Question about Kensington Pilotmouse Wireless Mini (73011576)
Batteries I have a Kensingfton wireless mouse model # 72237A. How do I change the batteries in that little mouse? Thanks
There is a none visible button under the word Kensington on the top off the mouse. Push the word itself and the mouse front and back will separate......... Hope this helps!
Posted on Mar 07, 2010
Holaaaa
Posted on Sep 21, 2008
  • 1,800 Answers
Its in the bottom of the mouse
rate me fix ya if this fixed ur prob if not fixed clarify ur problem!!
and i will be in ur command
Posted on Aug 17, 2008
  • 667 Answers
The top of the mouse is the battery cover. It should unlock from the tapered end away from the buttons/wheel
My Mouse is not working. I do have Window xp and 7 dell computers. I was looking for manualmouse Model No 72237A Manual. Looks like battery may be dead. Can you give some guidance. I did not use it for...
if you have optica usb mouse then u dont need to change or put new battery it will get its charge from pc through usb port
what you need to do is to install the mouse drive , mostly they are plug and play so u dont need to install any driver
Jun 20, 2010 | Computers & Internet
The wireless logitech mouse was working properly until it has low battery, when I changed the battery, it doesn't work anymore. There's a light but it doesn't work.The battery that I used is newly charged....
You need to 'reconnect' it. You didn't specify the exact model of your wireless mouse, but most types have a special 'connect' button on the receiver-box of the wireless mouse or on the bottom-side of the mouse itself. Just press this 'connect' button and you should be fine ...
Aug 23, 2009 | Logitech Cordless Mouse
How do i change the batteries in my logitech wireless mouse
Hi
On the bottom of the mouse, there is a tiny little button that has an image of a battery (it is very small).
Push that, and the covering that houses the batteries will pop up. You can then remove the covering easily to change the batteries.
Hope this helps. Thanks for using FixYa.
Jun 03, 2009 | Logitech WIRELESS OPTICAL CORDLESS MOUSE...
Changing the batteries in a hp optical wireless mouse
From pictures, it looks like the top part of that mouse slide down.
Try holding it with the buttons facing toward you, and pushing with your thumbs on the top silver piece of the mouse away from you.
May 18, 2009 | HP Wireless Optical Mouse
Wireless keyboard and optical mouse
Thanks! I fixed the problem by installing a USB mouse and using fn+f9. That unlocked the mouse so I could use the pointer leaving just the keyboard problem. I then tried reconnecting the wireless keyboard (by using the button on the receiver and under the keyboard) Hey Presto!!
Feb 02, 2009 | Logitech Wireless Access Duo Optical...
Hp wireless mouse model #m971au pointer stopped working
Make sure your batteries are good and then, Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch. Hope this helps you. Bud
Jan 14, 2009 | HP Wireless Optical Mouse
Battery change for model 98792 wireless GE mouse
Normal 0 If the mouse doesn't have a little door to open on the bottom, then try this. Just behind the Left and Right keys where your hand rests, apply firm pressure down on the cover and slide to the rear. Some mouse manufactures have used this type of access to replace the batteries.
Hope this helps. Bud
Jan 12, 2009 | GE Wireless Optical Mini Mouse 3087897985
Change battery
Jan 12, 2009 | GE Optical Mini Mouse ho98094
Change batteries
This is a deceptive little beastie. As you look at the mouse, you will see that the front approximately 1/3 consists of the left and right mouse buttons and the scroll wheel. The rest appears to be a one piece cover with the black area with the GE logo in the middle. There's the tricky part. The black part with the Logo is the housing for the USB plug in part (so you can keep it with the mouse when transporting it). The rest of that (silver on my mouse) is the battery cover. You open it up by gripping the little raised line on each side of the cover and pull backwards while holding the front by the black area under the mouse buttons. The cover (only the silver part, the black is attached to the rest of the mouse) will slide backwards and Voila! There are your batteries.
Wireless mouse
Dear friend,
I think that you are right, please check the manufacturing date of the mouse if one year has been passed that means it is ture.please also try to check your mouse after changing all the batteries of your wireless mouse.
thanks.
Jul 30, 2008 | Microsoft Wireless Optical Mouse
Kensington Pilotmouse Wireless Mini (73011576) Logo
281 people viewed this question
Top Kensington Computers & Internet Experts
dctocali
Level 1 Expert
Alun Cox
Are you a Kensington Computer and Internet Expert? Answer questions, earn points and help others
