Question about Mitsubishi WS-65712 65" Rear Projection Television
TV WILL NOT COME ON
WHEN WE TURN ON OUR MITSUBISHI 65712 THE GREEN LIGHT COMES ON FOR ABOUT 5 SECONDS AND THEN SHUTS OFF. YESTERDAY IT STAYED ON FOR ABOUT 20 SECONDS AND A THE PROGRAM WE WERE WATCHING THE DAY BEFORE CAME ON BEFORE IT SHUT OFF. IT HAS NOT STAYED ON LONGER THAN 5 SECONDS BEFORE SHUTTING OFF SINCE THEN. PLEASE ASSIST WITH A SOLUTION TO FIX THE TV.
  • kissfan69 Sep 09, 2008
    Starting yesterday, when I try to turn on the TV, the green light comes on for 5 seconds then the set turns off. No picture or sound comes on. I've tried different outlets and surge protectors but have received the same results. Could this be the lamp?
  • 54 Answers
Your tv is probably going into a "protection mode" this means something inside the set had failed. This is the tv's way of shutting down before more damage can occur. This could mean many different things that could have gone wrong with this unit. Your best bet is to call your local dealer and have them come out and look at it for you. Tearing apart tv's is very dangerous! Some sets have up to 30,000 volts on the anode! GOOD LUCK!
Posted on Aug 17, 2008
  • Joe Mamma Oct 20, 2011
    Jesse is a ********!
I have a mitsubishi ws-65315. When I go to turn the tv on the green power light comes on and you can hear the tv click on, but seconds later shuts off.
this model has a self check, when green light comes on and then goes off. Push and hold both the Menu and Input buttons on the front of the set for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks 2 blinks, a pause and then repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Feb 22, 2011 | Mitsubishi WS-65315 65" Rear Projection...
TV won't turn on.
Do the self check this set has:
when the power light goes off---on the front of the set press and hold both the MENU and INPUT (or Device) buttons for 5 seconds and then release both.
Power light will blink a two digit error code--most common is 2 blinks a pause and 2 blinks--it will repeat the code several times.
Let me know what the error code is and I will tell you what it means.
2,2 is most common and the most easy to fix.
If this information helped you rate this solution as I do this here for free.
Dec 28, 2009 | Mitsubishi WS-65712 65" Rear Projection...
I turn the tv. on , the green light comes on then
When you turn it on and it shuts off---ON THE FRONT OF THE SET PRESS AND HOLD BOTH THE MENU AND INPUT(DEVICE) BUTTONS TOGETHER FOR AT LEAST 5 SECONDS AND RELEASE BOTH BUTTONS.
Power light should blink a two digit error code---for example: 2 blinks, a pause and 2 blinks--This is the most common error code.
Let me know what error code you get and I will tell you what it means and if 2-2 what the problem is.
If this information helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 12, 2009 | Mitsubishi WS-65807 65" Rear Projection...
When turned on, my Mitsubishi TV shuts off after a few seconds.
the lamp is simple; yet you can run into problems with this tv. be very careful replacing lamp. the plug in the tv can be damaged. (due to the design)
lamp part #
915P028010
Mar 13, 2009 | Mitsubishi WD-62526 Projection TV
TV wont turn on.
Hi
This case needs to diagnose by a qualified technician
Thanks
Nov 28, 2008 | Mitsubishi Televison & Video
Yellow status light on mitsubishi wd-65733 tv
When tv goes out, press the menu and input buttons. The green light will flash with a 2 digit code.
Jul 26, 2008 | Mitsubishi WD-65733 65" HDTV
Mitsubishi turns on for 3 seconds then shuts off..after power surge
try holding in the menu and input buttons together on the front panel for about 8 seconds to see if the self diagnosis feature will blink a two digt code then let me know what happens
Jun 05, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Power loss
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Picture of bad caps
http://www.auctioncreations.com/wd62525a.JPG
Nov 30, 2006 | Mitsubishi WS-65857 65" Rear Projection...
Mitsubishi WS-65712 65" Rear Projection Television Logo
245 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
