Question about Lexmark Office Equipment & Supplies
Will not print, is their cord that plugs into the computer. I have the power on
  • 37 Answers
Hi
Please check that the usb cable from the Printer to your system, If yes then check the printer is correctly installed in your system by clicking the start, Control panel, printers if no then install the printer by using the printer CD. This will solve your problem
T.Boopathy
Posted on Aug 17, 2008
My printer is not printing
Without knowing any more, all I can do is take you through a tedious set of steps:
  1. Is it plugged in? Unplug the power cord at both ends, then plug it back in.
  2. Is it connected to your computer? Unplug the cord at both ends, then plug it back in.
  3. Is it turned on? Press the power button. Do any lights change (go on or off, change color, flash, etc.)?
  4. Send a print job to the printer. Does the printer show any signs of realizing it's been asked to print something (an indicator light or something moving inside)?
  5. Open the print queue. Delete all the jobs that are in there. Shut down the printer. Restart the computer. Turn the printer back on. Try printing.
  6. Are you getting error messages?
  7. What happened before it stopped working? Did you install new software? Move anything?
May 01, 2015 | HP DeskJet F380 All-In-One InkJet Printer
Printer will not print
If unplugging and re-plugging the printer into your computer doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/eVzv1x. Select your operating system, download and execute the file.
Feb 14, 2012 | Lexmark X5650 All-in-One InkJet Printer
I have a document in the queue for printing that I have tried to delete as it is blocking other documents for printing. How do I delete it permanently? I have tried clicking on it in active printers and...
This is the simple way to get rid of your stuck document. Do not short cut.
Delete your printer from within the control panel/printer folder.
Go to www.lexmark.com/support and get the latest version of your print driver that matches your operating system. Put the download on your desktop for easy locating.
Turn off your printer, turn off your computer, disconnect your printer from your computer and unplug the printer's power cord. Wait ... Turn on your computer ... run the driver (package) you just downloaded. Plug in the power cord for the printer. Do not plug in your printer data cord until instructed to do so. Follow the on screen instructions for loading the driver exactly.
This will get you up and printing again.
Thanks for your question today
Feb 06, 2011 | Lexmark Office Equipment & Supplies
Paper jam
Hi Good day!! Follow this method to remove your paper jam:
1. Check to make sure that the power cord is securely plugged into an active wall outlet if your printer is not turning on.
2. Make sure that the USB cable connecting your computer to your printer is securely connected if your printer powers on but will not perform a print job.
3. Remove a paper jam if the "Check Paper" light on the front of the printer is blinking. To do this, first turn off the printer and unplug the power cord from the printer. Open the front cartridge door and locate the jammed paper. Gently pull the jammed paper toward you. Plug the printer back in and turn it back on.
4. Connect your printer to a different USB port on your computer if you are experiencing slow printing. The slowness could be due to a connection problem with your computer's USB port. After you've switched the port, try your print job again.
5. Make sure that a phone line is securely connected from a phone jack to your printer if you are having trouble sending or receiving faxes.
6. Clean the scanner surface if your scans are blurry or have vertical white or black lines. To do this, spray the a soft, lint-free cloth with a mild glass cleaner. Wipe the scanner glass with the cloth and then dry it with another clean lint-free cloth.
7. Hard reset the printer if you are having trouble solving your problem. Turn the printer off and remove the power cord from the wall outlet. Wait at least 15 seconds and plug the cord back in. Power the printer on and try your job again.
8. Restart your computer if you can't solve your printing or scanning job. Sometimes restarting the computer can solve an unseen problem.
Don't forget to vote thanks!!!
Oct 28, 2010 | HP PSC 1510 All-In-One InkJet Printer
Both the orange and the green lights are blinking and printer will not print.
The printer is waiting to receive a document to print. Choose the print command from the software program that you are using.
Wait for the printer to complete the current task.
OR
If the printer continues to blink after several seconds, follow these steps:
    1. Turn the printer off, and then turn it back on.
    2. If it does not turn off, unplug the power cord from the back of the printer.
    3. Unplug the power cord from the power source. Wait 30 seconds.
    4. Plug the power cord into the back of the printer.
    5. Plug the power cord into the power source.
  • Restart the computer and the printer. Try printing again.
  • Make sure there is a direct connection from the printer to the computer. Remove scanners, switchboxes, and so on.
  • Try another cable.
  • Try connecting the printer to another computer. If the printer prints, then the problem was with the main computer, possibly a software or device conflict
Aug 11, 2009 | HP DeskJet 5550 InkJet Printer
Just changed both ink cartridges. Test prints fine. Tried to copy a doc, prints wall to wall black ink. What's up?
hi first of all try to scan something from your computer if scan is fine then open solution center and then go to solution center and click on settings after that click on printer tool box click clean print heads/cartridges after cleaning align then now try to copy
if still you have a problem then Perform a reset of the HP All-in-One
  1. Press the On button and turn off the HP All-in-One.
  2. Unplug the power cord from the wall outlet.
  3. Unplug the power cord from the back of the HP All-in-One.
  4. Wait for 20 seconds.
  5. Plug the power cord back into the HP All-in-One.
  6. Plug the power cord into the wall outlet.
  7. Turn on the HP All-in-One by pressing the On button.
Aug 05, 2009 | HP PhotoSmart C4280 Laser Printer
Zvonko jelusic from belgrade
The print carriage is stuck.
Solution
  1. Open the top access door on the printer.
  2. Remove the print cartridges.
  3. Close the print cartridge flaps after removing the print cartridges.
  4. Turn the printer off and then on again.
  5. Replace the print cartridges.
  6. Close the top access door.
If the resume light continues to blink after the print cartridges are released,
OR
the print carriage is stuck or makes a grinding noise, follow these steps.
Solution
  1. Lift the top cover to the printer.
  2. Turn the printer off and then on again.
  3. Unplug the power cord from the back of the printer when the grinding noise starts. Unplug the power cord from the wall outlet.
  4. Move the print carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct).
  5. Take out the print cartridges and close the top cover.
  6. Plug the power cord into the wall outlet. Plug the power cord into the back of the printer.
  7. Open the top cover, reinstall the print cartridges, and then close the top cover
Solution
  1. Open the top cover.
  2. Unplug the power cord from the back of the printer. Unplug the power cord from the wall outlet. Wait a minute or so.
  3. Plug the power cord into the back of the printer. Plug the power cord into the wall outlet
Sep 22, 2008 | HP DeskJet 5550 InkJet Printer
Hi! I'm getting the following message on my computer screen: Error Number : 306 A communication error has occurred. Make sure that the printer is plugged in, powered-on, and properly connected to your...
Do the following:
Try a different usb cable.
Plug the cable into a different USB port.
Try disconnecting printer power cable for ten minutes.
Unplug computer power cord for ten minutes and restart.
Reinstall printer drivers.
If that all did not work, test the printer on a different computer, to find out if it is faulty or not.
Sep 19, 2008 | Canon Office Equipment & Supplies
Hp officejet 6210 won't print
Perform the following steps:
a) Turn the printer on.
b) Open the printer’s top cover.
c) After the print cartridges have moved to the center/home position of the printer, unplug the printer’s power cord from the electrical outlet.
d) Remove the print cartridges.
e) Using a dry, lint-free, clean cloth, wipe the print cartridge contacts, from the top to the bottom
f) The contacts inside the printer may also require cleaning. Using a dry, lint-free, clean cloth, gently wipe the contacts, from the top to the bottom
g) Plug the printer's power cord into the electrical outlet.
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
Now, perform the following:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Mar 30, 2008 | HP OfficeJet 6210 All-In-One InkJet...
14 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
