Question about Hamilton Beach Iced Tea Maker
My dad gave me his Mr. Coffee Ice Tea Maker, but I have no instructions on how to use it. Can you please help?
Specifics may have changed for newer models -- we've had ours and used it happily for many years -- but the basics are simple.
(1) Fill the pitcher with water up to the "water" line and pour that water into the top of the appliance.
(2) Fill the pitcher with ice up to the "ice" line.
(3) Place a coffee filter and a family-sized tea bag into the top of the brew/steep basket and put the cover on that basket.
(4) Put the brew/steep basket on top of the pitcher.
(5) Slide the pitcher next to the appliance, such that the hot water exit port on the side of the appliance lines up with the entry port on the brew/steep basket.
(6) Press the "on" switch on the front of the appliance and wait for the tea to brew.
(7) When the brewing/steeping process is over, the appliance turns itself off.  Replace the brew/steep basket with the pitcher lid for pouring and storage.  Discard the tea bag and coffee filter, and rinse the brew/steep basket.
(8) Enjoy your tea!
Posted on Sep 16, 2008
I had a Mr. Coffee Ice Tea Maker Given to me with no information on how to use it ? model# tm36p sn tm30p
Unsure of which model number you are looking for a manual. Currently available manuals for Mr. Coffee Ice Tea Makers are available here:
http://www.mrcoffee.com/InstructionManuals.aspx
One of these should be close enough to your design to be of some assistance.
Mar 21, 2011 | Mr. Coffee Iced Tea Maker TM1S
Own the 3 qt ice tea maker. When making tea it leaks around the seam in the front of the machine and pours out all over the counter and not into the tea maker; any fixes or suggestions to remedy this messy...
I have this same problem. There seems to be two sources of the leak, described below. However, I think Mr. Coffee should re-design the offending parts.
1) bad fit between the brewer and the pitcher, caused by a pitcher that stands too high, preventing the pitcher's spout from snuggling into the brewer. I avoid this problem by brewing without the lid on the pitcher.
2) the brewed tea does not flow straight down from the brewer basket, especially when the tab is set to "strong". In this setting, the brewed tea is forced through a tube, in order to spend more time steeping. However, if you watch the tea flow out and down, you will see it bend to the left and thus miss the catch spout of the pitcher (and flow onto the surface, leaving the impression that one of the parts is "leaking") . I think this is caused by buildup of particulate matter from the tea and/or hard water deposits. My solutions here: try the tab in the "mild" setting; and/or clean the basket drain holes occasionally, especially if you have hard water (soak in vinegar to remove hard water build-up). You may need a tiny bristle brush to clean the small holes in the basket. Also, try to fit the pitcher into the brewer as far to the left as possible.
Hope this helps.
Gary in Torrance
Mar 02, 2011 | Mr. Coffee Iced Tea Maker TM1S
How to use mr coffee tea appliance
First clean the pitcher, lid, steeping basket and steeping basket before you use it the first time. Run a brewing cycle without any tea the first time and discard the water.
With the unit unplugged, fill the pitcher with water to the top water level mark on the pitcher and then pour the water into the reservoir. Do not overfill. Place the steeping basket and lid on top of the machine. Place a tray of ice cubes into the pitcher. Turn the steeping dial to open. Put the lid with the spout open on the pitcher and slide it, spout first, under the machine. Plug in the unit and turn it on. Wait until it turns off automatically.
For brewing, fill the pitcher with water to the line for the desired amount of tea. Pour this water into the reservoir (with the steeping basket and lid removed). Place a Mr Coffee filter into the steeping basket and add the desired amount of tea bags or loose tea. You can add sugar or lemon over the top of the tea if desired. Slide the steeping basket into the unit and put on the lid with the steeping dial set to closed. Fill the pitcher with ice to the desired ice level or with cold water to the same volume as poured into the reservoir. (If you are using water, put the pitcher in the refrigerator to chill.) Slide the pitcher with the lid on under the brewer and make sure the lid is open over the spout. Plug in and turn on the brewer. When the brewing cycle is done, it will turn off. Turn the steeping dial to open to drain the remaining tea from the steeping basket. (Let the remaining tea sit longer before opening the dial if you want stronger tea.)
You can get the manual from http://www.mrcoffee.com/Products.aspx?cid=43 . Click on the link for the TM3 (all the models in a series work the same way).
I hope this helps.
Jan 16, 2011 | Sunbeam Mr. Coffee Iced Tea Maker, TM3PS...
How do i get a manual that i can print out
I am looking for a manual on an Ice Tea Maker - Mr. Coffee Model 3.5
Jul 05, 2010 | Sunbeam Mr. Coffee Iced Tea Maker, TM3PS...
Where can I get Mr Coffee Tea Maker manual online
kitchen.manualsonline.com/manuals/mfg/mr_coffee/mr_coffee_ice_tea_maker_product_list.html - C
Jun 13, 2009 | Mr. Coffee Iced Tea Maker TM1S
Cleaning ice tea maker
Try to do that
  1. Pour 1 quart (32 oz.) of undiluted white household vinegar into the water reservoir.
  2. Place the pitcher lid on the pitcher. ...
  3. Push the "on" button to begin brewing cycle. ...
  4. Re-plug the cord. ...
  5. When your machine shuts off, unplug the cord, remove the pitcher.
Feb 24, 2009 | Sunbeam Mr. Coffee Iced Tea Maker, TM3PS...
How to
Fill the pitcher with water to the water level park on the pitcher and pour into water intake in the top of the tea brewer.
Fill pitcher to ice level mark (if there isn't one, put in about 2 - 3 trays).
Make sure that the brew basket lever is closed by pushing in then down.
Put 6 - 10 regular tea bags in brew basket and place brew basket on top of pitcher.
Slide the pitcher with the brew basket under the machine where the water comes out and make sure it is snug. Turn machine on.
When the machine is done brewing, the unit will shut off automatically.
Carefully slide the pitcher away from the machine and release the lever. This will let the tea pour into the pitcher.
That's it! Just don't put the pitcher, lid or brew basket in the dishwasher - that's how I ruined my first one.
Jan 24, 2008 | Mr. Coffee Iced Tea Maker TM1S
Coffee Makers & Espresso Machines Logo
319 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
jason
Greg Cann
Greg Cann
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
