Question about Sharp 25R-S100 25" TV
HOW TO ADJUST COLOR WITH NO REMOTE
The remote control to our SHARP 25" stopped working and the image is too green. Is there a way to adjust the picture without the remote control or are we just out of luck now? It is a 25F-M50. from 1994 (we bought it about 5-6 years ago new..?) I had to put the below product because this product was not listed.
Thank you!
ivycallaway@hotmail.com
ivy
  • ivycallaway Aug 17, 2008
    Thank you for your ideas! We don't have a menu button on this tv and the universal remotes we have from the cable company get the on screen menu to appear but the cursor doesn't move. I'll try some of our other universal remotes from around the house. Thank you! ivy
  • sivadelle Dec 17, 2008
    I have a 1992 Sony 27EXR25 and the picture is too bright. I have a Sony universal remote but can't get to a screen that has anything to do with picture adjusting. Would appreciate some help.
    Thank you.
    Carolyn
  • 22 Answers
YOU CAN TRY THE MENU BUTTON ON THE CONSOLE.USE THE VOLUME UP/DOWN BUTTONS TO SELECT THE FUNCTION.BETTER YET,JUST REPLACE THE REMOTE WITH A UNIVERSAL ONE.THEY ARE INEXPENSIVE AND ARE REALLY EASY TO SET UP.
Posted on Aug 17, 2008
    Problem Solver:
  • 7 Answers
Go to service mode,switch off the tv then press the vol+ and ch+ in the front panel of tv simultanously then switch on the tv then wait for a few second until it comes on. note: remember all the data they display, if you change the number but it not solve the problem back to original data then press chanel to select and vol to change.
Posted on Oct 29, 2008
The color on my sharp flatscreen is messed up and i can't get it to adjust
Go to menu and select factory default settings from the remote control. Then adjust brightness, contrast, sharpness, color etc. to your likings.
Jul 16, 2012 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Hi, we just moved the tv from one room to another and now the images are just greens and blues. We lost the colors! What can i do?
Sounds like you have bad solder connections at your convergence ic's.These are large amplifier ic's mounted on large heat sinks.These ic's run very hot and can cause faulty connections at the solder joints.Try resoldering ,if this doesn't fix it you will need to replace them and any surrounding resistors that have opened.
Nov 04, 2009 | Panasonic PT-47X54 47" Rear Projection...
Works but prdominantly green, can't ajust with color controls
The lcd polerizer(not sure this is proper name ) is bad.It has three: red,green,blue and one of them is bad. I also have a similar issue but only on the left side. Took it apart and found the bad one.
Mar 07, 2009 | Sharp Notevision XG-NV6XU Multimedia...
Sony 65 inch rear projection
behind the front grille there is a wooden panel remove it and yo will see a small black epoxy box with 6 knobs sticking out from it.
with the color turned down all the way, look closely for r,g,b on the box beside each knob this denotes which knob is for which color.
you need to adjust the 1 marked g on the bottom row. this adjusts the green bias to the green tube. this will get rid off the whiteish lines. adjust this knob counterclockwise in a darkened room untill the color shows a black and white picture. adjust slowly as the set will be monitoring what you are doing and will adjust itself as you adjust. bring the green down just enough so you don't see anything, make sure that you don't see red or blue either, if you do also adjust untill you don't see any color. these adjustments should be done with the input set to a video input that has no signal coming in the set will show the input label and nothing else.
when you have the raster( screen ) all dark you can go to an input with a signal and make sure the image is black and white adjust the bias of the color that is too much so that it is black and white.
hope this makes sense to you. now turn the user color control back to where you want it.you are done. reassemble, enjoy
you might have to do this again in a few months as the control you have adjusted are dirty and can't be cleaned with a cleaner.
moving these controls cleans them but the color balance procedure would have to be completed after such movement of these contols and any quick movement would have to be done with the set turned off. a quick back and forth movement will do a better job cleaning the tracks inside that adjustmet block but will mean you will need to do the setup adjustment all over again in order to get the screen blank and the color to balance to black and white. the top 3 knobs are for focus of the individual colos only adjust if the red, green or blue isn't sharp, you can try these to see with out doing harm. finally if thebias is too low then th lifgt on the front of the set might blink at you and the auto alignment might get part way through and stop. if this happens you need to bring the bias adjustment back up slightly. adjust only the bias for the tube that has too much color to start with and if this happens you will know that the bias control you just adjusted is the 1 that needs to be adjusted slightly.
