Tape running at high speed
Tape plays at high speed(approx 2x-5x), both video and audio with auto tracking not locking in and manual tracking ineffective. In addition, there is a ratcheting noise due to a toothed cam under the casette carriage not meshing correctly with its mating toothed wheel but not due to damaged teeth on either component. The cam appears to be pushed towards the wheel but is lightly spring loaded against it and basically bounce out of mesh from time to time. This occurs on both reccord and playback modes.
Any suggestions would be welcomed.
  • Noexpert Aug 19, 2008
    Cleaning the drive capstan idler has made no difference. I
    suspect the problem may be electronic rather than mechanical as it
    developed overnight and gave no prior indication of slippage. The
    ratcheting noise developed at the same time as the overspeed problem.
    You are absolutely right that repair is not fiscally sensible.
    SONY has two options on this unit: the first is an exchange
    program with an identical or equivalent unit for $280+ -- you can
    get a good DVD/VHS combo with digital tuner for that! the second
    is a repair at a fixed rate of $80 -- this would buy a simple
    DVD/VHS combo without tuner or possibly a couple of older VHS
    units! I guess this one is headed for recycling - I've had
    a good fifteen years out of it!
  • 5,568 Answers
The tape speed is controlled by a pinchroller arrangement; one rubber covered idler, and a metal drive roller with the tape between them.
There is tension of the take-up reel that will pull the tape faster than it would normally travel if the described rollers are doing what they should.
You might try removing the rubber idler (normally one small Phillips) and stripping the surface with something fairly aggressive such as lighter fluid or alcohol and an old rag.
If you get a good bit of black deposits, that may be enough to restore some tackiness to it and therefore function.
If you are handy and curious, you can take a cartridge with problems, remove the tape from the reels, cut out most of the closed side of the cassette, put a rubber band between the two empty reels and make a test cartridge that might let you see what function the various gears perform.
I still have one so prepared in a box of other homemade fixtures I used years ago.
A box I didn't bother to unpack since the repair of these is no longer fiscally sensible.
Posted on Aug 18, 2008
  • Steve Allison
    Steve Allison Aug 19, 2008
    One last comment; although repairing old equipment even if not exactly obsolete may seem futile, the later stuff is far less durable and the replacements I have bought in the last years have failed often with 2-3 years.
    A friend of mine who exclusively repaired TVs and VCRs warned me against disposing of the older units as the newer ones were far less reliable and much more difficult to service and keep running.
    Changes in manufacturing and origins (Japan > China) has brought a crop of inferior stuff which although cheap, isn't worth even the lower price we pay.
    If you can find someone retired that likes to keep their hand in, you might want to have your current unit repaired (if it is not a component no longer available) and wrap it carefully to stash and then use when the new one fails.
    Many of these problems are caused by the decay of certain very common and inexpensive components dependent on chemicals in the power supply of units.
    Any competent tech with a few necessary instruments can locate these and replace them at minimal cost.
    I would suggest that if you buy a new one, and don't currently know someone who might look at it for you, I would pack it up and keep it in case you do eventually find someone.
Only one speed playing 3 3/4
Does your machine have a pitch control? Is it on and the knob turned too far to the right? Also, do you have a 2X high speed dub switch? Is this a FACTORY tape that you are playing or is it your own formerly blank cassette?
Oct 23, 2015 | Audio Players & Recorders
Audio noise on some, but not all VHS tapes
First thing i would say is go for the HI-FI audio would go in and out and pop etc. Adjusting the tracking would bring in the audio, but sometimes the video would get fuzzy. Get the picture right and the audio goes out. Switch to Linear (mono on some VCRs) and the audio should be fine.
Finally if this doesn't solve your problem then i would suggest you to give it to repair and they will fix it.
Goodluck..
Feb 16, 2008 | Panasonic DMR-ES46VS DVD Recorder/VCR
Fostex e 16 tape warping
I can't speak to the specifics of the machine's mechanics but I have been into audio (hobby) and and a Service Engineer on data tape storage (from 7- and 9-track 1/2" open reel running at 200 inches per second and capable of start/stopping in .6" to 100-plus track 1/2" digital data cartridge tape) for over 32 years so I know a few things about tape media handling.
Squeezing 16 audio tracks into 1/2" of media doesn't leave much room for error in the analog world. The manual I found at retrevo.com discusses making electrical Play and Record level adjustments using a calibrated Magnetic Reference Tape BUT they don't discuss head azimuth setting or adjustment which could affect high frequency response and crosstalk between adjacent channels.
