Question about Refrigerators
Frigidaire Fridge FRS23HF5A
I just recently moved with my fridge. and it worked perfectlyfine before hauling it to the new place. I moved it in last night and put all of my cold items in there and filled up ice trays and put them in the freezer. THe ice trays have not frozen at all, and my food is thawing out. and the milk is not very cold at all.
I know that the freezer and the fridge temps are both as cold as I can put them. and everytime I open the door I can hear a fan running on the inside. I dont here the compressor at the bottom of the fridge running though.
Is there anything that I can do to try to fix this?
Thank you!!!!!
Jessica Walker
  • 473 Answers
SOURCE: New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Posted on Oct 07, 2007
  • 868 Answers
SOURCE: We have a Whirlpool gb22dk
1st.Check the freezer door gasket for any place it maybe torn or not making a 100% seal when you close the door.That would make temperature drop. 2nd.take off bottom kick plate so you can look under the refrigerator.Using a flashlight make sure there is not alot of lint / dust stuck on the coils .If there is remove it carefully and you will see temperature lower. PLEAS RATE THIS!
Posted on Jun 09, 2008
  • 331 Answers
SOURCE: model# 596.58642891 freezer side thawed first and
I humbly disagree with Sea Breeze. We know the thermostat (cold control) is working because the fans are running and the compressor is hot to the touch. So we're getting power to the compressor. Now, only TWO things will keep the compressor from firing up when it has power supplied to it.
1.) A failed Starter. (that box connected to the left side of the compressor.)
2.) A failed compressor.
Then there are two things that'll take out the starter.
1.) Just a mechanical failure within the starter (blown ceramic disk). Note ---> You can normally tell if a starter is bad just by taking it off the compressor and shaking it. If it sounds like it has pebbles in it... it's bad. If it's solid, it's probably good.
2.) If the compressor locks up or fails, the starter is not far behind.
This Kenmore is made by Frigidaire. My experience with these is that 90% of the time, the compressor has locked up. You said you had access to the compressor... if it's made by Tecumseh (you'll see a blue Indian head logo on the sticker) I can almost guarantee it's failed. (Frigidaire is now putting Embraco compressors in their machines because Tecumseh was such a terrible one.)
All that to say this... you may decide that you want to replace the starter (if it's bad/rattling). If you do, go here and look at parts # 211 & 251 on the diagram... you'll need these. So, all-in-all, it'd cost around $20 plus shipping to replace the starter. If the new starter works? Great! You fell within the 10%... (almost like winning the lottery!) If the starter doesn't work, all you're out is the $20.
Good luck,
Posted on Mar 28, 2009
  • 13 Answers
SOURCE: freezer works, fridge doesn't cool
Probably excessive ice in the condensor. Likely defrost thermostat or defrost heater problem.
What happens is excessive ice keeps airflow from the refrigerator part of the unit.
Posted on Jul 09, 2009
  • 1606 Answers
SOURCE: Ge Profile fridge
Pull the refrig out from the wall , and remove the rear panel . Touch the compressor and feel if its hot or running . If the compressor is cool , then the main control board is bad ( since the compressor isn't running ) . If you can solder , you can repair the board (another paragraph ) . If the compressor is warm , then you could have a thermistor or 2 bad . This would have to be checked by a technician , unless you know how to get into the diagnostics procedure . Also , see if the compressor cooling fan is working and the black squirl cage is clean of dust .
Posted on Sep 06, 2009
Testimonial: "Quick, professional response."
Recently got 2nd hand Amana side by side model XRSS687BB. Compressor stops when closing fridge door. Freezer working as long as fridge door remains open. Fridge damper closed and won't open though it
I have went through something like this before, the serviceman told me it was in fact a compressor issue. Do you hear some kind of buzzing noise? Is it extremely hot? Then it's a compressor issue. They are pretty expensive to have replaced, would recommend to purchase a different brand. I had the same problems as Frigidaire. I had the compressor replaced twice during a time period of 2 years. It went out a third time and it was out of warranty and they told me that the compressor didn't receive any kind of warranty gain for itself and the company shortened the warranty of the compressor because of the issues they had with them. Since they were aftermarket ones, didn't apply to the original warranty. If you continue to have issues with this brand, please research the brand integrity online before you make another bad investment. I paid more for the new brand but it lasted longer than 9 months. The next fridge that I bought was older and used but lasted 5 years, so I stuck to that brand and it paid dividends stop far.
