Question about Breadman TR555LC Bread Maker
It appears a washer has deteriorated at the base of the gray dough container - what washer(s) do I need to fix this
Washer type needed
  • 368 Answers
Hi realestateap,
I'd contact the manufacturer (Salton, Inc.) customer servicesite for parts or manual. If they don't have them, they should knowwhere to send you.
Go to
http://prc.prodregister.com/prodprotect/applica/
And click on "Breadman" (upper-right portion of the page), it redirects you to a secure webpage where you can register.
https://secure.prodregister.com/prodprotect/applica/bm.shtml
Part of the page reads:
"Call toll-free or visit our websites for assistance if you need more help.
Parts & Accessories:
Phone: 1-800-738-0245 (Monday–Friday, 8:30 a.m. to 8:00 p.m., ET)
Product Warranty:
Service: 1-800-231-9786 (Monday-Friday, 8:30 a.m. to 8:00 a.m., ET)"
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Posted on Jan 04, 2009
SOURCE:
How do i fix a transmission that is not moving forward?
First thing, check the transmission fluid. Also note the color of the fluid. It should be red. If it's gray or very dirty looking, this would indicate internal problems such as deteriorating clutches. In which case and overhaul will be needed.
Jun 12, 2014 | 2003 Toyota Camry
Panasonic SD-YD250 Bread Maker uneven bread
Usually this happens when the mixture is too dry. Flour contains varying amounts of moisture, thus water needed also changes. Follow User Manual to help solve the problem or add additional water one tablespoon at a time. The dough should be a little more tacky than conventional bread dough. This will allow the dough to flow out more evenly and be less dense. This is a very important step that many persons miss.
Apr 04, 2014 | Panasonic SD-YD250 Bread Maker
Dark particles all over clothes once washed. I cleaned the washer, ran a tide washer cleaner through, checked and cleaned the screen filters that hot and cold hoses pump water through. Is there anything...
sounds like you may need to check your hot water heater for deterioration. since you have done all that you need to check your water supply. a water heater can deteriorate on the inside for a time before you will notice it. good luck
Sep 06, 2011 | GE Profile WPRE6100G Top Load Washer
Leaking faucet
Did you check for debris, and clean it, or for deteriorated seat where cartridge washer bottoms out at tap base. If it has deteriorated too much, and seat is damaged, it won't help to replace cartridge, you will need to replace taps.
Jan 07, 2010 | Hand Tools
When we run the wash, black marks appear on some clothes. No pens or foreign objects are in the washer.
It can either be the rubber seal around the washer door or the bearings (normally sealed) for the tub may be leaking and getting grease into the tub. I think usually the bearing grease is brown in color. For some reason, as the rubber seals deteriorate, they tend to mark up clothes. At least that has been my experience. You may try wiping them down with some sort of cleaner (fantastic, greased lightening, etc) and see if that helps any.
Aug 15, 2009 | Frigidaire ATF6000ES Front Load Washer
Black goo type liquid oozing from under dough hook when done.
Sounds to me like your seal is bad and you need a new bread pan, which includes the seal. Call phone no. in your manual to get the part you need.
Dec 06, 2008 | Sunbeam 5891 Bread Maker
Whirlpool calipso washer
If these are gray spots it may be fabric softener. Try running a few loads without and see what happens. Also check the seal around outside of inner tub bottom to make sure it still contacts tub all the way around. If it doesn't, you need to have a tech replace the nutator assembly and hte bottom plate. Based on past experience, may be better off replacing.
Nov 18, 2007 | Washing Machines
Grit Deposits
best bet is to go to repairclinic dot com for parts.
Aug 02, 2007 | Maytag MAV6200 Top Load Washer
Breadman TR555LC Bread Maker Logo
94 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Irene Tulloch
kmciner
Level 1 Expert
Steve Allison
Steve Allison
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
