Question about Alpine MRV-1507 Car Audio Amplifier
Low Voltage Post
Thank you for your time. So from reading that page you sent me, it seems to be a problem with my headunit, not the wires or amp. Correct me if i got the wrong thing from that page. If i install a new head unit would that work as well? also do you have a solution for the "low voltage" thing?lol thanks man for everythin so far
  • 631 Answers
The head unit doesn't need to be replaced. It can be repaired if the shield is open.
If the amp still give an indication of low voltage and the voltage isn't too low, the amp probably has an internal fault.
Posted on Aug 17, 2008
Unplugged my headunit to work in dash now head unit flips out but does not come on and amps dont light up
Hi, sounds like you lost your amp turn on. Look for a blue, or a blue-white wire, that is your turn on and or power antenna wire. Turn on your strreo, check the output voltage with a meter on that wire. If you have voltage, check the battery power on your amp. If you dont have power on the turn on wire, use an acc. voltage that shuts off with the key. That should do the trick.
May 01, 2015 | Car Audio & Video
How to determine if I have a Battery issue or a Charging issue with a 2003 H-D FXDXT? What should the Voltage of a "fully charged" 2 year old OEM H-D Battery be. I have a reading of 12.4/5 Volts. At a
Post by the "Owner". The "Fix" was a New Stator. (Broken Wire).
After recharging the 2.5 year old AGM battery 3 times with acceptable results each time. (13+ volts & 14.5+ Volts at high idle) Purchasing a new AGM Battery, a month & a half of "pulling my hair out, all the "great solutions posted on fixya", being stranded 3 times with a "dead battery", I took the Bike to the Shop/Trained Mechanic. Many Thanks to the Post concerning the broken copper wire & "fixya.com" for allowing me to Post. Thank You all.....
May 22, 2014 | 2003 Harley Davidson FXDXT Dyna Super...
Subs cut out when bass hits
assuming that both subwoofers are working fine: check what voltage output your headunit has (RCA output voltage) and match it to your amplifiers input sensitivity (GAIN) eg: if your headunit has 4 volt outputs then on this particular amplifier your gain knob would be completely to the left as if in the off or 0 posirion.
if u are not sure of your headunits output voltage you could check the manuals specification page or send me the barand and model number of your headunit and I will check it for u.
hope this helps. let me know if I can assist you any further.
.......andy.......
Dec 26, 2013 | Alpine MRX-M50 - Monoblock 500 Watt RMS...
Driver side low beam headlamp out. replaced bulb--no go. checked fuse-fuse ok.
Remove the new lamp
Put a volt meter black lead to the engine
for a good ground or battery grd post
Then turn on the light & probe the lamp socket
one or two wires should read battery volts &
most likely the balck wire is ground & won't drop
any voltage
If good there or compared to other light connector
go after a broken or open ground wire
Dec 01, 2012 | 2004 Volvo V70
I have a cheap VRCD400-SDU receiver I bought on ebay. Im trying to install it in an 87 samurai. I have no harness whatsoever. Not a factory one in the dash, nor the 16-pin receiver harness that attaches to...
You are correct that finding a universal harness is much like a unicorn hunt. I have been there before.
Your best bet is to bypass the harness, but use the same style female wire terminals that the wire harness holds together. I have included a link to www.mouser.com of the specific page of their catalog of these style connectors. You are looking at figure G.
http://www.mouser.com/catalog/catalogUSD/643/1514.pdf
What you will need to do, is use 18-20ga wire, solder the wire to these terminals & heat shrink them. You will then be able to individually connect each wire terminal & wire to each male pin on the headunit. It will be important to strain relief so they stay connected. Make sure you are not shorting any pins together, as this can cause damage.
In all honesty, i would look for a new headunit if this is a cheapo. The time & money spent for this solution can easily go awry when installed in a car. Installing the headunit back into the dash could knock them out, a bumpy road, etc.... Your headache may be much smaller with a different unit. But then again, like yourself, its what you do for fun.
Mar 17, 2011 | Car Audio & Video
Got a problem with my car amp.Everything was working fine until 2day.Amp goes in to protection mode.Jumps from power to protection indicator every i would say 3 seconds and each time it goes in to...
Ok check the remote wire running from the headunit to the amp should be giving v12 feed whiles headunit is on.
check or change grounding position.
take cover off the amp as the circuit may be over heating.
Sep 22, 2010 | Car Audio & Video
I have a 99 BMW. Head lights have 2 wires, 1
Do have access to a volt meter or an old school 12volt test light? Turn the light on with the light harness loose from the light assy. and test each wire to the frame or the negative post of the battery. The wire that has voltage or will light the light is your 12v pos.You can make a test light using a old 1157 tail light bulb, using 2 wires tape one wire to the base metal and the other, hold on the silver bulb tip with one hand, put one end of the wire on the batt. neg. post and use the other wire to search for the voltage in the light harness, voltage will light the bulb..
Dec 27, 2009 | 1999 BMW 323 Series
No spark on zxr750j2
Hi and welcome to FixYa,
Initially, when starting check for the presence or absence of :
  • +12 on the red wires of the ignition coil;
  • very high pulsating voltage on the black & green wires from the CDI to the other terminals of the coils;
  • very low pulsating voltage (0.5VAC) between the green & black wires from pulser coil;
  • +12 on the brown wire of the CDI.
Additionally, try starting with the clutch lever pulled in and/or the side stand folded up.
Postback results of tests.
Good luck and thank you for using FixYa.
May 24, 2009 | 2008 Triumph Street triple
Car Audio & Video Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