Dec 18, 2014 | Amana Refrigerators
Frigidaire refrigerator flashing
Check if the bulb holder is not loose.
Jul 29, 2013 | Refrigerators
Breaker trips when Kenmore refridgerator is plugged in
That is Not a good thing.
I will assume the breaker trips when the motor on the fridge kicks in.
How old are the breakers and how old is the fridge? If either is approaching 20 years, I would call an electrician for the breakers and/or go to the wholesale fridge warehouse for a new fridge..
Old fridges need to be replaced, old breakers - even more so.
There is one device that might buy you some time --- a voltage regulator. But don't hold your breath. Rather, read this paper:
Ultimately you lef t of many details -- like did you just move your old fridge into a new place? Or did the fridge work great for x amount of years and then this started happening? Lots of stuff to know here.
As an example: One time a mouse chewed my wires just enough to cause trouble, but not enough to clue my meter - the meter said the voltage was OK. It can get complicated.
NTL, I doubt you went very long without a fridge.
Oct 02, 2012 | Frigidaire 20.6 cu. ft. Top Freezer...
My fridge has stoped cooling frezzer stoped last week dumped the ice out move frome wall started working agin for a week than stoped working yesterday WTF is was made in 06 is the compressure out or what...
you moved the fridge out from the wall and it started running again?try opening the fridge door and tap on the fridge control and see if it starts up.i,ve gone into houses and then the woman tells me when the fridge shuts down she hits the side and it runs's the control,this could be your problem also,when you moved the fridge the control could have kicked back on.let me know what you find
Jan 13, 2011 | Frigidaire FRS-26DR7D Side by Side...
I bought a frigidaire refigerator in March, 2007, noticed recently it was getting warmer inside. Pulled it out to clean coils and saw a date stamped on back of fridge with the words fix 06 beside it. What...
It should be OK and not 06 as you mentioned. Please have a look again and reconfirm it. It says that the unit is tested and in good working condition a certification from the final check point of the unit at the factory.
The failure of cooling is due to refrigerant leak and I wonder whether you have moved the refrigerator from the original place of installation. During moving the fridge the condenser coil would have been touched and resulted in refrigerant leak and resulting in poor cooling or no cooling at all. This also would have taken place over a period of time and not instantly on a fine morning. By recharging the refrigerant your unit should cool perfectly.
Jul 14, 2009 | Refrigerators
Fridge making burbling noises
This could be two things, i have had fridges get louder with age, its the refrigerant returning to the compressor after condensing, but it could also be because its low on refrigerant. If the fridge is cooling normally and not having an issue getting cold then i would just leave it alone until it has further issues. Most places don't service them anymore, if your really really lucky you might find an appliance repair place that can send a tech out to check the refrigerant on the fridge, but the rule of thumb unfortunately is they are a sealed system, and if they get low its because they have a leak, and the leak is usually due to seals wearing out in the compressor, and a new compressor costs more then a new fridge!
Jan 11, 2018 | Frigidaire FRT17G4B Top Freezer...
Water and Ice Not working on Fridge!
check you water valve make sure you have power to it when the water paddle is pressed... you may have a bad water valve
Jun 26, 2008 | Frigidaire FRS26R4A Side by Side...
Frigidaire Fridge PLHS69EESS2
Could be a jammed fan or something could have moved inside to block the opening. Some units have deflectors in the openings...did one of those cover the opening on the fridge side? Did you overpack your freezer and block the air flow from there to the fridge?
Dec 29, 2007 | Frigidaire FSC23F7DSB Stainless Steel Side...
Fridge cooling 54 degrees - freezer 38 degrees and 24 degrees
Will not be the defrost timer as they have a set cycle independant of the normal cycle...unless your fridge is eletronic. Did you stand the fridge up when shifting?
Dec 10, 2007 | Frigidaire GLTF2940ES Front Load Washer
Stinky Fridge
New one on me... Never heard this one before... if ya find out post on here for the rest of us...
Aug 28, 2007 | Frigidaire FRS26H5AS Side by Side...
Refrigerators Logo
103 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