Sep 22, 2008 | Sony KP-53V75 53" Rear Projection...
Hitachi 43FDXO1B Convergence?
Manual Convergence for the Hitachi. YOU WILL NEED ORIGINAL HITACH REMOTE CONTROL. NONE ELSE WILL DO.
1. Receive an NTSC signal.
2. Press Magic Focus to begin magic focus
3. Press magic focus again during the magic focus process to get the “stop” screen.
4. While stop screen is up, press STATUS or INFO on the remote control (R/C) to bring you to DCAM mode and the service grid (64 point grid).
5. When you first get in here? I believe red is the selected color by default (it is flashing).
6. To choose other colors to converge, use the following buttons on the R/C:
· “STATUS” - Green
· “0” - Red
· “ANT” – Blue
7. Start from the center of the screen and work your way out on one color at a time. I adjusted red across the whole screen to match green. Then I switched to blue, and adjusted that to green as well. After you adjust blue, you
may want to go back and adjust some red again? etc. until the convergence looks good.
· Use 4, 6, 2, and 5 on the R/C to move the cursor position (dotted lines).
· Use thumb stick to move the convergence point color.
Then going along the lines and adjusting, you may run into the problem of getting an ‘S’ curve on the line. You’ll know if you get there. Basically, no matter what you do to adjust the line to be converged, the middle of the line between the points will not straighten out (it bends between the points). To fix this, the manual recommends going to the (7x5) mode which gives you less points to adjust. I had this problem, and the solution worked. There is also another mode (3x3) which gives you even less points. Basically, if the set looks good, you only fine tune it in (13x9) mode (64 point). If you have serious problems, the grids work as:
3x3 – ‘coarse’
7x5 – ‘medium’
13x9 – ‘fine’
10) To get to each of these patterns use the following on the R/C: (only if you need to)
1. (3x3) Press “STATUS” 5 times (only works when DCU is in uncorrected state)
2. (7x5) Press “0” 5 times
3. (13x9) Press “ANT” 5 times
11) If you adjust the 3x3, then you should go to the 7x5, and then the 13x9. You get the point… depending on where you start, work your way up, and always finish on the 13x9
12) When finishing up the 13x9 mode, to get additional ‘grids’ on the edges of the screen, press the PIP CH button on the remote control while in the digital convergence adjustment mode (DCAM). Fine tune the edge convergence as necessary. To exit, press PIP CH again.
13) When convergence is acceptable, press PIP MODE to write data to ROM memory. ROM WRITE? is displayed to alarm system that ROM will be overwritten with new data. Press the PIP MODE button again to write displayed data to ROM.
14) DATA WRITE TO ROM will take approximately 4 seconds and no picture will be displayed.
15) Green dots will be displayed when operation is completed.
16) Press MUTE to return to convergence pattern, then confirm again convergence is acceptable.
17) Turn power OFF.
18) Wait a few seconds. Turn the TV on, and you should have your normal signal. Press Magic Focus button just to make sure the magic focus still works (and that you did the last few steps properly)
Jan 13, 2008 | Hitachi 43FDX01B TV
SONY 61" Rear Projection TV
you will need to get a service manual for the tv and enter the service mode. then you will need to readjust the convergence.
Oct 24, 2007 | Sony KP-53S65 53" Rear Projection...
Green hue instead of actual colors
Short on the crt board, look in the green area. Probably an small 3 leg transistor.
Sep 04, 2007 | Sharp 27L-S300 27" TV
Color Turns Green
HI PLEASE ADJUST THE SCREEN CONTROL OF UR TELEVESION SET IT IS INSIDE THE TV..IF U KNOW THE SCREEN CONTROL IN THE SET THAN MAKE IT LITTLE ANTICLOCKWISE.AND THE SET WILL BE OK..
May 13, 2007 | Sharp 27H-S60 TV
RCA 25: television
Sounds to me like a bad picture tube with circle rainbow like colors.Good luck.
Sep 03, 2006 | RCA F25423 25" TV
Sharp 25R-S100 25" TV Logo
1,200 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
