Question about Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
Drum turns but no heat
Purchased brand new 1 yr. ago, out of warranty. Heat stopped 1 week ago, found out vent was clogged, removed clog but still no heat.
  • 5,911 Answers
The following link explains a dryer "no heat" problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
In many cases a no heat problem is caused by poor ventilation which results in the dryer overheating to the point of failure. The common fail item is the thermal cut-out (TCO). Once it trips, it blows like a fuse and must be replaced. If you determine the TCO to be bad, it is recommended that you replace the TCO and Hi-limit thermostat at the same time (usually sold as a set).
Now if you have not cleaned your ventilation in a while (or ever at all) it is strongly recommended that you do. Replacing any failed components in a dryer with poor ventilation will eventually lead to the same problem. If you have any questions, or require addtional assistance, please let me know. I hope this helps you.
Posted on Aug 17, 2008
Trum turns but will heat dyer. Is there an internal lint filter?
bottom lower right remove panel drain if ok then lint filter inside top or lint in vent
Nov 13, 2014 | Splendide 2000S Vented Washer/Dryer
Whirlpool dryer bad heating element AGAIN
Hi Warren Fink
Try this solution to your problem
A vent clogged with lint can cause the dryer to overheat.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
Please take time to rate me
Bud
Oct 18, 2012 | Whirlpool Dryers
Dryer taking to long to dry
Overloading
1. One of the simplest problems to remedy could simply be that you are putting too many items inside the machine during the drying cycle. Avoid overloading your dryer, as this might cause your dryer to work extra hard to dry your clothing, extending the length of the dry cycle.
Wrong Heat Setting
2. A common issue with clothes dryers could be the wrong heat setting. Most home dryers feature several settings, from low heat settings to high heat and permanent press. Be sure the setting you choose is right for your needs. Another setting to check is the load size of your dryer. If you are drying a large amount of clothes, be sure the setting for large loads on high heat is selected. Choosing the wrong heat setting or load size can cause your clothes and linens to take longer to dry.
Lint Trap
3. One of the simplest fixes for drying issues might just be that your lint trap is clogged. Each time you use your dryer, lint will form in the trap. If the lint trap and vents are full, this could block air going into your dryer and slow down if not completely stop the drying process. After you use your dryer, remove this lint trap and empty it fully. Even if the lint trap is full, your other dryer vents might be clogged as well.
Clogged Vents
4. If your clothes are in the dryer for a long amount of time, but still not drying, the reason for this could be a clogged vent. A sign that your vent is clogged is if your clothes are warm or hot to the touch after sitting in the dryer, but still damp. To unclog your dryer vent, you may need professional assistance. This is especially necessary if your dryer vent leading out of the house is particularly long.
Heat Source
5. If the dryer is not getting enough heat to dry your clothes,something could be wrong with the heating system. After the drying cycle, touch your clothes to see if they are warm. If not, this means that the heating mechanism is malfunctioning. It will need to be repaired or replaced by a professional.
Feb 28, 2011 | GE Profile Harmony DPGT750GC Gas Dryer
AFTER DISCONECTING THE GAS FOR TILE WORK IT NEVER WOULD REHEAT
So long as its heating a little, try removing the venting, and see if there an improvement. a clogged vent will greatly reduce if not stop all heat . dont forget to check where venting exits the home outside also becomes clogged.
Now restart it - it should work.
Jul 21, 2010 | Whirlpool LER4634J Electric Dryer
No heat in dryer. This is a stacked dryer/washer combo. The dryer is electric. The drum turns and timer works but there is no heat in the dryer or exiting the vent. The washing maching beneath the dryer...
The element to heat the dryer has gone out. You removed the back of the dryer to remove lint you will need to remove the back of the dryer again to access the heating element. It is in the lower left or right hand corner (depending on model) and looks like the inside of a toaster oven small thin wires. Take the assembly out (make sure the unit is unplugged always) get the model and serial # and purchase replacement from an appliance parts house.
Good Luck hope this helped you some
Dave
Jan 23, 2010 | Dryers
Maytag Atlantis electric dryer Model
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Aug 08, 2009 | Dryers
My kenmore Elite Dryer model he3 starts but there is no heat, what is up with that and what can I do to fix it since my warranty is over.
Most dryers stop heating due to a clogged vent or duct. Check your duct hose inside the house for lint/water clogs. You will have to remove it to do this. Then check the outside vent for lint clogs and make sure that its opening properly (louvered vents). If thats not the case, call up Sears and use your warranty.
Jun 05, 2009 | Dryers
Dryer not drying
You have a venting problem and air is not leaving. Its either kinked or clogged.
Mar 29, 2009 | Dryers
Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
195 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
