Question about Nikon Coolpix 5700 Digital Camera
Just a black screen, nothing through the view fnder
Just got it second hand today. turn it on and there's no image, although it clearly works and is on, just do image what so ever
    Problem Solver:
  • 9 Answers
It's a manufacturer error which Nikon will fix for free, even if you bought the camera second hand. Go to http://www.nikonusa.com/email_images/nikonusa/service_advisory/coolpix.html
I just got mine back - took about five weeks because they were out of stock on the CCD (Charge Couple Device) that they had to replace. Don't give up on the camera. It's worth having it repaired since all it will cost you is to send it to them.
Posted on Aug 21, 2008
SOURCE:
Why does the screen shut down after 1 sec while sound continues
It sounds like bad luck to me. You cannot change any settings on a TV by connecting a computer to it. In theory you can damage any monitor by setting the screen resolution of the computer higher than the monitors maximum res. The Sharp 26" has a resolution of 1366 x 768 (1080i) so (again in theory and I have never seen it happen) if you set the output to 1920 x 1024 (HD - 1080p) it can kill the screen. Perhaps this is what has happened. You will need to take it to a Sharp service centre.
May 29, 2014 | Sharp LC-26SD1E 26 in. LCD Television
Problem with canon a420 digicam
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Note that your camera will not be able to take 15 second exposures, as per the above "fix". Instead, place the camera in manual mode, turn off the flash, and take the exposures in a darkened room. This should give you a couple seconds, just enough time to open the battery door while the red and yellow lights are flashing.
Sep 21, 2009 | Canon PowerShot A420 Digital Camera
Black screen
If the light stays on for longer than about 20 seconds, try moving the lid back and forth, try positioning it in every possible way. If you get an image, even for a second, you need a new LCD cable. If nothing happens, try to get your hands on an external monitor. Plug that bad boy in, if you get the image, you need either a new LCD cable or a new LCD screen. If still nothing happens, then you probably need a new motherboard.
Before you go buying a new MB/LCD/LCD cable, which can be rather costly, open up the back and make sure the RAM is seated properly, sometimes something can jar RAM sticks loose.
P.S. DON'T FORGET TO VOTE
Apr 15, 2009 | Acer Aspire 5050-3371 Notebook
Nothing shows on viewing screen
I had something like this occur with a minot mini video camera only it locked up in the "On" setting, meaning I could see a display on the screen but could not turn it off. I suggest you look very closely for a reset hole at the bottom somewhere, a place where a safety pin or the straightened end of a paper clip could be inserted. If no Reset can be found, then try holding in the Power On/Off for as long as 90 seconds. This may clear the problem. I would also suspect no power due to low charge or no charge on the battery, battery installed incorrectly, or battery not charged up.
Dec 10, 2008 | Casio Exilim EX-S600 Digital Camera
The display image unseen and the screen is dark
display shows ,saf, memory card ,charge symbols but not the capturing image on the display screen.After some time the camera is switches off.
It is sony cyber shot DSC- T33 .
Dec 10, 2007 | Sony Cyber-Shot DSC-T33 Digital Camera
Image not visible on monitor screen
My viewing screen is black. I had successfully taken a picture, viewed it, and turned the camera off. When I turned it back on about 30 seconds later, the viewing sceen was black. I can 'take' a picure, but it comes out black. Help!
Nov 12, 2007 | Casio Exilim EX-V7 Digital Camera
Screen on Toshiba M35x S149 Laptop blank/flickers
Ok, from the beginning. Can you do a cold boot and get into the bios? (is there an image on the screen then)
Secondly, can you connect to an external monitor and see an image?
Did it do this only when it was heading in to hibernation? If so, it sounds like the power management needs some adjustment.
If there's no image on the external monitor, you may have a video/motherboard problem, or it still could be the operating system/power management.
It all depends on if you have video in bios.
Let me know.
Good luck
Nov 10, 2007 | Toshiba Satellite M35X-S349 Notebook
Black screen
whats up with blackscreen?
Oct 08, 2007 | Fuji FinePix F460 Digital Camera
Nikon Coolpix 5700 Digital Camera Logo
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
