Question about Panasonic PT-47WX42 47" Rear Projection Television
Convergence problem not fixed after replacing STKs
I have a Panasonic PT-47WX42 47inch TV. The red beam went out of convergence. I replaced both ICs with STK392-150. But red is still out. Using the convergence menu, red adjusts vertically, but won't budge horizontally. On the left side of the screen it's in alignment, but across on the right it's way off.
Blue and green are ok.
Is there something else that should be replaced? It almost looks like a horizontal motor for the red beam has failed.
  • gdp1 Aug 20, 2008
    I just got the same problem with my blue color. It happened this week. I called a local repair shop and they think it could be the IC Chips. They said each chip is $50(I think there is 3 in this TV?) and $150 at a min for labor. How hard are the chips to replace?
  • mfoco Aug 23, 2008
    I found the chips easy to replace, but time-comsuming due to the number of pins involved. I woudn't want to try it if I'd not had prior experience with soldering.
    Still no response to the original question though. With 2 replaced STK392s, red is still not moving in horizontal alignment. What gives?
Obviously this site wasn't worth bothering with
Posted on Aug 27, 2008
Posted on Aug 23, 2008
Panasonic (PT-56HX41PF) rear-projection tv with no picture
The three blinks indicates a convergence IC fault. The convergence ICs must be replaced with the manufacturer replacement part. Use only the original replacement part. Your set uses STK392-110 convergence ICs.
These ICs are mounted on a large heat sink. Yes, you can replace it yourself and save few hundred bucks. But you must be knowledgeable enough on how to solder, resolder and use a multimeter.
You will need:
  1. Convergence ICs
  2. Heat sink grease or thermal compound
  3. Soldering iron
  4. Solder lead.
  5. Digital multimeter
  6. Solder pump
  7. Small side cutter
Feel free to inform me if you decide to replace the ICs yourself
Dec 03, 2009 | Panasonic PT-56HX41 56" Rear Projection...
What is conversion problems and how do I fix it on a 47 inch panasonic rear projection tv
Replace Both of your STK ICs they are big black ICs will have Part number on them Call Mats Electronics for Parts 1-800-628-1118 STKs are your convergence ICs
Nov 13, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Projection tv won't turn on after replacing convergence & resist
STKs are static sensitive, your tv though, also has a digital convergence board that if damaged will cause any new ICs and resistors to fail. you need to have a technician repair this. This is why many of the DYs that seek help on the net would save money, simply by calling on a repair shop. Julio milleniumtvsvc@gmail.com
Jul 26, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Green arc across bottom of tv,and a little purple.
Replace Both of your convergence ICs STKs, big black ICs.
Jun 17, 2009 | Panasonic PT-47WX53 47" Rear Projection...
I have a panasonic pt-51hx42. I was just
your convergence power supply blew a fuse & probably one if not both of the STK ics. Normally when this happens the short takes out the low value resistors connected to the ics.
it is common practice in the shop to replace both STKs and resistors
Jun 09, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Convergence issues
Have you replaced your convergence ICs STKs big black ics? If not what is # on your ICs?
Dec 27, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Sony 46WT500 Display Issue (Convergence?)
converge chip failing after warm up fairly common
to see
Dec 26, 2008 | Sony KP-46WT500 46" Rear Projection...
Convergence Problems with red to left of screen.
Replace Both STKs convergence ICs number of part will be on them STK392-110 if this is the number use 180s To order Parts Go To www.electronix.com or Call 1-900-223-3205 These ICs are big black chips.
Dec 14, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic projuction screen tv.
3 blinks is the error code for the convergence ICs. You need to replace both STK392-110 convergence ICs. You can get replacement ICs at the following link and they provide installation instructions with pictures.
http://servicemanuals.vstore.ca/
Oct 12, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Power Light blinking 5 times
check the resistors near the
stk's. There are some reports that they get fried when the stk's fry....or the other way around. The resistor ratings are labeled on the resistors. 2.2, 82, 180 or something like that. Also check the board as you turn on the tv. See if any glow red.
Sep 22, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX42 47" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