You could check for audible crosstalk by recording alternate (even or odd) tracks at a fairly high level and then playing back only the others. The crosstalk spec is only 50dB at 1kHz so you can't expect total silence but it should be on par with the residual noise of the tape without Noise Reduction engaged and should be fairly uniform across the tape.
Physical deformation of the tape will also plague any machine with narrow tracks. If the edges flutter you are definitely losing amplitude on the outer tracks. The tape itself could also be experiencing stresses due to uneven rewind tension that would result in an uneven 'pack' within the reel. If the appearance of the tape within the reel flanges after play or rewind is NOT uniform there may be a physical reasons for it. If any of the tape wrap is exposing edges of the tape you have to be extra careful to handle the reel without compressing the flanges. A perfectly wound tape would have a uniform wrap appearance and when viewed on edge there would be clearance between the tape and both flanges. Any contact with the flanges will wear or deform that edge of the tape.
If the reel flange is warped sufficiently it will contact the tape every revolution, too, and during high speed transport you'll see and hear it.
Physical Tracking within the tape path must be perfect. With a high powered lamp and no tape loaded examine the heads. There should be no visibly worn grooves in their surfaces that would alter the way the tape passes over them. Then load a new blank tape and view how the tape passes over the heads, looking for any deviation from perfect flat alignment within the tape path. It may help to place a piece of white paper behind the area so you can see the reflection of the light off the tape. Any variation indicates less-than-perfect tape-to-head contact which would result in loss of treble, crosstalk or dropouts. Repeat this with a previously recorded tape. If it's different then we need to suspect machine-induced tape problems.
Proper tensioning of the tape during both play and rewind is key as you mentioned.
Head wear is also a possibility.
One thing that many people overlook is the storage of their media to ensure longevity. A reasonably constant temperature and humidity is essential as is sufficient distance from magnetic fields. Though not very convenient, storing any tape (open reel, audio cassette, video) in a 'played' state produces the most uniform tensions and pack wrap so it's the best way to avoid problems that varying temperature might cause.
If you can identify or eliminate any of these problems and add that information to this post I'm sure someone out there might be able to assist with the next steps.
Apr 22, 2010 | Audio Players & Recorders
Hl-dt-st dvdram gsa-t20n ata burn speed for cdr changes to 10x minimum automatic soon as i put a blank cdr in. i need to do slower burn Speed (4x) and i tried with different software and its always the...
Your drive doesn't support slower burning speeds unfortuately, here are the specifications for it:
Write Speed DVD+R 2.4x CLV, 4x ZCLV, 8x CAV DVD-R 2x CLV, 4x ZCLV, 8x CAV DVD+RW 2.4x, 3.3x CLV, 4x ZCLV, 8x ZCLV
(8x Speed disc: 3.3x CLV, 8x ZCLV)
DVD-RW 1x, 2x CLV, 4x, 6x ZCLV DVD-RAM 2x, 3x ZCLV, 5x PCAV(Ver.2.2) (16x Media: Not support) CD-R 10x CLV, 16x, 24x ZCLV CD-RW 4x, 10x CLV, 16x ZCLV
(High Speed: 10x CLV, Ultra Speed: 16x ZCLV, Ultra Speed plus: 16x ZCLV)
DVD+R DL 2.4x CLV, 4x ZCLV, 6x ZCLV DVD-R DL 2x CLV, 4x ZCLV, 6x ZCLV Read Speed DVD-R/RW/ROM 8x/8x/8x max. DVD-R DL 6x max. DVD-RAM (Ver.1.0/2.2) (Ver.1.0) 2x
(Ver.2.2) 2x, 3x, 5x
DVD-Video(CSS Compliant Disc) 4x max. (Single/Dual layer) DVD+R/+RW 8x/8x max. DVD+R DL 6x max. CD-R/RW/ROM 24x/24x/24x max. CD-DA (DAE) 24x max. Sustained Transfer Rate DVD-ROM 11.08 Mbytes/s (8x) max. CD-ROM 3,600 kB/s (24x) max.
Jan 28, 2009 | Computers & Internet
Recording Speed
the tascam 414 is a 4 track recording studio which uses standard cassette tapes- meaning they only play in one direction, because the tape is full. The 414 records at double speed so that recording fidelity is increased. When you have made a recording you want to mix you then dub your recording though the outputs into another standard tape recorder or whatever you have available, be it a cd recorder or your PC. So, when you listened to your recording on a standard tape player, you were not only hearing it at half speed but you were only listening to 2 of the 4 tracks. The other tracks would only be heard if you flipped the tape over, and they would be heard running backward. I would have though the 414 had a swich to allow it to also record at standard speed to but I guest it does not.
