Question about Maytag MER6769 Gemini Electric Kitchen Range
My stove only burns the 2big eyes and will not allow me to bake. it reads lock and also f9. what's the problem?
  • 734 Answers
Check the door latch and replace it if you can't repair it.
Posted on Nov 30, 2008
  • 22 Answers
F9 code usually means that the temp sensor in your oven is at fault . The electronic oven control is sensing a fault with that part. that part is pretty simple to replace Call a local service company with model and serial # they should be able to get the part for you ! Temp sensors are usualy located inside the oven in the upper left hand corner 2 screws hold it in place .It pulls out and has a conector on the back that unplugs.
Posted on Aug 17, 2008
Frigidaire Self-Cleaning Oven Model FEF353BFW and F1 Error Code.
I just had the same problem! If I ever see that f9 again and hear that annoying constant beep....I will pick up and dispose of that oven on the front lawn. Lol. Took a pair of pliers and turned the lock clock wise till the light went out. Silence!
May 02, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Our stove reads f9 and won't let us do anything. How do we check the latch?
There is a motor in the back of the stove that controls the door latch. I would start by checking that motor.
May 19, 2010 | Amana ACS3350 Gas Kitchen Range
Electric Oven is not heating up (BAKE)
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} It could be that your lower element is burnt out or ready to burn out. They last 3-5 years depending how much you use your stove.
Disconnect POWER to the stove, remove the screws holding the lower element to the back of the inside of the stove, pull out carefully and remove the 2 screws holding the wires on. Check the element with an ohm meter, it should read 0 (zero or very close) resistance on an ohm meter. You may also take it to a store that sells replacements ($25) and they may check it for you.
Nov 13, 2009 | Ovens
Hit the "clean " button on my gas stove. Not only did it not clean but the Door locked button has been flashing for 2 weeks. Everytime I go to cook and it the Bake, Broil key it flashes DR then F9 I h
Personal opinion. Do not mess with settings on a gas stove. Call a gas oven repair tech and have them come out and fix it. That way if it happens again you have someone to call
Nov 03, 2017 | Frigidaire (FEB30S7D) Oven
F9 error
hi there,
can you tell me the model # on your stove please?
Sep 14, 2008 | Maytag CWG3100A Gas Single Oven
Cleaned stove, replaced bottom element, stove reading F3, F7 and F9. Oven will not work. But will work on Clean Cycle.
Initially, it sounds like a problem with the lock mechanism. Without the brand or model number, it's impossible to know what the fault codes mean. You may find them listed on a tech sheet in a plastic pocket behind the console.
F3 is usually a temperature sensor. F7 may be a keypad problem and F9 (on some machines) means there's something wrong with the door lock.
Sometimes during a self clean cycle, a high temp thermostat/ fuse fails, preventing the door from unlocking.
Mar 09, 2008 | Kitchen Ranges
F9 code
I hit the same F9 problem when trying to self-clean, except that the door was locked OPEN.
After much trial and error, I found the following fix: 1. Switch circuit breaker off. 2. Switch circuit breaker on. 3. Press Bake button. 4 Press the small/inside button which indicates that the oven door is closed.
The lock mechanism opened and the oven now works fine.
Nov 22, 2006 | Amana AOCS3040 Electric Single Oven
Function Problem
Paul, the F9-3 code has to do with the oven door lock motor assy.. Water must have gotten on to it and now the fault. There is a quick test mode on the model ending in aab, if yours ends in this try this. Unplug the oven for 30 seconds, plug it back in and press and hold the cancel and broil buttons together. It should enter test mode. When in the test mode press the clean button to see if the motor activates and resets. Press cancel to exit the test mode...Catriver...post back
Aug 15, 2006 | Jenn-Air JES9800A Electric Kitchen Range
Maytag MER6769 Gemini Electric Kitchen Range Logo
117 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal DeAngelo
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
