Not charging happens due to some problem in the charging IC and Componenets(resistrs) related to charging in the PCB board of the mobile.Better contact the service centre.It will cost less only.
First Option:Please change The Phone Bettery and charger and check The check The Phone charging IF Charging Problem will Not Solved So Secend Option:Your Phone charging IC Fault SO Please change charging IC And charging Problem will SOlved
use good charger... check charging pin on charging connector... check contact of charger connector to charger interface... if charger IC is the problem/damage pre-heat/replace...
Dear Friend,
I hope this will help you..
Your Light problem may be Caused Due to Water Damage(NO LIGHT).Then you have to Clear your Hardware Area.
Clean Light IC
Then Check phone
Still Problem Exist
Change Light IC
You can Repair Click here
(NB:Changing Light IC is Better to do by a Professional. Improper handling may lead to total Damage. )
IF THIS HELPED YOU in any way DO RATE ME...
Thanks For Using FixYa
