Question about Casio Exilim EX-S600 Digital Camera
I have a casio s600. And recently the screen has stopped working. Like when i turn it on the screen stays black, but the lense still pops out. And if i press the shutter button nothing happens.
  • 17,970 Answers
When a picture is taken, the CCD is struck by light coming through the camera's lens. Each of the thousands or millions of tiny pixels that make up the CCD convert this light into electrons. The number of electrons, usually described as the pixel's accumulated charge, is measured, then converted to a digital value. This last step occurs outside the CCD, in a camera component called an analog-to-digital converter.
Some symptoms of a defective CCD include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card. A CCD problem would explain the lines on your pictures and the lines on the LCD (since the CCD is used to feed the live image). CCD (Charge Coupled Device) is one of the two main types of image sensors used in digital cameras.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details: Bad CCDs
This, isn't a good new, but hope helps to solve it.
Posted on Jun 02, 2011
SOURCE:
Camera closes itself
I think it's rubbing against the ring around the lens. Too much pessure and the lens won't stay out. Or, the battery is low.
Jun 16, 2009 | Casio Exilim EX-S600 Digital Camera
My Casio digital camera QV-R41 lcd viewfinder does not work
Turn the dail to a different position and try again.
Does your lense open up 100%. If not , clean the outside (around) the lense and turn on and off a few times.
If you feel the lense does not retract 100% or does not open up 100%, push it or pull the lense NOT too hard a few times.
Good luck!!!!!!!!
Jun 12, 2009 | Casio Exilim EX-S600 Digital Camera
Casio EX-S600 damaged lcd screen.
take off the back you are going to need a soldiering iron. once the back is off gently lift the lcd out of the holder. fallow the ribbon cable to the plastic hold down. with a very small flat head screw driver. pop up the tab. take off the front case cover on the bottom of the main board you will see the lcd red and black wire de-solider them remember how the go. fallow these steps on the other camera tfering the good lcd to the other unit. and reverse the steps. if you fell this is something you do not want to attack I will replace your lcd with you other units lcd for. 30.00 goto digitalcamrepair.com for more help.
Mar 24, 2009 | Casio Exilim EX-S600 Digital Camera
Lcd aquarter is black
Please clean the lens thoroughly with a soft dry cotton cloth. Clean the edges also. Also try after cleaning the LCD screen.
Feb 10, 2009 | Casio Exilim EX-S600 Digital Camera
Problem
yes I have s600 LCDs if you can buy the LCD from me for 60.00 and repair it your self. or send me the camera and I will fix it for 80.00 plus shipping. goto www.digitalcamrepair.com for contact info.
May 22, 2008 | Casio Exilim EX-S600 Digital Camera
Casio ex-s600 frozen
I just took the battery out and then put it back in.
hehehehe
Mar 06, 2008 | Casio Exilim EX-S600 Digital Camera
Lens do not open
More than likely lens is off track. send into casio to have it fixed.
Oct 19, 2007 | Casio Exilim EX-S600 Digital Camera
Cant see anything when cam on to take pics screen stays black ?
With the power off, hold the camera in your palm and smack the front of the camera on your leg or arm. You might have to smack it a few time to get it to work. It has to do with the camera CDD lense (shuttle) being stuck. By smacking it around, it will free up the lense. Being extra gentle with it though. It worked for me. Hope this help.
May 25, 2007 | Casio Exilim EX-S600 Digital Camera
Casio Exilim EX-S600 Digital Camera Logo
99 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Parshiv Luthra
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
