Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
How to install Bosch garage door opener. Bosch 7 781 745 CEPT LPD-D 4333.92 MHz
2 Suggested Answers
  • 3197 Answers
SOURCE: Craftsman new 315MHz Garage door remote programming with old openers
The radio frequency has been changed so the two are not compatible.
Posted on Jun 01, 2009
My Lift Master garage door will not close. It makes the closing noise but the door does not slide down. Whcan I talk to to fix this?
Sounds like you have a chain drive garage door opener and you hear a humming sound when you push the wall console. The motor is running but the chain does not move. You need to replace the gear & sprocket assembly.
Jul 06, 2014 | liftmaster Lift Master 377LM 376LM 315 MHz...
My new 315 MHz keypad will not communicate with my older 390 MHz opener?
That is correct the units are two different frequencies and will not communicate. Kind of like trying to listen to an FM station on an AM radio. Sorry to be the bearer of bad news. Dean
May 05, 2011 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/s HP 315 MHz garage door opener (Model 139-18470DM). The temperature here is currently 34 degrees celsius with the windchill. When trying to close the garage door from the main switch, the...
Check for some obstacle in the path of the light beam sensor that (should) be installed across the width of the door opening about 3-4 inches off the ground.
Jan 30, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a clicker model KLIK2U and forgot the code. How do I reprogram without the old code?
It's really easy to reprogram your unit:
Step 1. Hold down the (*) and the (#) keys until the keypad stops flashing.
Step 2. Determine your opener ID using the list below:
*1= linear garage door openers manufactured from 1997 to
present.
*2= Chamberlin, Sears, Craftsman, LiftMaster, Master
Mechanic and Do it garage door openers manufactured from
1997 to 2004 ( Orange learn Button)
*3= Same as *2 above, but manufactured from 2005 to present
with a (Purple learn Button)
*4= Same as *2 above, but manufactured from 1993 to 1996
with a (Green learn Button)
*5= Genie Intellicode and Overhead Door garage door openers
manufactured from 2005 to present (315 MHz).
*6= Same as *5 above but manufactured from 1995 to present
(390 MHz).
*7= Stanley garage door openers manufactured in 1998 to
present.
*9= Wayne Dalton garage door openers manufactured
in 1999 to present.
Openers with learn Buttons
Programming: Enter the PIN that you want to use, remember
(4) digits only. then press #
Enter ID # from list above, for example 2 then #
Press and release the Learn button on your
garage door opener.
Enter your (4) digit PIN and press (0),
for Genie and Overhead door units press
(0) twice. To test and use wait for light to go out
on keypad, Enter you PIN and press (0).
Note: If opener doesn't function repeat programming.
Instructions if required.
Sep 17, 2010 | Universal Garage Wireless Keyless Entry...
My garage door opener only works from a couple feet away
On the rear of your motor unit just to the left of all those white wires you will see a small light. If this light is flashing randomly it is normal. If it is flashing rapidly it is an indication of interference or you have keyed your remote. It really sounds like interference and you will have to do some more checking things.
315 mhz is the radio frequency and you cannot change that. In fact if you purchase a new opener you will get that same frequency.
Your opener was made by Chamberlain Mfg. Co. that also makes Liftmaster. That may be where the confusion comes in.
Jul 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Jun 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
I can't get my old remote to work with my new garage door opener
buy new remotes. New opener is 315 mhz, old are 390 and not compatible,
Jan 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
789 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
