INK LEAKAGE ON PRINTS - Office Equipment & Supplies
    Problem Solver:
  • 6 Answers
I need more specific info. Where is the ink: on one side only or all across the page. On the top only or all down the page. Does it look like smudges or spatter.
Posted on Aug 17, 2008
I got same problem , the black ink head get dirty after 1st print
Posted on Sep 02, 2008
HP Designjet 110 inconsistent printing of magenta
>Check ISS pumping, >Check ISS tubes is there air gap?>Check cartridge bag broken in side?>Check for leakage at cartridge bank & carriage assm.>Do the following force priming to fil ink in tubes as well as in print heads:****Hold the power button down and press the cancel button three times and the resume button three times.****Switch Off the printer and then On again in order to start the priming of the ink supply tubes.
Jan 04, 2012 | HP DesignJet 110 Plus NR InkJet Printer
Have installed new ink cartridge. still getting low inw warning
The low ink cartridge warning is nothing to worry about. If it prints, it prints. Most modern printer cartridges have a chip on it which lets the printer know when the ink is low. When you run low on ink, it sends a message to the printer which sends a message to the computer telling you to refill the ink. The problem is that it doesn't go away once you refill the ink. It still prints, you just get a notification whenever you want to print. You can still use it up until that new cartridge runs out of ink. :)
Feb 21, 2011 | Canon PIXMA MP240 All-In-One InkJet...
IP4200 leaks line of black ink on back of pages
There is a fix, design flaw as you say. You need a new ink absorber kit which includes a mylar strip so it won't happen again. What's happening is the waste ink from the purge assembly is pumped over to the center of the absorber pads and when it dries it stops the flow and it backs up thru the exit rollers.
Sep 30, 2009 | Office Equipment & Supplies
Hp c4480 prints blue instead of black
Check the print properties and verify the black ink cartridge still has ink in it.
Otherwise, you may have a bad ink cartridge. If the cartridge has not been used for a while, the ink gums up the nozzle. You can try cleaning the ink cartridge and slot with alcohol. However, new color and black cartridges may be the best solution.
May 02, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
My canon mp 150 has a warning ink refill cartridge
After so many prints the printer gives you this warning because it is possible that the waste ink pads (that collect any spilt ink in the bottom of the printer) are full. You have two options. You can either reset the waste ink counter and the printer will run but might get some ink leakage if it has had a lot of use or replace the pad and reset the counter.
A waste ink kit for this printer is Canon part number QY5-0149-000. A quick search on the will get you the part for about £5. Too fit it you will need to take the printer apart but that is easy with a service manual from here: http://www.tradebit.com/filedetail.php/4589462-canon-pixma-mp150-printer-service-manual The manual will also tell you how to reset the waste counter.
Hope that helps.
Nov 07, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Black ink leaking from bottom of printer!
There is a ink resovier where the cartridges are cleaned of excess ink after a job. That gets filled over time and gives you the leakage described. Very messes job to clean it.
Sep 10, 2017 | HP Photosmart 3310 Printer
Cannon multipass 390 print problems
I have the exact same problem, cleaned heads, replaced cartridge, nothing prints, no ink at all no colors or black.
May 08, 2008 | Canon MultiPASS MP370 All-In-One InkJet...
Replaced Original Black Ink Cartridge but still bad low ink prints and low ink indicator lit.
Sounds like the print head is dirty take some rubbing alcohol and qtip and clean the print head.
Dec 03, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Prints without any errors but no ink on the paper.
if you have new print head assembly and cartridges, and waited for flow, and the printer is MECHANICALLY sound (not dropped or G-force damaged), then all that is left is improper cartridge installation. You may not have the cartridges fully inserted/, or maybe they are not PROPERLY inserted. Look for a snap when in place (and no wiggle). I suspect this is your problem, because one symptom you mention, ink accumulation INSIDE the head/cartridge cradle, is VERY rare -unless the cartridge is inserted improperly. The cartridges/head assemblies have VERY good seals to prevent leakage. Unless the o-rings/seals are damaged, leakage outside the seal just does not happen at all, normally.
*New head/cartridge installs can take several hours -sometimes even a day in cold weather, for small iP90-like printers to saturate the heads -and print.
Oct 08, 2007 | Canon PIXMA iP90 Mobile Printer
378 people viewed this question
jasbo
jasbo
