I need to replace the power connector in my pavilion dv9608nr notebook by hp. the number stamped on it is 78pbb-90w
    Genius:
  • 1,689 Answers
Hi Vinman, the DV9600 series pavillion laptops mostly uses the same type of power adapter. these adapters can be purchased in local computer shops, or you may check on Radioshack, walmart, bestbuy or circuit city whoever is the nearest. if possible, bring the broken one with you so that you can personally compaer if you will get an original part, or a compatible part.
hope this helps.
Posted on Aug 17, 2008
Jkjjl n klk nmk, klll
Replace your computer's keyboard, because the current keyboard is not working correctly: JKJLL N KLK MNK, KLL.
Apr 01, 2011 | HQRP 90W Laptop/Notebook AC...
I recently got this laptop from someone who did not have the power supply with it. Can anyone tell me what the required power supply must output? I really don't want to fry this computer, so I want to make...
You need a charger with this features: 90W Laptop AC Adapter / Charger for HP Pavilion DV5-1125NR / DV5-1127CL Replacement
Diameter : 5.0 mm x 7.4 mm
Input Volt Type : AC
Input Volt: 110-220V (Worldwide Use)
Output Ampere : 4.74A
Output Power : 90 Watt
Output Volt : 19V
You can buy one at:
http://www.buy.com/prod/90w-laptop-ac-adapter-charger-for-hp-pavilion-dv5-1125nr-dv5-1127cl/q/loc/101/215845345.html
for $19.89 including shipping.
If this was helpful, please rate me.
Thank you
Jan 13, 2011 | HP Pavilion dv5-1125nr Notebook
I have a hp pavilion dv6500 notebook pc which is having problems holding a charge. I recently replaced the power adapter with a 65 Watt power adapter and same problem. Not sure the wattage of the original...
start with removing the Microsoft ACPI Compliant Control Method Battery from device manager. Right click my computer > manage > device manager. right click unistall the Microsoft ACPI Compliant Control Method Battery.
If that doesn't work look for a BIOS update on the HP website. Known issue with this series.
Mar 12, 2010 | HP Computers & Internet
Can this HP Pavilion DV9000 adapter fit Presario V3000 laptop
just see it from http://www.udtek.com/hp-pavilion-dv9000-ac-adapter-90w-185v-49a-p-2970.html.may this is good for you.
Jan 15, 2010 | 2wire (1000-000005-002) 802.11g/b Wireless...
Laptop won't power up without battery, needs 135W adapter
The ASUS power adapter is below spec and it may damage the adapter because the HP is drawing 45 W more power than it can deliver and will cause it to overheat.
The 17" HP requires 18.5 or 19 volts depending upon the model of the HP laptop (check the power requirements on the label on the bottom of the laptop). If the ASUS adapter doesn't deliver this voltage, it most likely won't power up the HP laptop.
Use the power supply/adapter from the other 15" HP. If this HP's adapter has a voltage output of 19 volts and the 17" laptop requires 18.5 volts, don't worry a voltage difference of 0.5 volts, the only problem is whether the power plug will fit into the power socket of the 17" HP laptop.
Oct 28, 2009 | HP Pavilion zd7020US Notebook
Power connector
no problem, you mentioned it was the power connector right? the 78pbb.
Aug 17, 2008 | Computers & Internet
No power
All lights come on HP Pavilion dv1000 but will not boot. looked at motherboard and by power connector there is a blown part the number on the board shows PD27. I need to know what thhe part is or a schematic showing
Jun 23, 2008 | HP Pavilion dv1000 Notebook
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
