Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Pro Heat is not releasing water to do the job! Works only briefly.
We have looked through the machine and tried to make sure all was clear for water to flow but it doesn't. I don't have instruction manual. Please help!
  • 52 Answers
You can find a cop of the instruction manual at http://www.bissell.com/Product_Search.aspx?Criteria=9500+pro-heat
Click on User Guide and a PDF will download.
Posted on Aug 25, 2008
Bissel Pro Heat carpet cleaner is not suctioning cleaning water off of the carpet back into the tank. How can I fix this?
There is a knob on the base that says floor and tools. Make sure that it is closing when you switch it to floor, Make sure that the hose works when you use it too. That will tell us what the problem is.
Jan 30, 2014 | Bissell 1699 ProHeat Clear View Upright...
Hey there, a friend of mine has a bissell pro heat 2x turbo, that is spraying no water on the floor setting, the pump works i assume, as the machine vibrates when the trigger is pulled, how would i...
Check the following with liquid in both tanks.
- Check to see if the machine will spray through the hose with the setting on tools. If it does, the pump is fine. Continue troubleshooting.
- Check for debris on spray tips. Clean them with a soft brush (on old tooth brush works well). The spray tips may be lifted out for easier access.
- Ensure the tank lid is properly attached to the bottom of the tank. To attach this properly, remove the Water Tank from the machine. Hook the front window onto the lip of the bottom container and then allow the window with lid to cover the complete tank. Secure the latch on the back of the bottom tank to the back of the tank lid. THE TANK LID CANNOT BE ATTACHED PROPERLY IF THE BOTTOM TANK IS ALREADY INSTALLED IN THE MACHINE.
- Check the bottom of the Water Tank and the Formula Tank to make sure each has a red auto-load gasket attached. Make sure the Water Tank and the Formula Tank are seated properly. Depress the x on this gasket to ensure this depresses and release back out. Liquid from the tank should dispense.
- Remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
If the machine continues to not spray, check the following:
REMOVE THE COLLECTION TANK:
• Make sure the unit is set to water rinse
• Remove the smart mix bottle and fill it with water only
• Place the smart mix bottle into the collection tank reservoir
• Run the unit and try to spray. If the machine sprays, you will be able to see the water level decreasing in the smart mix bottle and you will need to replace the bottom tank. It is possibly warped.
Nov 22, 2010 | Bissell Vacuums
The machine is not spraying water or cleaning fluid out bissell pro heat 2
Please check the following with liquid in both tanks.
Sep 27, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
My Pro heat 2x by Bissell does not put out or **** up water Brand is Bissell. Model is 8920 12 amp
If these suggestions do not resolve the issue contact BISSELL Consumer Services at...
1-800-237-7691
Mon-Fri: 8am to 10pm ET
Sat: 9am to 8pm ET
Aug 15, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
My Bissell Pro Heat 2X steam cleaner is not releasing the water
Have you tried cleaning out the small filterfrom the reserve tank? Also, check the tank/resevoir valve is operating properly, when you take it out to fill try to make water release from tank.
Apr 29, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Mar 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
My Bissell Pro Heat 2X will not release water or
its probably a solenoid that controls the flow to the floor, take it to a bissell repair center, because its not an easy fix.
Jul 02, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell Pro-heat 2x model 8920
There is probably a bad solenoid in the machine that controls the water out to the floor, you would be better off taking it to a repair place because it is a big mess of hoses and wires.
Jun 29, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell ProHeat Carpet Steam Cleaner stopped spraying.
The problem was a clogged heating unit which is located in the lower handle. There are two clear hoses going up the inside of the left leg of the lower handle that go to the heater and to the in-line water switch all within the lower handle. I unplugged the metal heating unit water lines and electrical connections (label the connections as you take them apart if you have a hard time remembering things...there were seven connection in all be it water and/or electrical). Removed the heat unit out and then removed the 6 screws holding the heater cover. Inside was a white powdery pasty debris (lime deposit ?) and the water path was clearly blocked in four different places. I cleansed the water trough with a little water and soft toothbrush and several toothpicks then reassembled. If you need new washers go to Orchard or ACE hardware. Take the old rubber washers(they are red) with you for comparison. I didn't need new washers...I just gently cleansed them. I immediately ran clear water through the machine and actually cleaned the carpet with a water rinse only. Will go back and finish the carpet the right way tomorrow. I had only used my machine three times before this happend over a three year period. A friend told me to always rinse it two maybe three times with clear water after using it and before storage. This took me exactly 42 minutes to disassembly and reassemble. Cost savings is several hundred dollars since I have a 5 bdrm house and would need a professional cleaner to do the small dirty traffic lanes all around the house.
Sep 29, 2007 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
233 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
