Optimus 1000 belt drive automatic turntable
The belt has come off and we don't know how to put it back on. Help?
  • bLKJACK Sep 07, 2008
    I have a gemini TT-01 turntable and the belt has come off and I do not know how to put it back on. Can you please help?
  • Anonymous Mar 26, 2014
    I am trying to find the route of the drive belt.
  • 515 Answers
Usually, for most turntables, the belt goes on the bottom of the platter first. Then you put the platter back on the turntable. From here you should see an opening on the platter where you can 'grab' the belt. Pinch the belt, and then wrap it around the rotating motor's shaft. This is usually at the top left side - around the 10 o'clock position.
- OPTiC
Turntable Technician
www.1200s.com
Posted on Sep 08, 2008
HOW TO INSTALL A BELT ON A OPTIMUS LAB-1100 FULLY AUTOMATIC TURNTABLE
See:
http://www.youtube.com/watch?v=FTJd_WbEhEs
If you have difficulty lifting the platter off, raise it as far as you can and gently tap the spindle with a sift-faced hammer.
Sep 23, 2014 | Audio Players & Recorders
My drive belt came off i do not know how to put it back on please help! I have a Denon - Fully Automatic Turntable System - DP-29F It doesn't give me much help in the instructions on how to put it back on.
1. Remove the rubber disc from the metal platter.
2. Remove the metal platter by pulling straight up.
3. Ignore the player for the moment; focus on the platter.
4. On the underside of the platter is a circle about 2 inches smaller than the platter; stretch the belt around that inner circle. Make sure it is not twisted.
5. Put the platter back on the player. Rotate the platter so that one of the rectangular holes reveals the drive wheel.
6. Stretch the belt so that it goes around the drive wheel (I used a pencil but tweezers would likely work well).
7. Replace the rubber disc.
Mar 23, 2011 | Denon DP-29F Turntable
Belt is off my audio-technica turntable at-pl50
WASH YOUR HANDS FIRST! Any oils on the drive belt may cause slippage.
This is from the manual:
A) Remove the record mat from the turntable platter
(Fig. 10a). Through an opening in the
turntable platter, visually inspect to see if the drive belt
is around the motor pulley (Fig. 10b).
B) If the drive belt is not around the motor pulley: Lift
and remove the turntable. Place a thumb into each of
the left and right openings on the turntable platter; and,
using the fingers to press down on the turntable housing’s
surface, pull the platter straight up (Fig. 10c).
Avoid pressing on the tone arm.
C) With the turntable platter bottom side up, place the
belt along the outside wall of the turntable platter's
drive rim, making certain that the belt is smooth and
flat all the way around (Fig. 10d).
D) Put the turntable back on the center spindle, make
certain it is fully seated, and align one of its openings
over the motor pulley position.
E) Through the opening, carefully hook the turntable
belt with a finger or with the original red ribbon (never
use a sharp object) and pull the belt over the motor
pulley (Fig. 10e). Make certain the belt is not twisted
between the pulley and the platter’s drive rim.
F) Put the record mat back on the platter.
G) While holding the tone arm in its rest position,
slowly turn the platter by hand clockwise at least 10
rotations to clear the mechanism’s automatic cycle.
Apr 24, 2009 | Audio Technica AT-PL50 Turntable
Turntable help
http://www.archive.org/details/Turntable_Belt_Installation
above is a generic video that applies to almost all belt driven turntables including yours that will show how to install the belt and a few other things.
Sep 20, 2008 | Aiwa PX-E860 Turntable
Drive belt on Sony turntable
- OPTiC
www.1200s.com
Sep 07, 2008 | Sony PS-LX250H Turntable
Optimus lab 1100 Turntable won't turn!
The mechanics in your arm postion is throwing the switch. A mechanical postion switch has sliped out of postion, a arm from the toner arm post has moved to an encorrect postion, or if your turntable has a multi-album play abilty your 'next to play record' post postion sensor switch is out of postion. Last or first is your belt could fool ya. Your belt may have a weak spot on it in turn no friction underload.
Aug 07, 2008 | Audio Players & Recorders
The belt on my turn table came lose
01- Remove the rubber cushion.
02- Remove the Turntable Platter
03- Place your drive belt around the ridge inside the platter
(Make sure that it is not twisted)
04-Place your Turntable Platter back on the unit
05-rotate your platter until you can see a brass knob through one of the round holes in the turntable. (Your belt must be placed around the brass knob) The best way is to take a toothpick and carefully slide it under the drive belt and then pull it out enough that you can place it around the knob. I had the same problem and the above works. If you still have problems getting it back on contact me 352-377-1828......
May 03, 2008 | Teac P-A688 Turntable
Belt Drive
The belt is replaced as in the following diagram from the manual that you can download on the link below: http://www.lpgear.com/at_pl50_om.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 27, 2007 | Audio Technica AT-PL50 Turntable
Belt came off
Remove the rubber mat and you will see two holes in the turntable. Put your fingers in these holes & using equal force pull up to release the turntable. The drive belt goes around the metal disk you will see below and around the drive pulley. Most likely it has just jumped off the pulley so hook it back over. Replace the turntable and gently rotate it a couple of revolutions, you can see the belt through the holes in the turntable. If all is seated OK power up & enjoy! You can download the manual from the link below: http://usa.denon.com/DP29F_DFU_ownersmanual.pdf This shows the procedure as per original install. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 13, 2007 | Denon DP-29F Turntable
539 people viewed this question
 Grubhead
Grubhead
