Apple iPhone Smartphone
Problem for Apple iPhone Smartphone
Iphone clone p168
By xdaloux on Aug 17, 2008
hi, i am on o2 pay as you go and bought one of these a few days ago, but i cant get the internet to work. would you be able to help me please.
thanks lou x
Best Solution
posted on Feb 28, 2009
Very Helpful)
tz1234
Rank: Master
Rating: 84%, 14 votes
You need to do some setups for the internet.
For AT&T
Watch the YouTube video on internet setup for AT&T WAP
***First Step***
1.Main menu --> Select Services
3.Select Data Account --> Select GPRS
5.Select the first entry
6.Edit the account name to whatever you would like
7.Edit APN to wap.cingular (lowercase)
8.Edit Username to WAP@CINGULARGPRS.COM (UPPERCASE)
9.Edit Password to CINGULAR1 (UPPERCASE)
10.Edit Auth Type. to Secure
11. Save
Select Back --> Select Back
***Second Step***
Select WAP
1.Select Settings --> Edit Profile
3.Select the first entry --> Edit Profile
5.edit the name to whatever you would like
6.Edit Homepage to http://device.home
7.Edit Data Account to the Name you established in the First Step
8.Edit Connection type to HTTP
9.The IP address is 066.209.011.032 and the port number is 8080
10.Edit Username to WAP@CINGULARGPRS.COM
11.Edit Password to CINGULAR1
Select back or done
Select Activate Account
You should now see a Black [G] in the upper left of your screen.
MMS
Select Messages --> MMS --> Message Settings
Select Server Profile
Select Edit Profile
Edit Rename Profile to whatever name you would like
Edit Home Page to http://mmsc.cingular.com
Edit Data Account to the same data account you created for WAP
Edit Connection Type to HTTP the IP address is 066.209.011.032 and the port is 8080
Edit the Username to WAP@CINGULARGPRS.COM (UPPERCASE)
Edit the Password to CINGULAR1 (UPPERCASE)
Select Done or Save
Make sure to activate the profile and you are good.
Email will not work with any server that requires smtp authentication (which is pretty much all of them here)
There is no java in the browser. Forget it. There is also no java loader so there is no downloading java games. Copying them to the SD card won't work either. No java loader so the file will be unrecognized.
Wap services like gmail, yahoo email and wap based instant messagers work fine. Make sure you have a good unlimited feature so you do not incur overages from over using your new toy.
For T-mobile:
This is the one that worked for me - I have the $5.99 TMobile Web plan:
Create Data Account
1. Select Menu
2. Select Entertainment
3. Select Services
4. Select Data Account
5. Select GPRS
6. Choose an empty profile
7. Account Name enter T-Mobile WAP
8. Press Options
9. Press Done
10. APN enter wap.voicestream.com
11. Press Options
12. Press Done
13. User Name >Leave Blank<
14. Password >Leave Blank<
15. Auth. Type choose Normal
16. Press Done
17. Press Save
Create Profile
1. Select Menu
3. Select Services
4. Select WAP
5. Select Setting
6. Select Edit Profile
7. Select a profile
8. Choose Edit Profile
9. Rename Profile enter T-Mobile WAP
10. Homepage enter wap.myvoicestream.com
11. Data Account select GPRS
12. Select T-Mobile WAP
13. Connection Type select HTTP
14. Proxy Address enter 216.155.165.050
15. Port enter 8080
16. User Name >Leave Blank<
17. Password >Leave Blank<
18. Press Done
19. When prompted to SAVE please select Yes
20. Select Activate Profile
21. When prompted to Activate Profile please choose Yes
22. Press Done
If you have the $19.99 or higher plan replace the following:
Step 7 under Create Data Account:
Optional - change name from TMobile WAP to TMobile "whatever"
Step 10 under Create Data Account:
use wap.voicestream.com or internet2.voicestream.com or internet3.voicestream.com instead
and
Step 9 under Create Profile:
Step 10 under Create Profile:
change to www.tmobile.com - may not work so try google.com also
SMS, MMS AND VOICEMAIL
1- Click on thee envelope icon it will take you to Messages
CLICK ON SMS
1- Message settings--> click in Profile Setting
2- Click edit on any profile name it T-mobile that will be line No. 1 in No.2 type +12063130004
MMS
1-Message Settings-->click Server Profile
2-Click on any 1--> click on Edit Profile
1- Rename profile
T-mobile MMS
2- Homepage
http://216.155.174.84/servlets/mms
3-Data Account
click on GPRS--> choose Tmobile--> press OK
4- Connection Type
HTTP
5- Username
leave it blank
6 Password
leave it blank
CLICK ON DONE --> SAVE-->ACTIVATE PROFILE
VOICEMAIL:-
Edit it--> name No.1 Viocemail
No.2 +18056377243
NOTE:
Whenever the phone will ask you for a proxy address and port number.
You need that info to be able to get your sevice to work
Here is that info ...
Proxy: 216.155.165.050
port: 8080
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Apple iPhone Smartphone
Questions and Unsolved Problems for Apple iPhone Smartphone
Do you recommend Apple iPhone Smartphone?
Answer
Answer
Ok, so my iPhone won't turn on. I try to turn it on and the Apple logo comes up as per usual. Then... (More)
Answer
can my iphone bluetooth to another phone??
Answer
iphone 3Gs home button not respo, jailbroken on 3.1.2 using blackra1n
Answer
I want to sync my Palm's contact with my new iphone
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Apple iPhone Smartphone:
Top PDA Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more PDA Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
