Question about HP Compaq Presario SR1230NX (PJ518AA) PC Desktop
Computer will not start
System will not re-boot
System error stop:0x0000008e
(0xc0000005,0x8043f574,0xf7618ad4,0x00000000)
Computer: Compaq Presario sr1230nx
  • 1,800 Answers
When Windows crashes with blue screen, it writes a system event 1001 or 1003 and a minidump to the folder \windows\minidump. Check system event 1001 and 1003 and it has the content of the blue screen
Event ID: 1001
Source: Save Dump
Description:
The computer has rebooted from a bugcheck.The bugcheck was : 0xc000000a (0xe1270188, 0x00000002, 0x00000000, 0x804032100).
Microsoft Windows..... A dump was saved in: .......
Event Source: System Error
Event Category: (102)
Event ID: 1003
Description:
Error code 1000007f, parameter1 0000000d, parameter2 00000000, parameter3 00000000, parameter4 00000000
Control Panel -> Adminstrative Tools -> Event Viewer -> System -> Event 1001/1003. Copy the content and paste it back here
Posted on Aug 17, 2008
SOURCE:
Error on windows xp desktop page_fault_in_nonpage_area
You receive "Stop error code 0x00000050 (PAGE_FAULT_IN_NONPAGED_AREA)" or "Stop error code 0x0000008E (KERNEL_MODE_EXCEPTION_NOT_HANDLED)" when you restart a Windows XP-based computer uparrow.gifBack to the top ' Give Feedback 20x20_grey_minus.png954211 MS08-061: Vulnerabilities in Windows kernel could allow elevation of privilege
  • 959252 Error message when you switch the operating system from a dual monitor setting to a single monitor setting on a Windows XP-based computer or on a Windows Server 2003-based computer that has the security update 954211 installed: "Stop 0x0000008E"
  • Note Update 959252 addresses a known issue that was introduced by update 954211.uparrow.gifBack to the top ' Give Feedback 20x20_grey_minus.pnguparrow.gifBack to the top ' Give Feedback 20x20_grey_minus.png824684 Description of the standard terminology that is used to describe Microsoft software updates
    Jan 06, 2014 | HP Computers & Internet
    System is wont boot
    Getting 0x0000008e is surely a signal that your registry is corrupted. What you need to do is to fix 0x0000008e as well as other registry errors to prevent your registry from total corruption. If you continue to run this damaged system and don’t fix 0x0000008e, this potential risk will bring you more troubles, Even system crash.
    Cause of the problem would be.Mis-deleting registry entries, downloading dubious files, hard shutdown PC etc can also cause 0x0000008e.
    Heres how to fix the issue
    Download the software fix by clicking here.
    Launch it after finishing the installation.
    Click “Scan Now” button
    Click “Repair Problems” button and fix 0x0000008e.
    May 21, 2010 | HP Pavilion dv6000z Notebook
    Cannot complete recovery or clean install windows Compaq Presario
    You could have a Boot Sector Virus. you would need to run anti-virus software to try and remove this issue. I would recommend Avast or AVG. I have attached a link of website that microsoft recommends. http://support.microsoft.com/kb/49500/EN-US/
    Jan 10, 2010 | Compaq Presario 5000 PC Desktop
    I hve a compaq presario 5000 desktop. It will
    if you can view your desktop and use the menus, go to start/all programs/accessories/system tools/system restore, if you had enabled this option earlier then you can restore the system to an earlier known date when you system worked.
    else you can try installing winXP again, try the option to "Update" when the install option comes on.
    else start PC, before the WinXp screen comes on press F8 key, use the Safe Mode to start PC, if you can see everything then shut down and restart in normal mode.
    Dec 06, 2009 | Compaq Presario 5000 PC Desktop
    My presario SR1920NX gradually sloed down and
    You more than likely will have to reformat due to a corrupt system...I would try first going into safemode (unless i misunderstood ) and to to start,run type "msconfig" and then go to startup tab....uncheck anything you just installed....caution: if you dont know what it is is...windows/system then dont uncheck it because that will actually cause the error you describe. Or try un-installing what you recently install in safemode. if you cant access safemode then use the recovery mode to recover the system files...usually the computer will ask for the windows XP cd. good luck...hope this helps
    Nov 01, 2009 | HP Compaq Presario SR1920NX PC Desktop
    Compaq presario 2100 laptop operating system not
    On my Compaq Presario Windows 7 laptop, I have got "Operating System not found" error, to fix problem,Windows Boot Genius helped me finally!
