Sharper Image Ionic Breeze GP SI730 Air Purifier
Problem for Sharper Image Ionic Breeze GP SI730 Air Purifier
Blinking blue light
By tcbsr on Aug 17, 2008
blinking blue light
Same Problem
Apr 30, 2009
-   I just got two replacement units about 6 months ago. Both of my previous died within the 5 year warranty. The replacements worked fine for about 3 months. Then one had its off/on/on-gp light go out while at the same time the low/med/high light started flashing. Everything else seems to be working just the same.
Then yesterday at about 6 months after getting these units, the second one started doing the exact same thing after I cleaned it.
Both units appeard to be working fine except for the lights on top being dysfunctional.
-   Guest
Apr 03, 2009
-   I have the same problem , blinking blue light.
IONIC BREEZE QUADRA MODEL 51867-   LRIVERO
Dec 05, 2008
-   Me too. They said I need to clean it, which I did. But it still blinks. I've had mine for only 6 months, right before they filed bankrupcy. -   fix_me_up
Nov 16, 2008
-   same problem....just recently after cleaning....-   marshal40002
Sep 21, 2008
-   Yes, I have the same problem. Its been less then a year since i bought this ionic breeze and now the light are blinking and it doesn't seem to work anymore. -   kingbeast
Best Solution
posted on Feb 28, 2009
Very Helpful)
nenotech_neo
Rank: Wiz
Rating: 84%, 87 votes
What is happening is this: the main electrical component is overheating and forcing the machine to turn off. When it cools, the machine turns back on. Yes, that is actually what is causing the blinking.
There is no solution for this as the main electrical component (a high voltage capacitor in this case) has failed due to stress. In my case, the machine worked for 2 months before failing. The only real solution is to have the unit serviced. However, as there is no service centers, we are all out of luck.
I believe this could be a class action law suit against sharper image for selling units built with components it knew would fail after a short period of time. They had hundreds of reports with this same failure and they knew the cause. Pressing the "boost" button too much causes extreme stress on the capacitor and shortens its life drastically. This capacitor is what provides the power to the ionizing wires.
Good Luck!!!
neo
Was this helpful?
Yes
No
6 people thought this was helpful
Popular Solutions for Sharper Image Ionic Breeze GP
Questions and Unsolved Problems for Sharper Image Ionic Breeze GP
Do you recommend Sharper Image Ionic Breeze GP SI730 Air Purifier?
Answer
Answer
I have two Ionic Breeze Gp's 4 years old, they both stop working about the same time. I changed the... (More)
Answer
ionic breeze quadra red light won't turn off despite cleaning. What else to do?
Answer
I just got a used Sharper Image GP Model S1730. How do you take it apart to clean it? It is an air... (More)
Answer
the clean light does not come on . How do I really know if it's working? there are also two on... (More)
Answer
have there been any health problems reported with this air purifier?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Purifier Experts
Top Air Conditioner Repairmen
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
