If you have a router with two thernet ports you can connect them together using this.
Otherwise you can take the hard drive out and connect it to your new computer but this can be tricky to do.
The other thing you could do is buy a USB hard disk caddy. Fit you hard drive into this and then connect it to the USB port of your new computer. Make sure the caddy will take your size and type of hard disk.
ONE BAD LEAD?
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive one bad lead will cause a computer to shut down
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
