Question about Whirlpool Washing Machines
Gives error code F6 after about two minutes - Whirlpool Washing Machines
  • 5,911 Answers
If this is a Whirlpool Duet, "F06" is a motor speed error. The problem is usually caused by a failure of the Motor Control Unit (MCU), or Drive Motor. The following link explains how to troubleshoot:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
Let me know if you require additonal assistance. I hope this helps you.
Posted on Aug 17, 2008
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
Code f1 f3 f6
virtual machine - VNC send Ctrl+Alt+F1-F6 to server - Unix ...
unix.stackexchange.com/.../vnc-send-ctrlaltf1-f6-to-serv...
Stack ExchangeMar 15, 2012 - Hence I can switch to the TTY's if my CTRL + ALT + F1 - F6 ... As I understand it, you want to send CTRL-ALT-F3 to the remote .... What numeric keycodes do I need to send for the magic sysrq functionality in a VNC session?
error code f1 dishwasher model gldt696tss 00 KVM Switches
www.fixya.com > ... > error code f1 dishwasher model gldt696tss 00
KVM Switches error code f1 dishwasher model gldt696tss 00 questions and ... 6F 23 20 F1 01 = F2 46 B1 59 04 61 77 71 Telewest 00 = 75 4A 66 04 CF 7F 55 F3 ... ...96 F6 1F C4 01 = 6D EA BE 97 6A AA DA 71 NTL 54 01] 07/10/09 00 = F0 ...
kleenmaid f6 code KVM Switches Questions & Answers - Fixya
www.fixya.com > Forum > Tags > kleenmaid f6 code
KVM Switches kleenmaid f6 code questions and answers. ... 01 = C6 64 1D EF 47 5A 0E EF tellywest 00= B7 DE 73 DE 2F A4 F3 BO 01= FA 4B 82 4C ... ...in bradford area plz 5a 01 83 5D 12 B8 96 F6 1F C4 6D EA 8E 97 6A AA DA 71 Hope ..
Jan 27, 2016 | Computers & Internet
F6 error code whirpool duet
The F6 error code for this model indicates a drive motor tachometer error. The control board is unable to properly detect the motor speed.
Jan 09, 2016 | Washing Machines
I have an f6 code and the machine will not operate once it comes up
The F6 error code means that the computer on the control didnt detect that the motor reached a high speed on the spin cycle, sometimes it thinks the washer didnt spin fast enough because of a loose wire connection either on the motor or the control boards (motor &machine control) if you find that the washer did actually spin at high speed (clothes dont come out sopping wet at the end of cycle) the wire connections or the motor control board will be the potential causes of the F6 error code. Try unplugging the machine for five minutes to let the computer reset then try again. Next check the control panel wires. f6 code flashing on display Kenmore Elite HE3 Washing Machine
May 19, 2015 | Washing Machines
We have an ASKO W6451 flashing F6. appears to jump from 1 minute to go to 20 minutes to go then flashes F6. would it be something electical?
Asko F6 error is apparently a motor fault. The motor could be jammed, open circuit , burnt out?? It may just be a broken wire or connection come off. Check "Google" and type in Asko F6 error. There is a lot of info about it.
Dec 27, 2014 | Asko Washing Machines
F6 error code first time star unit show f6 code
good day I have a problem with my aircon its ECOAIRE aircondition with error F6
Sep 09, 2014 | Electrolux Heating & Cooling
Ho do I reset the whirlpool error codes f6
F06 Drive motor tachometer error The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Replace failed component.
Whirlpool Duet error f6 Google Search
Sep 06, 2014 | Whirlpool Duet WFW9151YW 27" Front-Load...
A/c will not turn on at all gives me error codes F0 and F6. The brand is Comfortair CSD-12Y3.
I cannot find your aircon unit anywhere. Changchong manufacture a CSD12Y3. I cannot find any support on that either. Because the unit flashes from F6 to the fan It would suggest an error with the fan.
Check the motor and PCB for errors.
Jan 06, 2013 | Heating & Cooling
F6 error on Hitachi washing machine Sk 120KJS
Jul 09, 2012 | Washing Machines
Getting an "F6" error on
HELLO.
An F6 error code typically indicates a controlpanel problem. Disconnect power and wait several minutes before plugging itback in. If the F6 error code comes back within a minute of restoring power,the control switch pulse return line is not connected properly. This willgenerally require professional repair.
Thanks.
Sep 21, 2011 | Kenmore Microwave Ovens
Washing Machines Logo
522 people viewed this question
Dan Webster
Dan Webster
Sal De
