Question about LG 42LC2D 42 in. LCD HDTV
Display delay I have a 37 LCD LG 720 and I am annoyed by the 6 second delay that occurs when I switch channels from regular definition to high definition and it also occurs from high def to reg def. I contacted LG and they said it probably has someting to do with my high def provider. I called my cable provider, Verizon Fios, and they informed me this is an LG issue. Any suggestions? This is very annoying!
I had the same problem. The cable comp. told me the same thing. I got a new box anyway and the problem was solved
Posted on Jan 14, 2009
  • 71 Answers
This is unlikely Verizon's problem.
Does the delay occur with non-TV sources like DVD player or video games?
If so, that's the LG firmware.
Posted on Aug 29, 2008
I have an LG TV model42LN543N-28 is this model high definition
I can't find an LG 42LN543N-28 listed anywhere. The 42LN5400 has a full HD display (1080); this model sold in the UK was labeled the 42LN543V. Thus I suspect that your model also is a HD TV.
Any screen with 720 rows of horizontal pixels or more is usually called a high definition TV or monitor (depending on the inclusion of a TV tuner). The 42LN5400 display has a 1920 x 1080 maximum resolution.
I hope this helps.
Jan 18, 2018 | LG Televison & Video
Water won't drain
Do the diagnostic test:
SHU 53 MODELS
To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show “88′ when REGULAR WASH button is pressed and “8h” when Delay Start button is pressed.
To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4).
0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault
1 = Aqua Sensor (“Sensotronic”) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), display will show fault code “4′ and unit will continually fill and drain where testing won’t be completed. If flow switch (e5) has failed (opened), display will show “0′, water won’t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code “8′ immediately and testing will end shortly after water has started circulating.
The dishwasher not draining is most probably faulty drain pump or drain hose is got bit loose.It has to be checked and confirmed
.You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 27, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
TV is working beautifully then the screen goes dark for 3-15 seconds and then the image reappears in beautiful HD. The TV is two years old and otherwise works perfectly
Technology changes at a high rate of speed, as we all know. And High Definition (HD) has come a long way in a very short period. Since your television still works perfectly otherwise, I don't think that it's a problem with the set itself. It may only be a victim of technology.
Does this only happen with High Def channels? Does it happen every time you change to another HD channel? If you answer 'yes' to either of these, it is most likely due to the television's processing capabilities. Because of the high amount of data that is required to deliver HD content, manufacturers have found creative (but not necessarily convenient) ways of dealing with the processing issues (blank screen delay for example). Since the audio and video signals for any given television station (either HD or regular) are transmitted separately, the television has to process that data internally so that you get the picture and sound aligned properly when you are watching it. HD broadcasts are much more demanding than regular stations requiring manufacturers to constantly improve this processing speed with every new model. On some televisions, the channel remains blank for a few seconds to allow the television to configure all of the information so it looks good when it's ready, which could explain the delay you are describing. At the time your television was manufactured, this may have been the best technology your manufacturer had to offer. On my personal flat panel, I get the picture and sound right away, but I have to wait about 15 seconds for the sound to catch up to the picture which I think is more annoying than being forced to look at a blank screen. But that's just me.
Hope this information was helpful.
Mar 19, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
I bought a Sanyo DP46849, lcd tv, 1080. and I'm getting a fuzzy picture. It helps when i put my cable receiver on hd channels, but even my blu-ray looks better on my 720 plasma???? any suggestions, I...
I gather from the information given that you are getting the proper signal from the cable receiver but there may be a settings issue with the LCD TV. If the 720 plasma is giving good performance then it has to be settings on the lcd .
I would review the instruction manual to see if you have over look something that is a proper cable select ( hdmi or vga).
If you have selected vga you will not get a clear picture in that mode. HDMI is High definition which works properly with 1080P mode. If you have further issue the manufacturer troubleshooting or Knowledge base will give answers also.
1. check your HDMI cables make sure they are properly seated in the input ports
squarely not at an angle.
2. If you are using a cable receiver check the connection there. Make sure you have the proper cable for your receiver to the TV
3.check channel to see if you TV is selected for channel 3 or 4 as recommend in the instruction manual
4. check the V-chip setup it may be blocking certain channels
5. check you picture modes each channel can have desire picture setup modes.
6. If you are using rca cables you may not get the proper picture as you would with HDMI cable that are specially designed for High Definition TV
Mar 13, 2010 | Sanyo DP46849 46 in. HDTV
Model LG52LG70 has a problem when switching from High Definition channels to non-high definition channels, and vice a versa. The tv simply shuts off, pauses for 10 seconds and then turns on. Time warner...
Any high def TV will momentarily go blank when changing from High Def to normal mode. Ten seconds is an abnormally long time for that to take place. If you still have a warranty on the TV I suggest you take it in to have it serviced. Otherwise you will have to pay to have this item checked out. There are a number of issues that might be causing the problem so it will be necessary to have a technician check it out.
Feb 18, 2010 | LG 52LG70 52 in. LCD HDTV
The dishwasher has been running for 3 hours and seems to be stuck on 1 minute left. Upon opening, there was sudsy water remaining in the bottom, but the dishes looked clean. The washer just won't go to...
SHU 53 MODELS To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button. To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show ?88″ when REGULAR WASH button is pressed and ?8h? when Delay Start button is pressed. To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4). 0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor (?Sensotronic?) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test) To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty. If water level switch (f1) has failed (opened), display will show fault code ?4″ and unit will continually fill and drain where testing won?t be completed. If flow switch (e5) has failed (opened), display will show ?0″, water won?t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code ?8″ immediately and testing will end shortly after water has started circulating.
Aug 01, 2009 | Bosch SHU5315UC Dishwasher
Bosch SHU 6800 Water hot at sink only luke warm at the washer
BAD CONTROL BOARD TO TEST TO SEE IF THIS IS THE ISSUE RUN TEST PROGRAM
pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ “20” = version 0 without jumper). When
alone). Cycle Countdown display will show "88" when REGULAR WASH button is pressed and "8h" when Delay Start
button is pressed.
To start testing, press both SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended,
together, (e.g./ “6” = faults 2 + 4).
1 = Aqua Sensor ("Sensotronic") fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
If water level switch (f1) has failed (opened), display will show fault code "4" and unit will continually fill and drain where
testing won't be completed. If flow switch (e5) has failed (opened), display will show "0", water won't heat (to 150ºF) and
water won’t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code "8" immediately and
Jul 18, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Sound issue on LG 42LG50
make sure the dish network menu settings in setup under audio are on high. Some tv's require it to be off. Try both and see what works. Also the delay is caused by digital conversion. new stereos have settings for this delay and they have delay boxes for sale online. You could try to change your delay settings on your stereo surround to help. I had to do this.
Nov 29, 2008 | LG 42LG50 42 in. LCD HDTV
Trouble removing closed caption on screen
tuner control the close cption /
in most case the cable box / CABLE BOX ACTS AS MAIN BOARD FOR TV - all tv can do is transfer and display image...
MOST LIKELY NEED TO CHANGE OPTION ON YOUR CABLE BOX ( TUNER) REMOTE - CALL YOUR CABLE SUPPLIER FOR TROUBLE SHOOTING IF WORSE COMES TO WROSE....
LG REP
Sep 13, 2008 | LG 37LC7D 37 in. LCD HDTV
Lg lcd 37 inch tv loosing sound
i have the same problem and find that if i freeze then unfreeze the screen it works
Jan 31, 2008 | LG 42LC2D 42 in. LCD HDTV
LG 42LC2D 42 in. LCD HDTV Logo
149 people viewed this question
Computer Repairing
Computer Repairing
