Question about Kenmore 80754 Top Load Stacked Washer / Dryer
Compact model number 110.4472,clothes get trap under the blades of the agitator
Clothes get trap undr the blades of the agitator.
causing the rest of clothes to tangle on one side of the machine
the machine is brand new
SOURCE:
vickygomar
  • 460 Answers
SOURCE: Model No. 22632
Okay
Seams like this washers has the same problem lets try to fixya. check the
Moldy at the front-loading washing machine these where it is,
look for mold inside the large rubber ring (the seal) at the opening of the washer and it's hard to scrub off, even with bleach.
Try this then used Affresh at list for 2 or 3 weeks,
good luck
Was this helpful?"
Posted on May 09, 2009
woobie dog
  • 1273 Answers
SOURCE: clothes come out tangled
Things tend to intertwine in the washer, even more so in front loaders. The only things that I have found that help is to use fabric softener, a gentler cycle, and an extra rinse. This alleviates the problem some for me, but it doesn't really go away entirely.
Regards, --W/D--
Posted on Aug 01, 2009
  • 1937 Answers
SOURCE: My top loading kenmore washing machine is not
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.16942500+
and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the problem isn't in the switch, and the Timer continues to move, the problem is likely in the transmission.
We had the same problem:
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Nov 24, 2009
TheMobilian
  • 8220 Answers
SOURCE: Kenmore 90 tub spins excessively clockwise during wash cycle.
Improperly installed thrust bearing kit. Too many washers cause the basket to spin during agitation.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 04, 2010
Testimonial: "Where is the "thrust bearing kit" and how can it be installed properly?"
mrfixit3667
  • 262 Answers
SOURCE: Clothes are caught under the agitator. How can I
Remove the top part of the agitator or the cap and you should find a bolt in the center. Remove the bolt and pull up on agitator.
98702 is not the model # of the machine. you should find the model # either on top of the machine or in the dryer door area around the frame.
Posted on Jan 11, 2010
Location of lint trap
under the fabric conditioner cup in the centre of the agitator.
How do you locate the lint filter in a washing machine? ' Reference.com
https://www.reference.com > Home & Garden > Appliances > Washers & Dryers
  1. Cached
The location of the lint filter in a washing machine depends on the brand and model of the machine, and the owner's manual states where it is located. For instance, model RAX7245JQ0 of the Roper washing machine by Whirlpool has a lint filter located under the washer's agitator ...
Lint Filter - - 426451P - Fisher & Paykel
https://secure.fisherpaykel.com/us/Catalog/ItemContent.aspx?ItemNumber...
  1. Cached
  2. Similar
Description: Suitable for topload washers that use agitator part number 425025P. The lint filter is inserted into the agitator by removing the fabric dispenser cup.
Nov 10, 2016 | Washing Machines
Where do you find the lint trap on the washer
google the make/model/manual possibly under neath at back tho some have a trap at the front
Mar 12, 2015 | Washing Machines
How to install agitator?
On a top loader, the very top of the agitator will pry/pop off. Inside you'll see the "agitator dogs" These are what cause the agitator to grab and wash the clothes. Under the dogs you'll fine a small bolt that holds the agitator blades onto the drive shaft.
Aug 18, 2014 | Kenmore Washing Machines
Washing machine lint trap
There is no trap per say. The lint catcher is self cleaning when the water is pumped out. It sounds like you are overloading it and the clothes are hitting the agitator. Operation should be agitation by water movement not beat by the plastic fins, run a wash cycle hot water no clothes to flush things out and try smaller loads.
Eric
Mar 14, 2010 | Kenmore 22622 Top Load Washer
Soap-not residue-still on clothes
Wow that's a strange one.
Are you pouring the soap into the tub onto the clothes or using a soap dispenser? If using a dispenser, it may be malfunctioning, try pouring soap directly into the tub under the waterfall while it is filling.
When the machine is agitating are the clothes on top being drawn under the water? Usually this occurs as a rolling motion from the edge of the tub towards the agitator. If the top layer of clothes have an air bubble trapped in them they may not be submerging into the water. Any soap on top may not be dissolved.
Finally, if you are pouring soap into the tub, make sure you are not spilling any onto the inside of the lid or in the softener dispenser. It could get trapped in the lip around the edge of the lid and be spilling onto the clothes when you open the lid at the end of the cycle.
Do you have the same problem if you use powder soap?
Nov 12, 2009 | Washing Machines
I have a model 110 and the agitator seems to be slipping. The part with the ''screwblade'' is not turning with the lower piece. I had a fairly full load in it this afternoon and it suddenly stopped moving...
This problem is commonly caused by worn agitator dogs on the agitator cam assembly. This is a very simple and inexpensive repair. The upper part of the agitator (called the "auger") has a cam assembly under it that acts as a clutching mechanism to drive it with the rest of the agitator. These cam parts wear out and require replacement from time to time. The following link explains what the dogs are and how to replace them:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
The part number is included in the link provided. You can purchase replacements at appliancepartspros.com for about $5. For a little more you can purchase the entire cam replacement kit, which includes the cam, the thrust bearing, and the dogs for about $11.
NOTE: You can refer to the excellent exploded view parts diagrams the web site has to offer for assistance. The model number is not "110". This is the manufacturer's code. This is the prefix to your model number that identifies the manufacturer of your washer as Whirlpool. You will need the rest of the your model number (located on a nameplate around the wash tub opening) in order to search for parts.
If you have any questions about this repair, please let me know. I hope this helps you.
Nov 05, 2009 | Kenmore 22422 Top Load Washer
When i wash it goes through all cycles but it lets out these pieces of carton rubbery pieces it doesnt happen all the time
YOU MAY HAVE WASHED SOME ONES CLOTHING WHICH HAD THIS ITEM IN THE CLOTHING IF THIS IS JUST AN INTERMITENT PROBLEM. IT COULD BE CAUGHT UNDRE THE AGITATOR AND ONLY APPEARS SOME TIMES. THERE IS ONLY ONE PUBBER PIECE UNDER THE AGTATOR AND THAT IS A GREASE SEAL IF YOU START TO SEE GREASE STAINS ON YOUR CLOTHING THE SEAL HAS WENT BAD AND THATS NOT GOOD
Aug 10, 2009 | Washing Machines
Laundry is trapped under the base of the agitator.
Im not very familiar with that type of top loadign washer,,, but on most agitators there is a bolt that runs down the center of the agitator, connecting it to the transmission/gearbox. Usually there is a cap, or softner dispenser that can be pulled off, revealing this bolt.
Mar 13, 2009 | Washing Machines
CAR KEYS IN MACHINE
If the keys are in the washer they woud be around the agitator It is unlikely that keys on a ring would be under the agitator but if youwant to check you can do the following:
FIX
1 Unplug from the wall
2 remove the plastic cap on top of the agitator hold one of the blades of the agitator and turn the top area counter clockwise and the top should unscrew allowing you to lift up the bottom blades
3 Reverse procedure
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80754 Top Load Stacked Washer / Dryer Logo
214 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
