Question about HP Real Estate Marketing Assistant (y1800a) for PC
HP 5400 Install Hang
I'm trying to install my HP 5400 on my new Dell XPS system (XP OS). I'm using the Setup.exe on the install CD. It hangs up at this point:
> Current Progress: Installing Additional Software. 0.7 KBps
> Overall Progress: Installing (Step 3/4) 94%
It has "stopped" at this point in three different tries.
"Stopped/hung" for ~2 hours, ~10 hours and ~14 hours respectively.
In each case the TaskManager says this application is still "running."
In each case, I used Task Manager to EndTask.
Had same problem with HP 110 Plus (plotter).
Found a previous install of a HP FAX left MANY bogus entries on the registry, I wipe them clean and now all ok.
Hope it helps.
Posted on Dec 02, 2008
SOURCE:
I use hp nx9010, i want to re-install windows xp but any time i try, the machine shutdown. sometimes is able to move up to copping files sometimes not then shutdown; i don't understand why is only windows...
well that is so easy to answer,
first off you are not using real HP disks are you.
sure. its old Blue Microsoft disks right,
and when you do that wrong, you get no HP chip drivers and lost more missing, even top row, fn keys dead, not just audio.
XP is a dead OS. for 3 years now, zero updates and is now a virus magnet extream.
nx9010 note book shuts down, all 3 os install different. !
old XP runs a very old and very DUMBB seteup.,exe
the newer OS run WINPE for setup.exe. vastly better and boots and loads the OS totally different.
Xp can be installed many ways, not one stated by you.
1-insert, HP install disk in CDROM drive and click, setup.exe running in a XP explorer window, live install
2: boot to HP install disk.
3: boot and hit F11 run HPs on HDD restore partition.
4: same as a above 1, or 2, but is Micro soft disk (wrong, you did it wrong, do not use mS disk) if must ask how, its a long long long story. ive done it all ways, 1000s of time. now since first PC.s ever.
if booting to XP , right or wrong CD. (its a CD right<)> or a stick
that too not stated,
it boots and you answer questions, then it starts copying
if it stalls that means, the CD is bad.
or PC is bad, you do know there are 3million transistors here to fail right? bad HDD, bad Mobo, and more. lots more
even the CPU can over heat and will shut down.
Personally I avoid all CD nows, they sux'd then and do now more.
make and ISO of your CD, (ask its easy and free)
then burn the ISO to a 4GB or bigger uSB memory stick using free RUFUS app.
boot to stick. on my HP hit F9 and pick Udisk USB. boot
bingo no more CD errors ever again.
i bet bad CD. seen it vast times, endless , but not today. too savvy now. to mess with any CD, if you copy it to ISO and get CRC errors
its a bad CD.
end pain.
the problem with real old PC most cant boot to USB
or must be BIOS flashed updated to get that.
ill now ill try to learn what yours can or can not do.
lacking ,what is there now.
but id do this first. go in to BIOS BOOT PAGE
What is the default boot order? The default boot order settings for the computer are configured in the factory. The default boot order for HP notebook PCs is listed below.
  1. Floppy disk drive
  2. Optical drive (DVD, CD-ROM)
  3. Hard drive
  4. USB device (see this?) bingo, can boot and install any OS here
  5. Network adapter
Apr 23, 2017 | HP NX9010: Pentium 4-2.4 GHZ, 512MB...
My dell xps m1330 will not boot up.it comes up on screen saying ''no boot sector on internal hard drive'' ''no bootable devices''it has had a new motherboard fitted by Dell.i'm trying to install xp pro
When it's booting, try to access the setup, aka BIOS. See if you can set CD/DVD as a booting option. As the top BOOT device. Then see if you can boot your installation CD. You may be able to format your drive during the installation - if the hard drive hasn't failed?
Nov 23, 2009 | Dell XPS M1330 Notebook
HP C6180 printer install hangs on my XP Thinkpad T43
If the installation hangs using the setup cd , the best thing that you can do here is to download the printer software from HP site and install it after that and that should correct the problem..
Sep 11, 2009 | HP Photosmart C6180 All-In-One InkJet...
Problem loading an OS onto a Dell XPS One 2010
YOU NEED THE BIOS UPDATE FOR THAT ,,GET IT FROM A ANOTHER CPU ,,BOOTABLE DOWNLOAD,,PUT IT ON THE DELL ,,THEN XP,,CHECK THE DELL WEBSITE
May 15, 2009 | Computers & Internet
I have a Dell D600 and I cannot install Windows XP on it
Format your machine to its orignial OS (XP Home). There are some limitations that some of machine wont able to carry. The XP Professional might not compatible with your machine. That's why you encouter hang-up from your machine.
Apr 05, 2009 | Dell Latitude D600: Pentium M 1.6GHz,...
Install Windows xp off USB
If you are only trying to boot to windows then you'll need files NTLDR, Boot.ini, NTDETECT.COM, and NTOSKRNL.EXE on the USB drive. This will boot you to the windows screen. Trick is to get those files off of your windows CD onto your USB...then copy those over to the c:\ and that should also take care of boot problems if it was because of corrupted files.
Apr 04, 2009 | Dell XPS M1530 Laptop
Windows XP setup is not loaded completely
Try using another cd or bootable media.any other will work coz either data of cd is unreadable or your ram problem if data of cd is corrupt then new cd will certainly work and if ram problem then new cd may work or it may hang at another step or none but i think you will get help
Jan 31, 2009 | Microsoft Windows XP Professional
Install Xp From Dos
If XP will not install from the CD or if you have a new drive with no operating system onit yet try these:
Install Windows XP from the hard drive with Windows 98 already installed:
Boot Windows 98
Insert the XP CD into your CD reader
Explore Windows XP through My Computer
Copy i386 folder to C:\
Go into C:\i386 folder and double click on winnt32.exe to launch the setup from the hard drive
Install Windows XP from DOS (ie. no OS on a new hard drive):
Boot with a Windows 98 Start Up disk
Insert the Windows 98 CD into the CD reader
Run smartdrv.exe from the Win98 directory on the windows 98 CD (file caching)
Type cd.. to back up to the root directory
Insert Windows XP CD into the CD reader
Copy the i386 folder to C:\
Go into C:\i386 folder on C: and type winnt.exe to launch the setup from the hard drive.
Oct 20, 2008 | Computers & Internet
Xps reformat
those question marks only indicate your system is not showing drivers for that hardware... last time I reinstall the os on a dell system dell made it a little bit tricky to reinstall the drivers... if I remember correctly you need to run the software on the cds to install the drivers (don't try to install the drivers with the windows wizard as probably the drivers are nicely packaged in the cd.) so look for some setup.exe application on the cd's you may have.. (assuming those are the cd's that came with your system) run it and follow the instructions.. from that point it should be straight forward.
if you don't have the cd to your system here's the driver download website from dell for your system
(check if it is your system first)
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=XPS_PNT_P4_DXG&os=WW1&osl=en&catid=&impid=
download what you need first and don't run everything at the same time. install one at a time and restart as prompted and then move on the next driver installation, until you get all the ? marks out of device manager.
good luck!
Oct 02, 2008 | Dell XPS™ 600 PC Desktop
Open Questions:
See all HP Real Estate Marketing Assistant (y1800a) for PC Questions
HP Real Estate Marketing Assistant (y1800a) for PC Logo
298 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
