Question about Microwave Ovens
Microwave does not heat
Sharp Quartz Chef combination microwave R-7E53 blows fuse on hitting microwave start button. Display, light, turntable etc. all work but no heat. Please can someone help?
  • Microwave Ovens Master
  • 9,174 Answers
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
Here is a helpful link you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
Info on ordering Sharp UK parts / spares is here.
The best place to order Sharp parts in the US is Tritronics.
Posted on Aug 18, 2008
SOURCE:
Magic chef MCD1611ST microwave, the display lights up, the time and powerlevel can be set, the light works when the door is open but when i hit start everything shuts off. Any suggestions?
There are a lot of possible causes, but I'd look at the door switches first, and the wiring connectors to them. Make sure the contacts on all the switches are opening and closing.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Nov 19, 2016 | Magic Chef MCD1611ST Microwave Oven
My Sharp Quartz Chef Jet Convection Oven Grill & Microwave model R-7E53 micro is not heating. All is working fine except it does not cook/heat anything i put in it.
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!any capacitors are discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Mar 07, 2011 | Sharp Microwave Ovens
The food in the microwave is not heating up I have tested the fuse (F8AH250V) and found that it has blown. Is it safe to replace this fuse (F8AH250V) on my microwave.
Fuses seldom just go bad on their own, but it's safe to replace. Before you replace the fuse, squeeze the tabs of the fuse holder clips together a bit. Sometimes they don't grip the fuse tightly enough, and this can cause heating which damages the fuse. If the fuse blows again there is a bad part in the oven that will need to be located and replaced. For a small countertop oven, it's probably more economical just to replace the oven than to repair it.
Jan 02, 2011 | Sharp Microwave Oven Microwave Oven
Sharp Carousel Model R-1874 no heating or turning, display works
sorry without seeing the machine we can not help try whatever you want . that is how many of us learned what we know today
Nov 17, 2017 | Sharp R-1874 Convection/Microwave Oven
My microwave keeps blowing the fuse upon hitting the start button
you have one of three problems (H.V. diode shorted or leaky, H.V.capicitor shorted, or the magnrtron tube is beginning to draw excessive current)if thats the case its not usually worth spending that for the mag.,the other two items aren't that expensive
Jul 23, 2009 | Magic Chef CMV1000B Microwave Oven
Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
Jan 08, 2009 | Sharp Microwave Ovens
Dacor dcm24s.light, fan, and control panel work but turntable and heat do not
Most likely the bottom door switch. Dacor units are built by Sharp and that switch is a very common problem. You'd either need to check the switch with an ohm meter or remove the cover of the switch to see if it's burned inside.
Oct 20, 2008 | Sharp R-930AK Convection/Microwave Oven
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
Sharp quartz chef combination microwave R-7E53 blows fuse and emits burning smell - display, light, turntable operate but does not heat. Is it worth repairing?
Aug 11, 2008 | Microwave Ovens
Microwave troubleshooting...
My GE spacesaver microwave all of a sudden stopped heating up things. The lights, fan, turntable, etc. work, but nothing is heating up. Any suggestions?
Oct 23, 2007 | Whirlpool GH8155XM Microwave Oven
Microwave Ovens Logo
94 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
