Question about Onkyo Audio Players & Recorders
Connecting receiver to dvd player and hdtv - Onkyo Audio Players & Recorders
  • 682 Answers
Dvd out to cd in receiver.
regarding hdtv with its cabel from receiver to tv.
Posted on Aug 17, 2008
How do I setup my dvd to mt tv, i use direct tv
How to Program DIRECTV Remote Control ' DIRECTV ...
https://support.directv.com/.../how-to-program-directv-remote...
DIRECTVTo do this, press and hold the MUTE and ENTER buttons while pointing at your Genie HD DVR, Genie Mini, or Wireless Genie Mini. The screen will display Applying IR/RFsetup. To program your remote to control a regular HDTV (not a DIRECTV Ready TV) or audio devices, follow these steps: Press MENU on your remote.
How to Connect DIRECTV Receiver to TV ' DIRECTV Support
https://support.directv.com/.../how-to-connect-directv-receiver...
DIRECTVHow do I connect my DIRECTV receiver to my TV? Print. Email ... This will help you determine what cable to use to connect your receiver directly to your TV. ... For example, a DIRECTV receiver, DVD player, Blu-ray™ Disc player, o... How to ...
Remote Control Code Lookup - DirecTV
Dec 10, 2015 | Supersonic Televison & Video
How do I hook up a HD satallite dvr to a av reciever dvd player and HDTV using HDMI cables
Things You’ll Need:
  • HD television
  • HD satellite or cable receiver
  • DVD player
  • Stereo receiver
  • AV cables
  • Cable connector
  • HDMI cables
Step1Examine the back of your HDTV. You will see a series of input jacks for AV cables, (typically color-coded white and red for audio and yellow for video), as well as an antenna input and one or more HDMI input jacks. There will likely be a number of them, but each one should be distinguished with a label ("video," "cable" or something similar). Step2Attach the cable connector from the cable or satellite receiver to the antenna input on the back of the TV. Step3Connect the AV cables to the DVD player, VCR, stereo receiver or whichever other component you wish to connect to the television. The cables should line up by color: place the white cable in the white input jack, the red cable in the red input jack and the yellow cable in the yellow input jack. All three cables from each component need to go into the same label input jacks. Usually, they will all line up in a vertical row. Step4Find the HDMI output jack on your receiver or DVD player (some receivers will not have them--they are necessary to receive a high definition signal--but can still play on the TV through the cable connector or AV cables). Attach one end of an HDMI cable to the output jack of the receiver and the other end into the input jack on the HDTV. Step5Turn on the TV. Access the menu with your remote, and follow any instructions it gives you. Your HDTV may require a few additional steps to complete the hookup of the receiver (though not all of them will). Step6Access the "input" button on your TV remote. This will allow you to switch the TV signal to one of the cable connections you have just made. For example, if you attached the HDMI cable to the first of two HDMI input jacks, the TV will flash "HDMI 1" on the screen to tell you that is where it is receiving its signal. Hope that helps..........
Jul 15, 2008 | Televison & Video
I need the wireing to hookup to a tv.
Hi, it depends on the kind of TV your using...
How to Hook Up a Receiver to an HDTV
Though it utilizes the most sophisticated technology on the plant, an HDTV is extremely easy to hook up to a receiver. Home entertainment systems are designed for compatibility, whether it is a cable or satellite receiver, a DVD player or a stereo sound system.
Instructions
things you'll need:
* HD television
* HD satellite or cable receiver
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Tips & Warnings
Not everything that can be hooked up to an HDTV is capable of playing in high definition. The signal needs to be HD as well, which means that only HD broadcasts, HD DVDs and Blu-Ray DVDs can play in full high definition (though "upgrade" DVD players will allow normal DVDs to play at an enhanced picture). You can still hook receivers up to an HDTV, and it will still play broadcasts from them as clearly as the signal permits.
Mar 15, 2011 | Audio Players & Recorders
I cannot get any sound to the speakers, hooked up receiver to new HD tv and not what input source or settings to use??
Hi, it's a general process to connect any receiver to a HD TV.
Things You'll Need:
* HD television
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Instructions
Tips & Warnings
Hope it helps.
Good luck..
Feb 23, 2011 | Kenwood VR-406 Receiver
OTA HDTV ONLY
just do these connect AV output from your dvd player to AV input in your TV.
Jun 09, 2009 | RCA 27F650T 27" TV
Installed memorex mvd2042 dvd player, receive message "root"
Aha. I just found a solution. Press DVD menu on the lower left.
Dec 29, 2008 | Memorex MVD2042 DVD Player
Novice installing HDTV(Samsung),DVD(Sony) no pic on TV
Purchased a newer HDMI DVD player,(Sony)as well as found that I do need the video cables.Also found that I need to change the input to component on the DVD player by using a regular coxial to at least get a display from the DVD player had I kept the older one.
Oct 08, 2008 | Televison & Video
Trying to connect sony dvd player to hdtv
You will need some cables first. It's really not that difficult once you know what each cable does.
Since you're only connecting from the DVD player to a receiver, this should be simple.
There are 4 solutions depending on what cables you have.
Composite - Yellow, Red, and White ended connectors.
S-Video - Black 4-pin connectors.
Component - Green, Blue, Red and sometimes extra Red, White for audio.
HDMI - heavy cable with a wide/flat connector.
Composite connection - Connect the yellow end to the yellow Video Out of the DVD player and to the DVD Video In on the receiver. Connect the Red audio connector to the Red Audio out of the DVD player, the White connector to the White Audio out of the DVD player, and then connect those to the Red and White Ins for DVD Audio on the Receiver.
S-Video Connection - This is the same as the Composite video connection, but connect the black 4-pin cable into the S-Video out of the DVD player and into the In for DVD on the back of the receiver instead of using the yellow video cable. The S-Video cable is a video only cable and uses the same audio cables (the red and white ended cables) for audio.
Component Connection - On the back of the DVD player, connect the 3 video cables that are Red to Red, Blue to Blue, and Green to Green. These will be labeled Y for Green, Cb/Pb for Blue, and Cr/Pr for Red. Connect these video cables to the inputs of the receiver the same way Y for Green, Cb/Pb for Blue, and Cr/Pr for Red. The audio connection is the same as composite and there should be a place on the DVD player that will tell you what audio is for Component. This is also the same on the back of the receiver.
HDMI Connection - This one is the easiest to connect as your audio and video are in the same cable. Plug in your HDMI cable in the back of the DVD player (there should only be one) and then to the HDMI connection for DVD on the back of the receiver.
Now...once you have your connections made, turn on your DVD player, set your receiver to DVD, and enjoy.
If your receiver does not have video inputs, you will need to run the video lines directly to your TV while the audio lines go to your receiver. This will mean you will need to set the receiver to DVD as well as change the channel of the TV to the input you have the DVD player plugged into.
I hope this helps.
May 12, 2008 | Sony DVP-NS725P DVD Player
No sound from digital cable thru AVR3200 after adding HDTV - DVD plays fine
you need a digital coax cable and then connect it to 6.1 also the digital cable type is not a coomon type so check that also
Jan 04, 2008 | Denon AVR-3200 Receiver
73 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
