The main bus on my behringer 2222 mixer has gone. nothing patched to the main bus comes up on the main vu meter, and only a feint distorted noise comes out of the headhones when the main bus is turned up to full. feint bleed from the fx & aux sends can be heard. what's wrong with the mixer?
  • 682 Answers
Please make all your fader down-all your rotary control at middle(12 oclock position)------all your pressed pushbuttons in up position--disconnect all inputs cables----use good new cables for outputs---bring a good mic and connect it to any channel and raise its fader up and main mix faders up and check if the problem solved check your cables and your pressed button if not better to contact a good service center.
Posted on Aug 17, 2008
How do you connect tape deck to pmp 4000
Hi, use the RCA/Phono connections for the Tape In & Out. The level will be set by the Master/Main fader. If that is not so convenient (& assuming it's a PMP4000?) there should be a "Main 2" output & connections with the level controlled separately to Main 1 via a Knob / Rotary control over to the right above the "Mono" fader... Hope that helps... Good Luck!
Jul 11, 2014 | Behringer Pmp3000 16 Channel Audio Mixer
Effects Problem! Help!
The Field Effect Transistors are overheating and causing distortion. This is an electrical malfunction and the circuit board and transformer are being compromised. If this a new unit, exchange it for a new device as the cost to repair is more than the exchange value.
Dec 17, 2013 | Behringer Xenyx QX1202USB USB Audio Mixer
Where are the Amplifier inputs on a Behringer usb 2222 mixer
If you need a better answer post again with more details. You can connect an amplifier to any of the inputs assuming it has compatible output levels. In your case I am assuming you want to connect to a power amplifier, so connect to the Main Outputs.
This mixer does not drive speakers!
Nov 10, 2012 | Behringer Xenyx 2222FX 22 Input Mixer
I have a Behringer 1002 mixer. Applying 0 dBu unbalanced to the input I need the -10/+4 control in its most sensitive position to acheive 0 db out with the main output control set at 0 dB. Is this cor
Depends on the input you are using. First you need to calibrate signal coming in with the Gain attenuation knob. Setting this prior to adjusting your channel output volume should calibrate the signal so when the channel volume knob is set to 0 and the Main volume is set to 0, the meters should indicate a true 0 reading.Not setting the Gain correctly will affect this. On the 1/4" channel inputs, you have less adjustment and may have to adjust the item you are plugging in from its source. If you are having issues with high gain, chances are it could be a cable issue, or something from the source itself.
Jun 06, 2012 | Behringer 1002 10 Input 2 Bus Mixer
Behringer ub802 mixer is buzzing even when no input when i hook my head phones into the headphone jack and main output jack
If it buzzes when you have no inputs AND no output leads connected, there is a problem with the power supply... HOWEVER if you have used UNBALANCED output cables instead of the REQUIRED TRS BALANCED output cables, it is possible the noise is being driven backwards and that is what you are hearing. Note that at full gains, there often is a tiny bit of noise, usually hiss. Also make sure the supply is powered from the SAME receptacle as the equipment this drives such as an amp or powered speakers.
Jul 18, 2011 | Behringer Eurorack Ub802 - Ultra Low-Noise...
Mixer does not sound "clean"; almost distorted
If more than one input is bad, then problem has NOTHING to do with the preamps. Check list:
1. Make sure you are using BALANCED lines everywhere... either XLR or TRS cables.
2. Make sure ALL interconnected equipment, mixers, amps, powered speakers, CD players, etc. are ALL powered from the SAME receptacle or power distribution unit.
3. Do proper setup. Select each channel PFL and set the trims so the indicator never goes into clipping, but is in the 70% range during max volume input to mics, etc..
4. During operation the sliders should be at least 50% up on used channels and the mains. Setting of levels throughout the system is important for noise free operation. Using EXCESS gain at some point results in distortion and noise. Using sliders near the bottom position results in poor signal to noise ratio.
Now re-read #2 above... and believe it. I have seen a lot of equipment blown due to ground bounce of building power. That is why the pro's run power back to their mixer from the area where the amps are powered.
Apr 28, 2011 | Behringer EURORACK UB2442FX PRO Mixer
Iam trying to make my behringerXENYX 1204fx mixer, / connect
I have trouble my new behringer xenyx 1204FX VU led dead , like new VU it must play , how to repair this unit VU light
Mar 13, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Behringer SL3242 Mixer has a noise problem.
It sounds like you have ground loops. This is noise generated by having interconnected equipment grounded at different physical locations. Especially a problem if you have a cable from your cable TV provider connected into your equipment.
Remove EVERY connection into and out of the mixer. Plug in headphones. Noise? If so, mixer needs repair. If not, re-connect equipment 1 piece at a time and assess for noise. If it slowly increases as you add connections you will need expert on-site help to fix it. If it is sudden, what was just connected is the source and steps need to be taken to lift the ground on the connection to that equipment.
Apr 15, 2009 | Behringer Audio Players & Recorders
No Volume oe sound coming out of speakers
try connecting speakers to another sound source or if you have access to a ohm meter, check impedance of speakers, should measure 4~8 ohms.
Jan 25, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
 Grubhead
Grubhead
