • Circuitry.
    • Deactivator switch.
    • Speed control servo.
    • Go To Pinpoint Test H .
    PINPOINT TEST H: FLASH CODE 3 - DEACTIVATOR SWITCH CIRCUIT FAILURE
  • CONDITIONS DETAILS/RESULTS/ACTIONS H1 CHECK THE DEACTIVATOR SWITCH CIRCUITRY
    Speed Control Servo C122
    Measure the voltage between the speed control servo C122 pin 9, circuit 307 (BK/YE), harness side and the speed control servo C122 pin 10, circuit 57 (BK), harness side.
    • Is the voltage greater than 10 volts?
    Yes INSTALL a new speed control servo. REFER to Speed Control Servo in this section. REPEAT the self-test.
    No GO to H2 . H2 CHECK DEACTIVATOR SWITCH POWER
    Deactivator Switch C1025
    Measure the voltage between the deactivator switch C1025, circuit 10 (LG/RD), harness side and ground.
    Yes GO to H3 .
    No REPAIR the circuit. REPEAT the self-test. H3 CHECK CIRCUIT 307 (BK/YE) FOR AN OPEN Measure the resistance between the speed control servo C122 pin 9, circuit 307 (BK/YE), harness side and the deactivator switch C1025, circuit 307 (BK/YE), harness side.
    Yes INSTALL a new deactivator switch. REFER to Speed Control Deactivator Switch in this section. REPEAT the self-test.
Nov 23, 2016 | 2002 Ford F-150
Only charges 9 volts
Hi Mcnabb491, in order to check out any main system electrical circuit, you have to start with a fully charged battery 12.5 volts or better, and be able to pass a load test if necessary.
1. Check battery terminals for damage or corrosion, check battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
2. Check the voltage drop at the battery when you hit the starter button, anything below 9 volts you might have a faulty battery.
3. Check voltage at the battery with the bike running at 3,600 RPM should be 14.3 to 14.7 volts. If you are not getting these numbers, you might have a faulty voltage regulator.
4. Make sure voltage regulator is grounded and functioning properly, watch the video below on how to test a voltage regulator.
5. Unplug the connector to the alternator and hook your multimeter leads to the alternator (pin/socket selection does not matter) set the multimeter to AC volts, at an idle the meter should read 16 to 20 volts AC. at 2,000 RPM 32 to 40 AC volts, 3,000 RPM 48 to 60 AC volts. If you are not getting these numbers, you may have a faulty rotor, follow step 6
6. Set the multimeter to OHM'S, connect one lead to the alternator (any pin/socket) and the other to a ground, the meter should read infinity. Connect both leads to the alternator meter should read 0.1 to 0.2 OHM'S. If you are not getting these numbers, you have a bad stator.
7. Check all wiring in the charging circuit for worn or chaffed spots and all wiring connectors in the circuit for corroded, broken, or loose pins/sockets, which is the # 1 offender.
Good luck and have a nice day.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Dec 15, 2015 | Motorcycles
Need a wireing diagram for 149 cub cadet mower tractor it does not charge
The Battery Won't Charge or stay charged.
Several possibilities
  1. Key switch doesn't turn off the system and the battery drains while it's parked.
  2. Bad insulation on the wiring somewhere and the battery drains down.
  3. The alternator is not putting out enough power or no power at all.
  4. The battery is bad.
Let's consider the battery first. This is an easy check if you have a cheap, simple volt meter. It's much better to have an old fashioned needle meter rather than a digital. The needle is more sensitive, much quicker, and makes a clearer diagnostic tool. But not to worry, for you fancy folks a digital still works (sometimes the results are not as easy to decipher).
  1. Set the meter to DC Volts.
  2. Attach the red and black leads of the meter to the positive and negative posts of the battery. Most modern day digital meters don't care if the polarity is correct or not. However, if you have a needle meter, best to put the positive of the battery with the red wire of the meter; otherwise the needle will not be happy with you.
  3. Note voltage. It should read near or above 13 volts if the battery is good and fully charged. If it reads below 12 volts the battery needs charged or it has bad cells. If after charging a few hours, the voltage is still below 12 volts then the cells are bad, replace it. That should solve your problem. If not...continue.
  4. "Load Test". Turn the key to crank the engine while keeping your eyes on the meter. Whether the engine cranks (turns over) or not, the meter should not fall much below 11 Volts. If it falls below 10 volts or worse yet below 9 volts, the battery has a bad cell or two. Replace the battery, charge it, and repeat the test.
  5. If the engine starts, rev it up and watch the meter.
    1. If the charging system is working the voltage on the meter should quickly rise above 13 volts.
    2. If it rises up strongly towards the 14 volt range this indicates the charging system of the machine is working.
    3. If it plays around down near 12 volts you are reading the recovered voltage of a good battery, but the charging system is not working.