Jan 10, 2009 | Tascam Starter Pack for 4-Track Cassette...
Dubbing from VCR to DVD
Dont use xp mode. Here are the definitions:
SP is short for Standard Play. Standard play allows you to record information onto the tape the way it was intended, with no quality loss. By default, VCRs and camcorders will record your footage as standard play. On a standard VHS tape, recording footage in SP mode will yield 2 hours of video.
LP is short for Long Play. Long play allows you to record much more information at the expense of quality. It accomplishes this by reducing the speed the tape is run through the VCR. As the tape speed decreases, the quality will also decrease. You’ll notice this effect when comparing a tape recorded at LP versus one recorded at SP, especially after years of storage. The LP tape will appear more blurred, have more tracking and color issues than tapes recorded at SP. A VHS tape recorded at LP can hold roughly 4 hours of video.
EP/SLP is short for extended play. Extended play is similar to LP, but actually provides you even more recording time. EP was primarily used to document long, continuous events without the need to change video tapes every 2 hours. Due to the fact that the video is not of optimal quality, many times this setting was not used in order to preserve the quality of your footage. Tapes recorded at EP usually are the most problematic after years of storage, displaying a wide variety of tape damage symptoms including color loss, audio loss, frame skipping, and tracking issues.
Sep 02, 2017 | LG LH-C6235 System
Magnavox DVD Video Player DVD609AT
DVD609AT:
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• CD-ROM
• Compact Disc-Interactive
(CD-I)
• Compact Disc-Recordable
(CD-R)
• Digital Video Disc-Video
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
Digital
Video
Disc
12 cm
12 cm
Approx. 4 hours
(single-sided)
Approx. 8 hours
(double-sided)
Approx. 80 minutes
(single-sided)
Approx. 160 minutes
(double-sided)
20 minutes
8 cm
8 cm
(singles)
Logo
Maximum
Disc Type Contents Playback Time
Sound
and
Pictures
Audio
CD
Disc Size
Sound
74 minutes
Disc
Segments
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
• CD-ROM
(CD-I)
(CD-R)
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Photo CD
• Video CD
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
Need to play a T-160 recorded in slp at normal speed to watch
This is automatic, as the record speed can only be manipulated, not playback unless youhave that setting which I have never seen,
May 11, 2008 | Zenith VCS442 VHS VCR
Older VHS tapes play 'sped up' on S-VHS
A couple of possibilities: 1. One of the machines had a audio & tracking head alignment problem. If memory serves, tracking pulses are recorded on the bottom edge of the tape, and if one machine's head is slightly off, then these pulses aren't being picked up.
2. Do both machines have 3 play/record speeds? Many machines had SP, EP, & LP. Some didn't have EP, and if your older tapes were recorded in EP, perhaps this would cause your problem.
Both of these possibilities might be way out in left field.
Perhaps you could have a friend try your old tapes in their machine- in short, narrow down the defect. Is it the older VCR and it's recordings, or is it some goofy problem on the new one.
Lastly, you might check the audio/tracking head- see if it needs cleaning. This head is just to the right of the rotating video drum assembly.
Jan 28, 2008 | JVC HR-S3901 S-VHS VCR
Can hear crackling or spitting sound when selecting HI-FI
The "crackling" sound you describe sounds suspiciously like mis-tracking. That is: The result of the Hi-Fi heads (which are on the rotating video headwheel or drum) not exactly following the recorded tracks. Have you tried adjusting the tracking slightly? The reason this happens is that the Hi-Fi tracks are MUCH narrower than the thinnest video track (used for 6 hours per T120 tape). Tape stretches and shrinks as it ages. Video recorders wear with normal use in such a way that the tracking changes. The problem is often worse with tapes recorded at the SLP (6 hour) speed because the servo cannot correct errors as fast when the tape is moving slowly (on some machines only). Tape quality also counts...and manufacturers change their formulations without public notice. All these things can lead to "archived" tapes being lost. Solution: Use the best quality tape you can afford, not the cheapest; record at the highest possible speed. Store the tape carefully. Never use a cheap "rewinder" because they can over-tighten the tape causing wrinkles, stretches, and other kinds of damage.
Mar 08, 2006 | Zenith VRA421 VHS VCR
Televison & Video Logo
102 people viewed this question
Top Televison & Video Experts
