Question about Philips HTS-6500/37 System
Stuck disk please help the audio cd i have put in wont eject it just keeps saying close
Unplug the unit !!!!! take a screw driver, take out screws, take off lid/top after that you can push the disk out by hand. then replace the parts you took off.
Posted on Aug 18, 2008
Samsung HT-100W Cinema System audio cd won't eject this model is a closed stand up system fed from the top no way to get at the mechanism if stuck
But.... it is Samsung right?
Try This
Many CD Mechazizms used to have a small button just inside the left or right side. You push the button with a paper clip or bamboo skewer stick. ejects DVD.
All cd dcd players are sealed and hard to access. Because they have a laser beam insid that could shine in your eye and blind you. Safety First
Nov 30, 2016 | Samsung Audio Players & Recorders
Eject disk
If your cd is stuck in the Bose you may have to open up the cover any manually remove this disk, make sure not to put it back in. If you are unable to remove this yourself you will need to get some one qualified to do this procedure for you. Be careful not to break anything take your time and put everything back as you took it apart.
Apr 05, 2010 | Bose Lifestyle 28 System
DVD or CD is stuck and will not eject
Pull out the power plug and leave it for a few minutes. Now plug it back it in and get ready to press EJECT or OPEN/CLOSE button continuously until it releases the disk.
Jul 10, 2009 | Sony DAV-HDX500 System
DVD Eject tray stuck
I took a stake knife from the kitchen and pried open the tray door as I hit the eject button this got it to open, I then cycled eject and close, eject close a few times and this did the trick, I even played a DVD and that worked fine also. I had the problem with the tray not opening, and the display would read OPEN when I hit eject and I could hear it trying to open. So I wanted to make sure the tray wasn't just stuck or wedged before I took the system apart and looked for sripped out plastic gears or the belt being broken. GoodLuck rayruiz10@yahoo.com
Aug 24, 2008 | Zenith XBS344 System
Cd stuck for good in bose 3-2-1 (first edition)
This is an Update to my above problem:
I've managed at last to pry open - with a huge scredriver - the very sturdy black metal clasp that holds down the cd-dvd driver onto the shaft. Now I could lift it up, see the small frontal hole that manually frees the disk tray. I stuck in a pin and at last it opened!!
But... Allas....
I could see that the "captivated" disk had very deep "skid" mark on its playable side, as if sometihng was carving into it. The same carving happened to a new disk I inserted, although it played and ejected normally - only with strange machnical noises. I think that some of the plastic cogwheels that turn or eject the disk got loose. I stuck them in and now it works fine, but I lost confidence in the machine - fearing it may stuck again or ruin my disks.
Aug 20, 2008 | Bose 3·2·1 II System
Disk wont eject
tough luck buddy, this system is sh!t. i'm on my second and have now got a similar problem with the second system. I eventually took a pen knife to the first unit to get the dvd out and then managed to get a rented dvd stuck in the machine a week later.
Aug 17, 2008 | Philips HTS-6500/37 System
Unable to eject CD's/DVD's
Dear blxriverrat,
Optical Lens of Home Theater got stuck and its sled-mechanism doesn't move, thats why you see message "please wait" If you can handle this system then open its top cover, open plastic cover on CD mechanism and push the Optical Lens inward-outward 2-3 times carefully. No need to say, 1st unplug your theater system from A/C outlet before opening top cover.
May 25, 2008 | Sony DAV-DX250 System
6 disk will not eject
you are all correct......
as are many other people with 6 disk cd changers in the same boat. check out this web site i have found at least 15 others with the same problem ( round about , but all problems relate to the 6 disk cd changer.)
the 6 disk changer is not excluse part to bose.
i recommend forcebaly removing the dam thing trying not to damage it further,( savge smashing the cd changer cassette) and trying to get a new one somewhere)
really though, you should consider surgury, - > open it and obtain spare parts to repair in the usual bodging fashion. ( that is to say any way you can ) or else return to manufacturer for remanufactured or replacement units at a cost or try to find replacement units on line such as ebay.
Dec 30, 2007 | Bose Lifestyle 12 System
Disk player door
You would need to disassemble the unit to take out both the CDs. Trying to force the disk out without opening the unit might damage it. If you are not comfortable with open it, please get someone who can actually do it for you. please revert back with the results.
Mar 22, 2007 | Bose (321GS) System
Philips HTS-6500/37 System Logo
230 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
