Question about Cobra 29 LTD CB Radio
I have just bought a cobra 29 ltd classic with a scanner ant and it worked befor on the turck it was on but now that iv installed it on my truck im not able to talk to other nor hear them
    Problem Solver:
  • 6 Answers
Sounds like a mic problem if a wire is broken in the mic it will not let you receive or transmit common..or not to common an audio chip...
Posted on Aug 19, 2008
SOURCE:
Road noise
You will need to install a noise filter, you are getting interference from the Alternator in your vehicle.
Jun 19, 2010 | Cobra 29 LTD CB Radio
Cobra 29 LTD Bluetooth
You got your radio peaked? Most likely, however, the pot for the antenna warning indicator is VR6. I always check that after peaking a radio.
Jul 28, 2009 | Cobra 29 LTD CB Radio
I have a cobra 29 nw ltd classic i cannot hear or be heared
Start with the antenna that you have hooked to it, is it grounded, is the coax in good shape, is the connector in good shape. stuff like that.
Jun 14, 2009 | Cobra 29 LTD CB Radio
Cobra 29 ltd classic ant light
Your SWR is probably NOT fine. You need to use an external meter if you have had work done to the radio. Especially if you have had a swing mod done to the radio. When you do this, the dead key of the radio is lower then the calibration knob on the radio can adjust for. It will always come up lower then it actually is.
Your radio might have been fine before the work was done on it because it was putting out very little power. Now you are most likely putting out 50 watts or more. Big jump from 4 watts.
When your raise the power in a radio, you will notice more when the antenna is not properly tuned.
In most cases with a stock CB, even when the antenna is not even near tuned, you will get a reading less then 1.5 anyway.
the more power you put out, the more important it is to have a good match.
But an external SWR meter, and check it. be careful if the ANT light is on.
You might also want to check your coax, connections to it, and your antenna for anything wrong.
Apr 22, 2009 | Cobra 29 LTD CB Radio
Cobra 29 LTD Classic not transmitting or receiving
ant. light should only come on if you have a high vswr a bad thing did you check that cb/pa switch is set to cb check your swr this is not a good place to mount ant. as it is close to metal of back of cab
Dec 20, 2008 | Cobra 29 LTD CB Radio
As I understand from a tech friend of mine, most truck beds are not grounded well enough. Perhaps you could borrow/purchase a magnet mount antenna and locate it on the roof, for testing. Then you would have it narrowed down to the location.
Dec 05, 2008 | Cobra 29 LTD CB Radio
Cobra 29 issues
Check D23 and D28. They are polarity protection diodes. It could also be the power knob.
Nov 09, 2008 | Cobra 29 LTD CB Radio
Cobra 29 LTD CB Radio Logo
174 people viewed this question
Top Cobra Radio Communications Experts
Steve Allison
Steve Allison
Chris
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
