Question about Audiovox AVP-7000 Video Cassette Player - 12 Volt Car Video Player
Boat battery 12 volt drains down in few days. I hooked up volt meter in line positive wire to circuit to elec lift, it shows just under 1 volt steady with switch in off position, could this be the drain on battery, how do I determine if it is the switch or short in wire
    Scholar:
  • 132 Answers
1 - isolate the swithc completely
2 - remove the +ve terminal from battery
3 - conduct continuity check between +ve & -ve lines from on any lines possible.
A short is unlikely, as this would either blow a fuse, or cause you a fire.
It does sound like you have something that is draining power constantly, or you have something that has risen in resistance (water environment can cause verdigris and bridging to occur) this is not enough to power the given unit, but certainly enough to drain a battery.
HINT - Apply vaseline to any exposed copper or contact points.
Posted on Aug 17, 2008
Why won't my lights work
It sounds like your alternator is not charging the battery. Fit a new battery remember to undo negative lead first to remove and fit positive lead first to refit the battery. When the new battery is filled please charge it using less than 1 Amp DO NOT use a car charger or try to jump start it. Your new battery should show 12.5 to 13 volts on a meter for a 12 volt system and 6.3 to near 7 volts for a 6 volt system. Start the scooter and check across the battery terminals your meter should show about 14.4 V for 12 volt battery and about 7.5 V for a 6 Volt one. No voltage increase means your charging circuit is not working. Either the alternator or rectifier(regulator) are not operating correctly. Worst case scenario is both units dead.
Sep 06, 2014 | 2012 Piaggio Fly 50 4V
Battery dies or drains completely every few days
Hi Anonymous, perform the following tests:
1. Fill acid type batteries to proper levels.
2. Charge battery overnight at 1-2 amps you need 12.5 volts or better after charging.
3. Check battery terminals for damage or corrosion, check battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with ohm meter if necessary.
4. Hook up battery positive cable, then with your multimeter on the milliamp scale connect one lead to the negative battery post and the other lead to the ground cable. Meter should read 3 milliamps or less, 10 milliamps with a radio, 15 milliamps with radio and CB. If your meter reads higher you need to isolate the circuit by pulling fuses and circuit breakers one at a time and observe meter for drop in amperage then get out your test light and track down the short in that circuit.
5. Hook up a volt meter to the battery and start the engine, if meter falls below 9.0 volts while cranking you need to perform a proper load test on the battery and replace if necessary.
6. With the engine running at 3600 RPM, the battery should read 14.3-14.7 volts if not continue tests.
7. Unplug the voltage regulator from the alternator at crankcase by the front of the primary cover.
8. To test voltage regulator go to https://www.youtube.com/watch?v=F8EjV0IjW9Q
9. With ohm meter, one lead grounded, touch alternator pin meter should read infinity, if not replace the stator.
10. With ohm meter, both leads touching alternator pins meter should read 0.1 to 0.2 ohms on 1989 and later models. 0.2 to 0.4 ohms 1988 and earlier models, if not replace the stator.
11. With the volt meter set on AC scale, both leads touching alternator pins meter should read 16 to 20 volts AC for every 1000 RPM'S 1989 and later and 19 to 26 volts AC for every 1000 RPMS. If not replace the rotor.
For more information about your issue please visit the websites below. Good luck and have a nice day.
DOWNLOAD Aprilia Rsv Mille
Apr 17, 2014 | Aprilia RSV Mille Motorcycles
Sometimes while riding the bike, it stalls after driving for sometime and then experienced hard start until it won't start again. Had battery checked and it was drained. Replaced with a new battery but...
3. Hook up battery positive cable, then with your multimeter on the milliamp scale connect one lead to the negative battery post and the other lead to the ground cable. Meter should read 3 milliamps or less, 10 milliamps with a radio, 15 milliamps with radio and CB. If your meter reads higher you need to isolate the circuit by pulling fuses and circuit breakers one at a time and observe meter for drop in aprerage then get out your test light and track down the short in that circuit.
3. Make sure all connections are clean and tight especially the negative cable at "BOTH" ends.
4. Hook up volt meter to battery and start engine, if meter falls below 9.5 v while cranking replace battery.
5. With engine running at 3600 RPM battery should read 14.3-14.7 volts if not continue tests.
6. Unplug voltage regulator from alternator at crankcase by front of primary cover.
7. To test voltage regulator go to: https://www.youtube.com/watch?v=F8EjV0IjW9Q
8. With ohm meter, one lead grounded, touch alternator pin meter should read infinity, if not replace stator.
9. With ohm meter, both leads touching alternator pins meter should read 0.1 to 0.2 ohms on 1989 and later models. 0.2 to 0.4 ohms 1988 and earlier models, if not replace stator.
10. With volt meter set on AC scale, both leads touching alternator pins meter should read
16 to 20 volts AC for every 1000 RPM'S 1989 and later and 19 to 26 volts AC for every 1000 RPMS. If not replace rotor.
17. For a free wiring diagram please visit the website below. Good luck and have nice day.
Harley Davidson Wiring Diagrams and Schematics
Sep 18, 2012 | Harley Davidson XL 1200 S Sportster Sport...
1995 FLHTCU WIRING DIAGRAM MANUEL
Aug 23, 2012 | Harley Davidson Motorcycles
2002 FLH harley will not charge battery
Jul 08, 2012 | Harley Davidson Motorcycles
Battery drains while sitting
Jul 06, 2012 | Cars & Trucks
1997 fatboy does not charge the battery
Hi Anonymous, try performing the following tests:
Jun 01, 2012 | Harley Davidson Motorcycles
Battery Drain
Hi Benbattell, try performing the following tests:
Jan 26, 2012 | 2009 Harley Davidson FXDF Dyna Fat Bob
Something is draining the battery
What you do is pull off the pos cable. Touch it to the ground cable for a couple of seconds to discharge any voltage that may be lingering in the cars circuits. (Leave ground wire hooked to battery. Only the Positve should be unhooked) Now hook your meter between the Pos Cable and the Pos of the battery. It should show anywhere from between 0-2 volts. maybe more if you have a alarm system. If it shows anymore then 3-4 volts you have a parasitic draw. Best way to Isolate this is to start pulling fuses one by one until the meter jumps down to zero. Then plug other fuses back in. If meter dos not go back up. you have isolated the circuit that is draining the battery
May 09, 2010 | 1995 Honda Odyssey
Wring for trolling motor
just hook the two batteries up in series. To do this buy one short cable and use it to hook the positive of one of the batteries to the negative pole of the other. Then use the two remaining poles, one positive and one negative to hook up to the motor. good luck
Jan 18, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Audiovox AVP-7000 Video Cassette Player - 12 Volt Car Video Player Logo
423 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
