Question about Mitsubishi VS-50605 50" Rear Projection Television
Mitusbishi vs 5041
We moved the tv before the move it worked fine after the move it wouldn't turn on . when I push the power button I hear a click like it is trying to turn on but no picture no sound any help would be greatly appreciated
Thankyou rob
  • 927 Answers
Good Day, rob;
More than likely you have CRT coolant (fuild) on the board(s). Check this by removing the TV's speaker grill, the small panel and look for the fluid using a bright light. It's not always easy to see, if fluid is found remove it with acetone and use heavy plastic and drape loosely over the board in the front. Always remove POWER from TV BEFORE ATTEMPTING ANY SERVICE. Good Luck, big IRISH.
Posted on Aug 30, 2008
What's the matter with my Mitsubishi Big Screen Tv Model VS-5041?
just re-read the trouble-shooting section of your owners manual and check the setup on your remote
May 26, 2013 | Mitsubishi VS-5043 50" Rear Projection...
On our mitsubuishi vs-5041 50 inch there is a black box aroung the picture of the tv. I dont have the remote, so how do i get the television picture back?
Hello.
You can use buttons that are located in front of the TV as well.
Press "menu" button and locate "picture" or "video submenu. You can use some buttons as directional ( they have arrows that indicate where you can move highlighter on menu). To choose option you can press "Select/enter" button.
More info in your TV owner's manual.
Regards.
Russ.
Dec 01, 2010 | Mitsubishi Televison & Video
Sylvania 6842THG won't turn on. the tv red light displays when you push the power button you hear a click and then 5 - 10 seconds it goes back off
I have been having the same issue. I unplug the TV for 10 minutes and it usually works fine. I moves all of my A/V plugs to a single power strip and that helped a lot. Since then, the TV went into protection mode only once in 2 weeks. Next, I will use a power strip that includes the cable protection.
Dec 12, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Mitsubishi vs-5041 -after a few hours on, the tv goes black
Get the projection bulb checked if fine its something internal in your tv but i think you need new bulb
Aug 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
TV wont power up
lose connection is a common problem of tv, try to resolder but be careful of short circuit ,
Oct 14, 2008 | Mitsubishi VS-4544 45" TV
Mitsubishi VS-5041 (TV turns on but no pic or sound)
Your problem is one and or 2 differant problems. The power regulator could have went bad because of the convergence IC have shorted. Seen this a thousand(easy that!)Times. All parts in this set are soldered in and are not user serviceable. look in your owners manual or call 800-332-2119 to get an authorized servicer to come and look at your problem . I wish i could tell you what to replace but theres the Extreme Hi voltage inside these sets even when they are not plugged in .. Good Luck
Jun 16, 2006 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
88 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
