Question about Toys
Talking pete the repeat parrot doesnt work, want to fix it
Hi
its one of those red and colored talking parrot toys, it was working and got the plastic mount broken somehow; years later it was pointed to, I put in batteries and it does nothing.
I carefully opened it, and there is a motor for the wings and beak and a circuit board with a 40pin DIP and a smaller 16 pin chip MB8264A, probably a DRAM?
Id like to find the schematics and dig into this
thanks!
  • toots171 Apr 14, 2009
    I got a Talk Back Parrot that has stopped talking. Would like to know if the problem is the battery connection or the circuit board?
    Thanks
5 Suggested Answers
SOURCE: MS-1036 doesnt sense power cord attached
You hit exactly on the head with don't move the unit when plugged in - there are many people with the MS-1036 having this problem if you search the web. MSI does cover the bare-bone itself, however this falls into that damaged not defective area. Many shops would replace the entire board, making it costly as looks you had done once already. Good idea is to look to Asus 17" bare-bone and move your items over, much better made. Citrus Micro - see you worked with them, so have I, always had good luck with them, they make great contact and sometimes too honest, prices are great to - like any etail store with returns, manufacturer warranty tells most etail stores how they are to handle things. Could be why you see them getting rid of selling MSI products? Looks like you found the best idea, take to walk in repair shop - hard to beat that or again, buy new bare-bone.
Posted on Sep 07, 2007
rey jr
  • 149 Answers
SOURCE: Toshiba TV model CZ27V51 - picture+audio off, red light flashing
hi there, Flashing light red means a shorted electronic component is need to be replaced. do some test at video section, most of it are diode, transistors, transformers. ty
Posted on Jan 27, 2008
SOURCE: Schematic and/or wiring diagram - Magnavox TV Mod 20ms233s
the problem in my tv is the sound no have
Posted on Jul 04, 2008
  • 65 Answers
SOURCE: Bad wax motor in door lock assy. Where I can buy just wax motor?
TRY WWW.MARCONE.COM OR WWW.SEARS.COM UNDER PARTS. IT WILL GIVE YOU AN EXPLODED VIEW OF THE LATCH.
Posted on Jan 27, 2009
SOURCE: My Chamberlin remote garage door opener stopped working.
Try this website for a possible solution
http://www.bearcatco.com/helpgifs/liftmaster_troubleshooting.html
Posted on Feb 16, 2009
The bike will go in reverse but won't go forward. how do I fix this?
Lil' Rider FX 3 Wheel Battery Powered Bike, Black - Amazon ...
www.amazon.com/Lil-Rider-Wheel-Battery-Powered/...
Amazon.com, Inc.Amazon.com: Lil' Rider FX 3 Wheel Battery Powered Bike, Black: Toys & Games. ...On Motorcycle 6V Toy Battery Powered Electric 3 Wheel Power Bicyle, Red ... VTechGo! ... sound effects, working chrome colored headlight, and forward and reverse ...power wheels vehicle more to handle size, weight, and your child won't ...
Lil' Rider FX 3 Wheel Battery Powered Bike, Blue - Amazon ...
Amazon.com, Inc.Amazon.com: Lil' Rider FX 3 Wheel Battery Powered Bike, Blue: Toys & Games. ...Sold by: Global Supplies (We currently can't ship to, HI, AK,APO,FPO, POB) .... Ride On Motorcycle 6V Toy Battery Powered Electric 3 Wheel Power Bicyle, Red ... sound effects, working chrome colored headlight, and forward and reverse ...
KB901 Lil' Rider FX 3 Wheel Battery Powered Bike ...
? 8:05
https://www.youtube.com/watch?v=fED8N8DTQfU
Oct 21, 2013 - Uploaded by TMKGL
Jan 07, 2016 | Lil' Rider FX 3-wheel Battery Powered Bike...
What are some must-have toys I should buy for my parrot?
You want to try and buy your parrot a selection of toys, helping to distract your bird and keep it entertained for many hours a day. I recommend looking for a good chew toy, something for exercise, a long-lasting durable toy and perhaps a foraging toy. Below are some links of great parrot toys.
http://www.funtimebirdy.com/foragingtoys.html
http://www.funtimebirdy.com/ring-toss-trick-training-bird-toy-for-macaws.html
http://www.birdguys.com/bird-chew-toys.html
Aug 30, 2012 | Aspen Birds
Pair sony ericsson xperia x10 mini with Parrot VM3.20
Hi to all all the above solution to pairing your phone to parrot system don't. Work toyed them all But this will work first Turn your Bluetooth off on. Your phone Now turn on the parrot sys go to settings Go to pair devices were the old phones are still in the memory. You need to go to each one press the green button roll the menu button down Till it shows you delete this phone press the green button Do this till all old phone that were in the memo are gone then and only then do you turn on your phone Bluetooth and it will find the parrot sys it will ask you for a code Enter 1234 and the phone is paired this will work as I did it this way to day No green and red button pressed together or all three will etheir So save your time and do it this way many thanks ;);)
Jul 11, 2012 | Parrot Par Ck3000 Evolution Ck3000...
How do I dim the backlight on 2005 hd roadking speedometer
Don't think you can.Your talking dim like dash lites in car.Try this.Take lens off and get sheet of colored plastic,thin gauge.Cut out piece and place it in lens and put it back on.Of course red and the thicker the plastic the dimmer the light coming thru.Guess blue would work.Might make needle hard to see but probably no worse than dimming would.I don't know the kind of bulb you have but you can get some bulbs already colored in red or orange.?.I'm talking plastic like wax paper or celliphan.
Feb 20, 2010 | 2005 Harley Davidson FLHR - FLHRI Road...
Parrot CK3100 lcd control isn't working.
try pushing the wire into the bottom of the display, this comes loose easily and causes these problems.
Oct 21, 2009 | Parrot Ck3200 Ls - Color Cell Interface...
Can't get contacts to work with parrot 3200ls & nokia N95 8GB
hi, try using the object push in your settings. this happened to me and i had to install a program from my work and then object push. worth a try.....
Apr 15, 2009 | Parrot Ck3200 Ls - Color Cell Interface...
Unable to pair with CK3100
You need to reset the Parrot first.
Hold down red and green buttons together until she tells you that the memory is being cleared. Then she will prompt you to pair your phone.
Feb 05, 2009 | Parrot Ck3200 Ls - Color Cell Interface...
Toys Logo
382 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
