Question about Panasonic FP-D605S2 Copier
Error code E04-01
Tried the reset instructions for the DP-2005 but the F9 function doesn't have an LBP fuser rest option. any ideas?
    Problem Solver:
  • 18 Answers
You should be able to open the front cover and close it. This should rest the warm up low temp. code. If not sounds like you have a blown fuse or thermal lamp. Are you able to see the heat (bright orange)lamp turn on at the exit side of the machine. or does the copier feel a little warm at the exit before indicating an error. Hpe this helps. Please leave + feed back
Posted on Nov 27, 2008
ERROR E04-01 SHOWN BY THE MACHINE
reset code fuser error...press at the same time "original size" + 'function" + "3"
F9 mode, 06 (ram initialize) sub code 04 to reset fuser code
Jul 12, 2011 | Panasonic DP-8045 Grayscale Copier
Panasonic DP-8035 Copier. Machine Error E04-02
Yep, you need to go into the service mode to reset this code. To enter the service mode press and hold the FUNCTION, ORIGINAL SIZE (LEDGER/A3), and 3 keys and F1 should appear on the screen. Go to F9 by pressing 9 on the keypad, press the down arrow key once on the touch screen, press 06 RAM Initialize on the screen, and choose 04 LBP Fuser Reset. This will clear the code.
Jan 28, 2011 | Office Equipment & Supplies
What does error code E04-02 mean?
You've had too many fuser jams. Remove the fuser and inspect the heat roller and separator claws. After putting the fuser back in, you must do an lbp fuser reset in F9-6 mode. While holding down the function key, press original size ledger key. While holding those down, press the 3 key. This gets you into service mode. Press the stop key, then while holding down function key, press clear key to exit service mode.
Jan 05, 2011 | Panasonic Workio DP-3520 Copier
Panasonic dp 2000 pm error code e04-01 need help
this is fixing error
f9
enter
Apr 02, 2010 | Panasonic Workio DP-2000P Copier
E 04-1 Error code What I do Reset?
the best thing that u do first is to clean the fuser unit, esp. the thermostat located there. then you may go to service mode, (function+orig.size+3), F9, look for ram initialize, then look for LBP FUSER RESET.
it will reset all e4 machine error.
Sep 11, 2009 | Panasonic Workio DP-3030 Printer
DP 3530 error code E04-02
Hello sir; You have to look at heating unit you havv paper jam over there!
Aug 23, 2009 | Panasonic Workio DP-3530 Copier
Panasonic dp c-264 error e04-34
Fuser code, reset in service mode F9 -06-04, continues to come back new fuser required
Aug 05, 2009 | Panasonic DP-C264 Copier
Panasonic workio 3000 error code E04-01
Your FUSER is not warming up. It needs to be replaced.
Jun 29, 2009 | Panasonic WORKiO DP-3000E Printer
Panasonic FP-D355 Error Code E04-01
Jan 16, 2008 | Panasonic Workio DP-3530 Copier
Workio DP-2500
E4-01 is the fuser not heating up in time. It can happen after paperjams, and usually it is no big deal. A reset of the code and you might be good to go.
Go in to service mode:
Function + Original Size + 3
Hit 9 for F9 mode
Scroll 'til you see Ram Initialization and enter there
Look for an "LBP Fuser Reset" option. Choose that and it will then ask you to turn the power off and back on. If the code comes back up then you have a blown thermistat or thermal fuse. You'll have to pull the fuser out to take care of it, but you'll want a tech to come out and do that.
Jan 08, 2008 | Panasonic Workio DP-2000P Copier
Panasonic FP-D605S2 Copier Logo
227 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
