Question about Emerson EWR20V4 DVD Recorder/VCR
Can't record cannot go to setup and go into disk to format it will not go over to disk what do i do
  • rhamil Sep 01, 2008
    using dvd-r and the dvd will not record
  • Anonymous Nov 26, 2008
    I can not get my setup menu to allow setup on the highest level. I can change region for example or format. I can not record on DVD-R
I wonder if you ever fixed your Emerson EWH100F DVD VHS machine. I'm looking to buy one for parts. I need the DVD drive. So if it's sitting busted on a shelf somewhere please let me know. I'd probably buy it from you.
My email address is Tom@CasperCabs.com
Thank you,
Tom...
Thank you...
Posted on Nov 29, 2008
I have a toshiba dvd recorder D-R160SB and am trying to record from sky plus to a verbatim dvd-rw (as recomended by the manual). When i put the disk in the dvd recorder it immediately starts to format the...
Two in ten discs usually are corrupt out of the box unfortunately. Try a different brand. As for it coming out in 4:3 or 16:9 try the settings on your SKY box. This should work.
Mar 01, 2014 | Televison & Video
When i insert a blank disk i get cannot format disk message
sorry that you getting this message......... but the ch-dvd 300 is not a recording machine........it only plays recorded DVDs
May 08, 2011 | Cyberhome CH-DVD 300 DVD Player
Have been using DVD&RW disks for years now they won't format, no matter what brand.
Do you mean finalise the dvd record; its different from format on the PC? Finalise is in the setup of the combo.
Aug 16, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Every disk I put in to record something says bad disk
There's very little information about your problem, like model and disks you are using. I can give you general information.
All DVD's doesn't work will all types of recorders.
DVD Types:
  1. DVD-R, DVD+R, DVD-RW, DVD+RW, DVD-RAM, DVD-ROM, DVD+ROM.
For More In-Deph detail of DVD Formats, Enter Here.
Check what types of disk your equipment uses. Maybe needs lens cleaner or is a equipment malfunction. If it reads, then most likely is in good shape. From my experience, I have two DVD recordable setup boxes. But one only accepts DVD-RAM and the other accepts DVD+Recordables and ReWritables.
If this can't help, you can post more detail about your equipment.
Jul 06, 2009 | Daewoo DVR-06
I can format dvds or record what is wrong
make sure that when trying to format dvd's you are using the bottom portion of the controls. i know it sounds silly, but the center arrows are for dvd playing and control....ff...rw....play, and the lower controls are more functional.
i'm not sure, but if you put in a blank dvd-r disk, it will allow you to format after going to the "setup" then using the lower arrow moving the selection over DVD. format is allowed in that selection. If you have already recorded on the DVD-R i don't believe it allows you to format, it only allows you to edit or finish.
i'm not sure how the dvd-rw works as i haven't used one in a long time. in theory, you should be able to format a DVD-rw.
hope it helps.
Jan 25, 2009 | Emerson EWR20V4 DVD Recorder/VCR
Emerson EWR20V4 -can't format discs for recording
mine says NB108. You may have the correct remote. make sure after you push setup that you use the lower set of arrows, not the ones beside the play/stop buttons. this should allow you to move over and push right arrow, moving you over the disk options allowing you to format and other options. i can't tell you how many times i've pushed the wrong arrow and thought something was the matter. additionally, you may only be allowed to use up to 8x recording speed disks. i've had mine awhile, and have had a service pack that allowed me to go from 4x speed to 8x speed. there is no service pac to allow you go higher on the dvd-r. i believe the highest you can use on the dvd-rw is 2x.
hope this helps
Jan 23, 2009 | Emerson EWR20V4 DVD Recorder/VCR
Have sony rdr-gx360. no manual to show how to work recorder or format cd.
Try this - You will need remote.
After you have recorded video... (if you eject disk all will be lost)
- Push "Setup"
- Now push "Edit"
On left hand side it should now show "Finalize disk".
I also lost manual and took a few minutes to find.
Dec 25, 2008 | Televison & Video
DVD created on my Samsung R155 won't play on other playes or PC
check the output formats the machine is writing to disk and then compare the players formats they are being used in
could be your disk type ie format type - Minus (-) or Plus (+)
One disk is better for data and the other is better for DVD video
Jul 22, 2008 | Televison & Video
Dubbing rom hdd to dvd
All you have to do is select dvd on the remote (at the top). Then it should do it automatically. If it doesn't, go to menu, then setup, disk, format. That does the job.
Nov 17, 2007 | LG RH1999H DVD Recorder/HDD Recorder
Vcr to dvd recording
As i recall, +r's will only format in dvd vr, the unit does not like high speed recording disks. switch to dvd drive - insert blank disk - if no format screen - goto (on remote) setup - onscreen menu - system setup - disc setup - new disk format - hit center button in ring on remote to change to vr or move up to reformat as vr. once disk is formatted, use record speed button on remote to set record speed 1,2,4,6 hr then switch to tape deck with tape in and stopped at begining, on remote hit dubbing, it will ask you confirm dubbing vhs-dvd .... toggle over to yes & hit center button... away you should go... c245 is a copyguarded tape.
Oct 09, 2007 | Sansui VRDVD4005 DVD Player/VCR
Emerson EWR20V4 DVD Recorder/VCR Logo
54 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
