Mitsubishi VS 5047. Won't turn on. When the on switch is pushed it immediately turns itself off.
I had just put in about $500 worth of work into this TV to clean the color tubes of bacteria and other miscellaneous problems - They kept my TV for 3 months before bringing it back. It worked for 2 days and then everything went green, so they came back and took it for another 30 days before bringing it back.
This new problem could have been anything as simple as a tube to a circuitry problem. We decided to junk this Mitsubishi product. I have a 30 year old Curtis Mathis TV that I've never had any problems with (that's 3 times the age of the Mitsubishi).
We've opted for a new 50-inch Panasonic Plasma with the anti burn in technology. I will not buy another Mitsubishi product, or a rear projection TV of any brand after this experience.
Posted on Aug 24, 2008
Mitsubishi projection TV model VS-5047 won't turn on
No. It is shutting itself off after it finds something is not right in circuitry.
Apr 14, 2010 | Televison & Video
Mitsubishi VS-45607 turns off immediately when I try to power up
STK ICS replace Both of them STK393-570 big black ICs will have STK on them Call mats for parts 1-800-628-1118
Dec 20, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Where can I purchse new lens/lamps at for my Mitsubishi vs 5047?
Is this a CRT (picture tube) or LCD, DLP projetion set. DLP and LCD are lamp driven CRT have three picture tubes (red green and blue). You can tell by looking at the back pof the set if you see the glow of white light than it's a LCD or DLP. Lamps can be purchased at "bluestar international" ($100-$400) (google it) and CRT's are not worth replacing (over $300 each_)
Sep 20, 2009 | Mitsubishi VS-5047 50" Rear Projection...
Tv shuts off immediately
check first for the contact point of your control panel button maybe the tact switch is shoted specially when your always using remote control for function operation.second check power supply for leak capacitor or change in value,check also the photo coupler for leak test or change in actual.
Aug 01, 2009 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi VS-5071 rear projection turns on, has audio but no video
That is a VZ3 chassis, similar to Mitsubishi models Ts-4545, Ts-5045, Ts-5545, Vs-4543, Vs-4544, Vs-5043, Vs-5044, Vs-5047, Vs-6043, Vs-6047 and has common failures in the vertical circuit, specifically vert Ic401 which is a La7845 which is usually caused by defective C402 100uf 50v and/or open 1.2 ohm 2 watt R510 next to FBT.
If not that check C268 off Q215 on signal board 22mf/50v and Ic200 on signal module Cxa2025s. However the vertical failure is more likely.
Bill
Sep 10, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi Big Screen VS-45607
probaly bad wiring or shorts in the wires or something is intefearing with your tv if it is wiring it might be a fire hazard
Feb 13, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Tv powers on, then switches off immediately
check out ctechnicians.com and find error codes
Oct 07, 2007 | Mitsubishi VS-60607 TV
Television Problem
First off can you answer this:Is it possible to hook up my Mitsubishi 60" Gold rear projection tv (with Picture in a Picture capabilities) to my "Direct TV DVR", Phillips AV receiver and Phillips DVD player so I can receive picture in pictures of diferent channels i want to view of my "Direct TV" satellite provider. If so I would be glad to pay you for the easy to follow directions and drawings of the possible solution to my problem.
Sep 20, 2007 | Mitsubishi VS-5047 50" Rear Projection...
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
