Normal reset procedure is to leave the television unplugged anywhere from a half hour to 24 hours depending on the model. However, you are not mentioning the use of a surge protector and if you weren't using one you may have fried your TV due to the surge.
If you have no power light on TV ,then you must have a blowed Fuse on the power supply board.
Check Fuse and check board for Bad Capacitors they will be vented or swollen on Top.
1000uf 16v 2200uf 10v 3300uf 10v.
