Question about Sony Computers & Internet
I am trying to connect to the internet on my sony NR32L/S laptop and althought i have full signal it says i have low connectivity and so i cannot connect to the internet.
    President:
  • 2,961 Answers
If you mean limited connectivity, you must have the wrong password for your laptop to connect if it's secured, or you need to set your wireless connection in network connections to obtain an ip address automatically.
Posted on Aug 17, 2008
SOURCE:
I don't seem to have HDMI socket on my VGN-NR32L Laptop. Is there a different cable i can use to connect it to my tv??
yes you can use other alternatives such as vga. the quality shouldnt be that bad. however vga doesnt come with sounds. make sure you have 3.5mm jack cables to connect to your TV RCA
Oct 17, 2013 | Sony Vaio VGN NR32L Laptop Universal AC...
My Sony Bravia HDTV 3D Internet ready will connect to Internet but will not stream a movie ?
Chech the setup instructiond once again for this type of connection. If you cannot get a signal connect the RJ45 internet cable to a laptop to see if you can stream on that device. If no, then check to see if you can actually access the internet, could be a bad patch cable. If you can access the internet and stream on the laptop then it can be a bad RJ45 input sloth in the TV audio visual board. It would need to be replaced. Do this one step at a time. Finally if you cannot stream on the laptop or the TV , this could be a low signal data stream provided by your ISP (Internet Service Provider).
Good Luck Ed Pinero
Feb 03, 2013 | Sony KDL40HX800 FlatPanel TVs 40 3Dready...
How do you change limited internet access to full access
Limited access usually means you have full access to your network through your hotspot, but the hotspot is not connected to the internet or it cannot get a signal.
Sep 25, 2012 | Dell Inspiron 1525 Laptop
Can anyone advise me please, my acer 4220 says I'm connected to my wifi with full signal but when I try and start the Internet it won't connect.
Possibly a router issue. It shows the connection but it must be completed through the manufacture website.
Aug 27, 2012 | Acer 4220-2346 Notebook
Internet/network problems
Connecting the laptop to your network using a network cable, does this solve your Internet problems?
Does this works without the Internet connection dropping out?
If the wireless connection has a low signal, try positioning the wireless router or the laptop to get a better signal strength.
Also try reinstalling your wireless driver.
Jun 20, 2009 | HP Pavilion dv6000z Notebook
Can't connect to internet since purchasing wrt100.
What is your laptop name, model#?
All "wireless" laptops have software that can "scan" for , and "repair" wireless connections. Bottom right corner, do you have a pix [picture] of a monitor ( with what looks like a 'radar' signal coming out ? ) right click mouse and you should see a menu, left mouse click " repair " and follow directions.
that you loose the signal after 3 ft. could suggest that your antenna is not connected right, that the coil ( that makes up the antenna ) is 'opened' or that you did not configure the wireless part of the router.
May 22, 2009 | Linksys RangePlus WRT100 Wireless Router
Pc setting for sony bravia
'Unsupported Signal' Error indicates that TV is accepting the signals for Video but not able to display because resolution doesn't matches. Else the message would be 'No Signal'.
Follow the steps-
NOTE- Make sure cable is 15 pin(at both ends) VGA cable, working fine between PC & Monitor.
1.The standard resolution of laptop(any) which would support is 1024*768.
2. Toggle the display output from Laptop Fn Keys depending on Laptop Brand.
3. Connect the cable after settings made.
Also PC Settings will not be highlighted until connection is made.
Jan 20, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Wireless router dynamode
areejshaukat,
if ur laptop detect full signal from ur router, click on the signal and let ur laptop connect to the signal..coz even ur laptop detect the signal,it doesnt auto connect,so u hve to connect it manually..
Apr 07, 2008 | Computers & Internet
MacBook Internet connection
ok call me or I can post for you. I know what your problem is. But i need to know what model netopia router you have. Kepp in touch
Thank you
Jason
Feb 09, 2008 | Apple MacBook Pro Laptop Computer with...
Computers & Internet Logo
35 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
