Question about Panasonic Microwave Ovens
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door
switch or mount trouble can be caused by slamming the door or by
opening the door while it's cooking without hitting the Stop pad first.
There
are plastic mounts inside the microwave which hold the door switches
and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes
it's a broken tab on the switch holder, allowing the switch to rotate
just out of position. This tab
can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or
handle as you try to start it. If it works or tries to work, then it's
a door switch mount or door alignment issue.
If
you or someone you know decide to look into it, we have critical
information on safety, disassembly and door switches at our site, and
our link is at our listing here on FixYa:.
If
the digital programmer circuit / controller does not get a feedback
signal from the inverter for a period of 3 seconds, the controller will
stop the cook cycle.
In this case, it's probably happening because it;'s not cooking due to a switch problem.
Posted on Aug 18, 2008
Dec 06, 2017 | Panasonic Microwave Ovens
Apr 17, 2015 | Panasonic Genius Prestige Over-the-Range...
Mar 20, 2014 | Avanti Microwave Ovens
Dec 24, 2010 | Panasonic NN-S753 Microwave Oven
Feb 17, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Dec 31, 2009 | Panasonic NN-S533 1300 Watts Microwave...
Dec 04, 2009 | Panasonic Microwave Ovens
Aug 30, 2009 | Panasonic NN-SN657SMicrowave Oven
Aug 16, 2009 | Panasonic NN-S753 Microwave Oven
161 people viewed this question