    Oct 10, 2009 | Compaq Presario 1692 Notebook
    Installing windows vista on compaq presario 750 computer stops responding during installation now can't boot or startup
    Vista installations inbult drive format tool is not so good, and causes errors, so i recomment u format the drive with some linux live cd's or some other bootup type partition tools. Then do a clean install. The problem should be solved if u hav min system requirements for vista.
    Mar 21, 2009 | HP Compaq Presario F750US
    Hp compaq presario v3000 is not loding the OS, show an error
    • as you boot the computer, start tapping the F8 keys
    • From the boot menu, select Safe Mode
    If this seems to work, you can try restoring the computer to an earlier point from Start > All Programs > Accessories > System Tools > System Restore.
    If Safe Mode also fails to load, you would have to check your disk for errors or you may have to install XP all over again.
    Please get back, if you need any further help.
    Jan 09, 2009 | HP Compaq Presario SR1920NX PC Desktop
    Unmounable boot volume
    This is an operating system error, and you will need an operating system disc. You can try to repair or reinstall the operating system, but most likely the hard drive has failed and will need replacing.
    Jul 19, 2008 | HP Compaq Presario V2000 Notebook
    Compaq Laptop Not booting
    This is not a hard drive problem. The reason for the display of the box showing the message is that one or more of your critical system processes got stopped somehow. Your system files may have got corrupted and may be as a result of that your computer is behaving weird. I too had the same experience.
    Try reinstalling the Operating System. It sure did work for me.
    May 11, 2008 | HP Compaq Presario V6000T Notebook
    Open Questions:
    VIPRE cUsToMeR SuPpOrT PhOnE /@\{18OO8O3/@\1O69} NuMbEr .U.S.A AsIf This VIPRE USA phone number is ranked #2 out of 2 because 7,728 VIPRE USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the VIPRE USA customer Support department for problems like Where to buy, Complaint, customer support, Repairs, Returns. As far as we can tell, VIPRE USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. VIPRE USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact VIPRE USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling VIPRE USA Calling VIPRE USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from VIPRE USA customer Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with VIPRE USA's customer Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare VIPRE USA's phone numbers against each other. Contacting VIPRE USA in General While I8OO8O31O69 is VIPRE USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach VIPRE USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact VIPRE USA.
    Oct 16, 2019 | Best Computers & Internet
    AVIRA cUsToMeR SuPpOrT PhOnE /@\{18OO8O3/@\1O69} NuMbEr .U.S.A AsIf This AVIRA USA phone number is ranked #2 out of 2 because 7,728 AVIRA USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the AVIRA USA customer Support department for problems like Where to buy, Complaint, customer support, Repairs, Returns. As far as we can tell, AVIRA USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AVIRA USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact AVIRA USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AVIRA USA Calling AVIRA USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AVIRA USA customer Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AVIRA USA's customer Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AVIRA USA's phone numbers against each other. Contacting AVIRA USA in General While I8OO8O31O69 is AVIRA USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AVIRA USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AVIRA USA.
    Oct 16, 2019 | Avira Computers & Internet
    AVAST cUsToMeR SuPpOrT PhOnE /@\{18OO8O3/@\1O69} NuMbEr .U.S.A AsIf This AVAST USA phone number is ranked #2 out of 2 because 7,728 AVAST USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the AVAST USA customer Support department for problems like Where to buy, Complaint, customer support, Repairs, Returns. As far as we can tell, AVAST USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AVAST USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact AVAST USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AVAST USA Calling AVAST USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AVAST USA customer Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AVAST USA's customer Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AVAST USA's phone numbers against each other. Contacting AVAST USA in General While I8OO8O31O69 is AVAST USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AVAST USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AVAST USA.
    PANDA cUsToMeR SuPpOrT PhOnE /@\{18OO8O3/@\1O69} NuMbEr .U.S.A AsIf This PANDA USA phone number is ranked #2 out of 2 because 7,728 PANDA USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the PANDA USA customer Support department for problems like Where to buy, Complaint, customer support, Repairs, Returns. As far as we can tell, PANDA USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. PANDA USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact PANDA USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling PANDA USA Calling PANDA USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from PANDA USA customer Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with PANDA USA's customer Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare PANDA USA's phone numbers against each other. Contacting PANDA USA in General While I8OO8O31O69 is PANDA USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach PANDA USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact PANDA USA.
    Oct 16, 2019 | Panda Computers & Internet
    See all HP Compaq Presario SR1230NX (PJ518AA) PC Desktop Questions
    HP Compaq Presario SR1230NX (PJ518AA) PC Desktop Logo
    407 people viewed this question
    Top HP Computers & Internet Experts
    Ekse
    Thomas F. Schneider
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
