Question about Arris DCT6200 DTV Receiver
Motorola DCT 6412III, How to reset time display
We have reset the PVR and cannot display the time on the readout again.
How do we do it?
Sent it through the dct guide....menu then setup then cablebox...should see display option either channel or time
Posted on Aug 18, 2008
What is the code for my Motorola DVR Model DCT 3080 1
Willliam-
Contact Arris ARRIS for Consumers for support for your Motorola DVR DCT3080.
Mark
Motorola Support
Feb 02, 2015 | Motorola Televison & Video
My DTC 6200 converter/decoder was working fine. A few weeks ago I have disconnected it, pull the power cord out of the AC outlet, put the decoder in a safe place. Then when I finish painting, I hook...
Hello
Check out these with your Motorola converter
[1] Verify that the AC power cord is connected to the DCT*
and an AC outlet.
[2] If the DCT* is connected to a switched outlet on another
unit, verify that that unit is powered on.
[3] Press the POWER button on the DCT* front panel instead
of the remote control. The batteries in the remote control
may be depleted
[4] The DCT* may have received a software update and
may not power on while the new software is being
installed. Try again in a few minutes.
OK.
Oct 21, 2011 | Arris DCT6200 DTV Receiver
Have to turn off the pvr then on again every time the tv is turned on due to ''no signal'' being displayed though aerial works fine. The pvr does a scan each time and gives the option of a full channel...
I think the problem lies with what input you have selected on your tv. On your (tv) remote control there should be either a circle or square with an arrow on through it. With your pvr already switched on, turn your tv off then on again. When it says no signal, press the button on your tv remote I've described until you see a picture.
Jan 20, 2010 | Televison & Video
I misplaced my Manuals for my new PVR
here is the manual in pdf
Hope it helps MANUAL
Mar 30, 2009 | Televison & Video
Motorola Dual Tuner PVR - DCT 6412-III --- HELP
I was just reading another blog on this problem and it seems you must clear any recording setup you have for the program the go to the settings and in the history file delete all listings of it. This can take a while as you must delete them one at a time. Then you can reset the series or single recordings. Seems to work for some people. I am having the same problem and programs are disapearing one at a time. Good Luck
Smalltown
Feb 24, 2009 | Arris DCT6200 DTV Receiver
Reset Motorola dct 6200 without dvr
turn it off, push the front panel menu button… an onscreen menu will appear that you can navigate with the remote… the last item is reset to defaults.
Mar 28, 2008 | Arris DCT6200 DTV Receiver
Reset
using your remote hit replay-list-live tv 3 times each it will shut of reset then hit list & will read 0
RESET
try browsing to www.motorola.com or try your manual
:D
Dec 11, 2007 | Arris DCT6200 DTV Receiver
Motorola DCT 2244/1661/abcdeg locked up
Pay Per View events, or IPPV events are stored inside the unit on NVRAM (Non-Volitile RAM) until the DAC-6000 (Digital Access Controller) calls up or "polls" your unit for IPPV events.
THE BAD NEWS:
They cannot be removed by "resetting" the unit.  Some claim unplugging the unit for several hours or days.... other claim that you can unplug the unit, hold down the power and select buttons at the same time, and plug the unit back in (while holding these buttons) and watch the LED screen flash 8888 several times and then let go of the power and select buttons.  All this does is erase the firmware, NOT the IPPV or polling information.
Only the DAC-6000 can remove the events from your unit. Those events are stored in the unit forever until it's correctly polled by the DAC.
THE REALLY BAD NEWS:
Once those events are collected you will be billed for everything you watched.
The "0" you are seeing on the LED screen indicates it has lost it's firmware and is basically a "brick" until it has been properly re-authorized with the firmware and cleared any polling events.
Nov 08, 2007 | Televison & Video
Arris DCT6200 DTV Receiver Logo
342 people viewed this question
Top Arris Televison & Video Experts
Are you an Arris Televison and Video Expert? Answer questions, earn points and help others
