Question about Philips Televison & Video
Philips flat screen TV MODEL ID 19PFL5422D/27
TV keeps turning on and off by itself and has vertical lines on the screen.
  • Anonymous Mar 24, 2014
    when turn philips tv flat screen on came on for first 20 minutes moving pink blobs appeared but after a couple of months, moving and streaching blobs stay on all the time
I bought the television less than a year ago, so I called Philips Magnavox and they asked for the serial and model numbers. Next thing I know they asked for my name and address and Philips is sending a brand new television to replace it !!! The new one should arrive in about ten days. How's that for service? I'm very happy that I bought Philips and I will do so again. So don't forget to keep all the paper work that comes with your new televisions,especially Model and Serial numbers ! Thanks for asking , Debbie Hoffman
Posted on Aug 19, 2008
I have a philips flat panel lcd model#42PFL36030/27 I have a vertical yellow line that is near the left side of the screen. The TV is only 2 years old. What could this be and what can I do to fix this...
This problems are alway the causes by the T-CON decoders board that sit at the bottom wright in middle of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to a refurbish T-CON decorders board for the replacement.
Nov 20, 2010 | Philips 42PFL3603D 42 in. LCD TV
My philips flat screen tv has got negative colours and two vertical lines down the middle of the screen it just went like that is it the tube?
It is possible that you may need to download an upgrade to a flash drive and then with the tv off, insert the flash drive into the usb port on the tv. Turn the tv on and it will load itself. Check Philips website for updates...
Sep 10, 2010 | Philips 42PF9631D 42 in. Plasma Television
Philips TV turns off and on and has a very bad picture
Check electrolytic capacitors on the power supply board for bulged tops.
May 10, 2010 | Televison & Video
Phillips 19" flat screen
OK, I had the same problem and I fix it 100%.
The power board is ok, the lamps are ok, don't waste time there.
Just open the TV, remove the shield of the mainboard, and in the side where are the wires from the power board, there are many capacitors, check them, in my case 4 were "fat", exploded.
I had to change 9 to make shure, and that's all !!!
Saludos de Mexico!!!
Feb 21, 2010 | Philips 19PFL5422D Television
My philips 19pfl5422d tv turn on then turn off with no picture how do i fix it.
Power supply board is dead.Replaced the power supply board.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply.
Feb 15, 2010 | Philips 19PFL5422D Television
My tv will turn on but with white light line then shut off itself
If the line is horizontal (it is a vertical problem) If its a Vertical line (it a horizontal problem) So it could be just a bad solder joint or a component has failed in the horizontal or vertical section. Hope this is helpful.
Nov 28, 2009 | Philips Magnavox 27MS343S 27" TV
Horizontal lines at the top of the t.v. screen.
you will have to find fault in vertical deflection try condencer replacement in that stage
Jul 11, 2009 | Philips 27PT6441 27" TV
Philips Magnavox 20MS3442/17 Green Line
If this is a tube type or crt type. Your vertical circuit has a problem. Could be the vertical IC loose connection on its board. Or the vertical ic itself is faulty. If just resoldering or refluxing of its pins doesn't help check some minor cmponent within vertical circuit. Or the vertical ic is defective already.
If your not inclined on electronics never do the repair itself, nasty voltages might caught you.
May 11, 2009 | Philips Magnavox 27MS343S 27" TV
Philips tv model id: 19pfl5422d/27 terrible loud sound
The issue is 4 1000uF X 10V on the main board under the shield close to the connector that from the power board. you will see them because they will be FAT( exploded)
Feb 28, 2009 | Televison & Video
Televison & Video Logo
631 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