    4. If it simply stays below 11 volts, the battery and the charging system are both suspect.
      1. Charge you battery.
      2. Repeat the test.If you get the same results...continue
      3. Replace the battery.
      4. Fully charge it,
      5. Repeat the tests before worrying about the charging system.
Note: if the battery falls below 9 volts the fuel cut off, a black cylinder on the bottom of the carburetor (if your model has this), will cut off the gas supply to the carburetor.
If the battery passes all the tests and you still don't get 13-14 volts of charge it's time to test the charging system.
Small engines have 3 different possible alternators, standard circuit, dual circuit, tri circuit. I would need the exact engine model numbers in order to precisely answer your question. Often mower models have choices for the engine they come with. In this situation the engine model is more important than the model of the mower.
Testing an alternator is fairly simple; all you need is the same multi-meter used for battery testing. Do take note: The settings for battery testing are DC Volts. The Settings for Stator or Alternator testing are AC Volts (in the 50 Volt range).
  1. Disconnect the connector from stator. The stator is right there on top of the engine under the plastic/metal fan guard. Take this off and look for a pigtail wire with a connector. Don't get the coil wire with the spark plug end.
  2. Set multi-meter for AC volts.
  3. Attach RED test lead to either pin on stator side of stator connector. (On single wire leads, attach RED test lead to the single pin.) On AC output alternators there is no positive or negative because both wires alternate from positive to negative, so either pin will do.
  4. On two wire lead models, attach Black test lead to the other pin. On single wire stator connectors attach the Black test lead to the engine or other ground.
  5. Prepare the lawn tractor for engine start (set parking brake). Start engine and run at full throttle.
  6. Check output. Output for engines of this general size run in the 30 to 50 volt range. For instance the B&S V twin 22 hp AC output at full throttle is 30 Volts minimum. Other B&S on these machines spec 40 Volt minimum.
If your voltages are not in the manufacturers range (too low), or non-existent, your stator is partly shorted or completely burnt out (open circuit). Either way you have to replace it.
A. In the picture is a single lead stator connector.
B .In the picture is a two wire lead stator connector.
Mar 18, 2015 | Cub Cadet Garden
1996 Blazer fuse #9(ECM Battery) keeps burning out and wont let the vehicle start
No ! Do you know how to test electrical circuits ? Use a DVOM - digital volt ohm meter ? Use a wiring diagram to pin point areas for testing in a wiring harness .
Fuel pump electrical circuit diagnosis no fuel pressure testing GM
The #9 fuse powers the ECM , fuel pump relay , fuel pump switch , engine oil pressure sensor .
Aug 14, 2017 | 1996 Chevrolet Blazer
My jvc av-32890 makes a click and shuts off 95% of the time.It will not stay on and when it does it is only for a few seconds.
maybe your flyback. check b+ on the flyback. If you dont have voltage you can unsolder b+ pin on flyback and feed a 75 watt lamp to verify if power supply or flyback trouble.I think it`s pin 9 on flyback. look for print b+ on pcb.
Apr 23, 2010 | JVC AV-32890 32" TV
My Sony TV kv32s22 has a problem. It has audio but no video. There isn´t oscilation of the flyback at firts it turning on but now the red led is flashing all time. I look the pin for 9 volts has 8.2V...
Just moved my mitsubishi big screen from one location to another. The tv wont communicate to the remote and the tv will not resond manually. Pls help
Jan 08, 2010 | Sony KV-32S22 32" TV
Flyback
I read the other post you made and I don't belive that the flyback transformer has gone , and these models and makes from rca do have some common fixes that are found out by tech's . this problem that you are having can be in the power section , stanby circuit , protection circuit or even a horizontal output IC or some component that is causing the set not to come on . the flyback transformer would need to be tested to determine if it went bad but the power section would need to be tested first because there are different voltages that come out of the primary transformer and they go to different parts of the tv's functions and circuits , also info like what happen when it went out? and or was there a problem with it while watching it before it went out? , this can help to know what section was failing , thus start the testing in that section.
the best thing to do is to call an electronic repair shop to have a teck come out so they can determine the failure for you , as these are pretty complex sets and unsoldering and soldering , testing of and value idenentification of components is required , so if you cannot perform these then you could be putting alot of money into it and never finding the problem.
if you would like any more info , I'll bee glad to assist you
Dec 07, 2008 | RCA P52960 52" Rear Projection Television
Sony KV-27FS100
in theses set's there should be a board that has a module that the power chord plugs into this module supllies the motherboard and the componants on it. to be honest it would be best to just let a professional replace any defective chips orboards at this point because i believe it is not just one problem but several and without me beibg hands on it would be difficult to narrow it down to just a simple answer.
Sep 08, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
I measured 1.1V at pin 2 on IC561
Check for +15V from the flyback pin # 9, if that voltage is present; check R541 and D531. If these parts are good you should find +12V at TP98 nearby C539.
If still not voltage found, I would suggest to desolder and isolate IC561 pin 2.
Aug 16, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
66 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
