Contributor
- Posted on Jun 02, 2011
Re: When you change the ink cartraige and clean printer...
- Print a Print Quality Check Sheet.
- Press the Ink or Ink Management key on the control panel.
- Press the up or down arrow key to choose Test Print and press OK.
- Press the up or down arrow key to choose Print Quality and press OK.
- Press Color (Colour) start. The machine begins printing the Print Quality Check Sheet.
- Closely examine the Print Quality Check Sheet. Each of the four colors is represented by a slanted square pattern made up of individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
- Compare the print quality of the Check Sheet you just printed with the three examples listed below:
(A) One or more complete blocks of colors are missing:
(B) Most of the short diagonal lines are missing from one or more color blocks:
(C)Some parts of the short diagonal lines are missing fromwhen you change the ink cartraige and clean - c_ngsample2.giflor blocks:
- The display will then ask you if the print quality is OK for black. Press the down arrow key or 2 or "-" to choose No for black with the problem.
- The display will then ask you if the print quality is OK for Color. Press the down arrow key or 2 or "-" to choose No for color with the problem.
- The display will then show Start Cleaning? Yes No.
Press the up arrow key or 1 or "+" to choose Yes and the machine will start cleaning the color ink cartridges.
- When the machine completes cleaning the print head, press Color(Colour) Start. Another Print Quality Check Sheet will print.
- Repeat the cleaning and the quality check process following the Step 4-7.
